Question about Whirlpool Ovens
Oven Mod # RB260PXYB O If you set temperature to 425 degrees it will warm up to about 350 (on a analog thermometer). It will not hold that temlperature. It will trickle down to about 259. All this time the "heating" indicator is lighted. The heating element does not glow red except for the initial heating period. If I flip the circuit breaker off and then back on, the heating element once again glows bright red and the temp rises to about 350 where it again begins to cool to 250.
  • marnt777 Sep 12, 2010
    This is a digital oven control. There is no Knob
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems that the oven temperature sensor circuit failed. To resolve this issue you'll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 12, 2010
  • Rylee Smith
    Rylee Smith Sep 12, 2010
    Thats the reason I told you to check and replace the part that has gone bad. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
  • Whirlpool Master
  • 1,711 Answers
This is a frequent problem and idicating that the oven thermostat knob need to be replaced and is complete with the temperature probe.
  • espressonist
    espressonist Sep 12, 2010
    The thermostat is consist from a relay and probe which you should replace.
My Kitchenaid Oven doesn't allow me to set a temperature higher that 350 degrees. Electric oven. For example, i will punch in 425 and the panel will default back the temperature to 350.
350 will be the design max for your oven unless the handbook says for your model is higher rated and is faulty
repair or replace with a higher rated temp oven
Nov 07, 2016 | KitchenAid Ovens
Oven temperature
Hello....Go and get yourself an oven thermometer form a store like Target.Ther are accurate from 100 to 650 degrees and can either sit on, or hang from your oven rack...Then you can be sure...I hope this was helpful....PEACE....
Jan 05, 2012 | Ovens
I have a kenmore mark 1 oven in my apartment and the oven temperature says 1-9 instead of going in degrees such as 100, 350 etc. I am wondering which number stands for which heat?
This Conversion table is from the old Gas Mark scale
I'm thinking it should be right or at least pretty close.
You could also get a cheap ($5-7) oven thermometer from local grocery store.
Put it inside oven to check actual temp achieved.
Gas mark Fahrenheit Celsius
1⁄4 225° 107°
1⁄2 250° 121°
1 275° 135°
2 300° 149°
3 325° 163°
4 350° 177°
5 375° 191°
6 400° 204°
7 425° 218°
8 450° 232°
9 475° 246°
Apr 10, 2011 | Ovens
When set to bake eg: 350 degrees the audio alarm will indicate it's reached temp but the oven is 50- 75 degrees lower. Must wait another 15 min for it to reach the proper temp. Have tried to adjust the off...
If you are monitoring the oven temperature with an analog style thermometer you may actually be ok, but seeing the thermometers slow reaction time.
Some newer ovens actually do pre-heat beep prior to reaching temp in an effort to conserve eelectricity.
A good home test is to try your oven at several different temps to see if there is any variation in internal temperature. Try it one day on 300, the next at 375 and another day at 450. Give your analog style thermometer time to catch up (usually just about 15 min) and leave it on for a half an hour to see if the temp maintains.
Also Beware of aluminum foil AND THE NEW OVEN LINER MATS as they can alter oven performance bay absorbing and blocking the ovens natural heat radiation and convection air flow currents that happen in all ovens, not just convection models.
Another interesting fact is that older ovens used a thermostat in them that operated much like your thermometer and was very slow to react making the oven typically about 100 degrees hotter than where the customer set it. This was just a fact of life before the advent of electronic temperature management and became noticeable when people began trying to bake older "hand me down" recipes in the newer ovens with less than stellar results.
You can mimic the older oven performance by preheating the oven about a hundred degrees higher than called for and after it reaches temp, re-set it to the correct temperature and put the items in right away.
If you find your temperatures fluctuating ask your servicer to replace first the temp sensor and as a last resort the control board as this part is usually pretty expensive.
Good Luck with this!
Jun 14, 2010 | Ovens
Oven temperature does not regulate. The temperature is set for 350 but was 500 degrees in oven according to thermometer. Then sometimes you set it for 350 and it will get to almost 350 and then start...
From the symptons you describe, I would say that the oven thermostat is faulty, and in need of replacement.
Make sure your thermometer is o/k by checking it against another one, or boil some water, and check the temp of the boiling water, this should determine if your thermometer is o/k.
Hope this helps.
Dec 20, 2009 | Kenmore Ovens
My Whirlpool oven no longer heats to the set temperature.
Temp probe/thermometer inside oven dirty, or off attachment, or defective. On some models, a small screw head adjustment is provided to calibrate thermometer under dial knob. Else, I would just set dial 50 degrees higher rather than expense of new thermometer or dial.
Mar 02, 2009 | Ovens
Oven will not achieve setpoint temperature.
You may not need anything. Most people test their oven with a dial type oven thermometer. They are slow to react and often not very accurate. When I test an oven or install a new thermostat, I use a digital thermometer with a remote temperature probe, hanging from the center of the oven, which shows the temp in tenths of a degree. I let the oven cycle on and off at least three times, then take the high and lower readings on the next cycle and average that out to see what the actual oven temp is. Most of the time, if there is a dial type thermometer in the oven it is very slow to react. After 3 to 5 cycles, they often show close to what the actual oven temp is, but the only way to know for sure is to use the more accurate digital thermometer. Most ranges with digital displays can be adjusted + or - about 35 degrees. Check your users manual for this info, but don't mess with it until you have checked the oven with a digital thermometer! Please don't bother rating this solution, as anything but a Fix-Ya drops my score. Thanks.
Jan 08, 2009 | Amana Ovens
Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
Nov 27, 2008 | Amana AOCS3040SS Electric Single Oven
Kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
Ovens Logo
351 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
