Question about Cell Phones
It want turn on i wanted to know do you plug the charger in at the top of the phone or the side of the phone to charge it?
  • 358 Answers
Hi,when a phone does not come on, it is either the battery of the phone is dead,
might need to be charge or replaced with another battery.
you can use another battery to test if it is the battery the fault.
The other thing to check is if the phone memory is weak and may need to be restored
back the phone memory.
will need to be flashed.
if too weak to power up the phone all application you downloaded on the phone has
VIRUS and has affected the phone memory.
First Charge the battery for longer hours before using another battery to confirm
if the battery cell is the problem.
If not battery, in think you will have to flash the phone memory for it to come back to life.
You can use the link below to know about how to flash the phone.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
(unlocktotalk.com/UnlockCodeInstructions.htm),
Have a nice day.
Posted on Sep 12, 2010
My kindle fire does not charge.
If you are truing to charge with a USB post then switch to a wall wart. There is often not enough voltage to charge from USB.
Feb 04, 2015 | Amazon Kindle Fire HD
Where is the charger located and what type of charger does a Nokia 5230-1cuse?
The charger plugs in to the top of the phone, on the right hand side. As with most Nokia phones, the charger is a fairly generic device with a small standardized connector. You can pick them up fairly cheaply at many appliance stores if you don't have one.
Alternatively, you could use USB to charge with an adapter such as this on eBay.Note that the phone will not charge on its included USB cable.
Oct 21, 2012 | Cell Phones
Htc wildfire not fully charging always show the led red
When want to charge htc wildfire it is better you turn the phone of before charging. Plug in the charger and charge for about 20mins to 30mins then remove the charger pin-mouth for like 10secs and plug it back in. soon the red light will turn green in less than an hour..
Jul 16, 2012 | HTC Wildfire
My Lg Xenon is not charging properly. It says full battery after i charge it but then when i talk to someone on the phone after about 20 mins it starts beeping saying it has low battery and eventually...
I had a similar problem with a brand new LG Xenon. The battery charger said it was charging but the phone didn't charge. When the battery life on the phone died the phone would not turn on with the charger. I plugged it into my USB port on my laptop and the phone fully charged for real. I got 4 days before I had to recharge it again. Try USB cable to a PC to charge phone. Charger is probably bad. I am getting a replacement and will see if that works.
Oct 21, 2010 | LG Xenon GR500 Cell Phone
Where do I plug the charger into the phone?
It's obvious you don't know the position of your charging port on your phone,the charger of your phone should be plugged in the place specially designed for your charger which is known as the charging port.
It is located either by the side of the phone or by the base,rare times at the top of the phone, depending on the model of your phone,perhaps you should go through the user manual for a detailed description.
If you need further assistance,please reply with the model of your phone and name.
Thanks and take care
Aug 31, 2010 | Cell Phones
I dont know were i plug in the charger on my nokia 5300 xpressmusic phone. i have a circle on top my phone and on the side i could of sweared it goes on the top but i have a charger that doesnt fit on top...
hi,
charger point is located at the cell, identification is this... the hole which has a small rod with in... if you see the whole then the whole which has a small point in the centre...
or download the manual from given link and see manual page no. 17. for image. Download the manual mentioned under first option
http://www.google.co.in/search?rlz=1C1_____enIN348IN348&sourceid=chrome&ie=UTF-8&q=nokia+5300+xpressmusic+phone+manual&qscrl=1
alternate link....
http://support.t-mobile.com/doc/tm30156.pdf?&A2L.SERVICE=UserManual Hope this has helped you... Please rate the answer.... Thanks...
Jul 19, 2010 | Nokia 5300 Grey Cellular Phone
Wont charge
Try a car charger. If the car charger works, then it is either
A) Your power outlet
B) Your wall charger Power Supply unit
C) The phone connector on your wall charger.
If it doesn't work on the car charger, then it is most likely your phone charging system or the connection for charging on your phone. Either way, you will most likely need a new phone. Sorry.
Sep 23, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Charging problems
have you tried your dads battery in your phone it sounds like the battery is dead if your charger works on your dads phone then you know it not the charger the chances are it is the battery it would only be the phone if it has been dropped or got wet if this hasnt happened then the problem is the battery if your dads battery is the same then try charging his batt through your phone that way you would know if it was phone or battery.
If you take the phone into any phone shop they will test the phone and battery for free for you they can try the battery and also try a new battery in your phone and they will tell you if it is phone or battery but from my experiance it is going to be the battery let me know how you get on ok
Nov 27, 2007 | Motorola Mobility MOTORIZR Z3 Cellular...
Cell Phones Logo
18 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
