Question about Car Audio & Video
XO1915BT In Dash Mobile System
I just installed this into my 2004 Buick Rendezvous.
I know its hooked up correctly because i can listen to the radio and the bluetooth is working fine.
Whenever I insert a DVD it plays for about 2 seconds and then the screen turns blue and says "caution: do not watch screen while driving"
With the type of vehicle i have, there is no break detection wire that I can ground to bypass this.
Any help on how to get the DVD's to play?
There is a wire included in the harness, which needs to be connected to a ground I think it was called "PARK" or something. Just turn on the radio with a dvd in it, while touching the excess wires to a ground. You'll quickly have it in hand.
This was done as a safety feature to ensure you're not driving while watching a DVD.
Posted on Jul 15, 2008
Set clock on 2004 Rendezvous
push and hold the H button four the hours to change and push and hold the M button to change the minutes. You just have to hold them in until the numbers change.
Mar 09, 2014 | 2004 Buick Rendezvous
Does anyone have the factory radio wiring diagram for the 04 Buick Rendezvous? I am wanting to remove the factory radio and install my Sony stereo. I have found 1 wiring diagram, But it seems to be off. On...
it should be written cast on radio for wire purpose
orange wire is there for ignition current turn on and off radio current
red for battery current (keep radio setting,clock)
Oct 14, 2013 | 2004 Buick Rendezvous
2004 buick rendezvous ... interior/dash/mirror fuse keeps blowing.
Pull the electrical connector to the visors out of the headliner and disconnect it from both visors, see if the short goes away.
Oct 19, 2012 | 2004 Buick Rendezvous
My inlaws' 2004 buick rendezvouz: the dash lights don't come on. Dealer says no dash lights were installed on that model. Chris
The dealer is blowing smoke up your tailpipe. I couldn't find a manual for the '04, but the '03 and '05 have identical controls for the dash lights, so it's a very good bet the the '04 is the same. Here's a link to the manual for the '05 -- you will find the dash light control on page 3-16.
http://www.extendedgmwarranty.com/owners-manual/buick/2005-Buick-Rendezvous.pdf
P.S. You might want to print the page and confront the dealer with it . . .
Mar 27, 2011 | 2004 Buick Rendezvous
How to change thermostat on 2004 buick rendezvous
Hi there, below are the removal/installation instructions for your thermostat.
REMOVAL:
  • Remove the air cleaner and duct assembly.
  • Drain the coolant until the coolant level is below the thermostat.
  • Remove the crossover exhaust pipe.
  • Remove the radiator hose from the thermostat housing.
  • Remove the thermostat housing bolts and clean any sealer from the bolt threads.
  • Remove the thermostat housing and gasket.
  • Remove the thermostat.
  • Clean the mating surfaces.
INSTALLATION:
  • Install the thermostat.
  • Install the thermostat housing and gasket.
NOTE: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
  • Install the thermostat housing bolts and tighten them to 18 ft. lbs. (25 Nm).
  • Install the radiator hose to the thermostat housing.
  • Install the crossover exhaust pipe.
  • Install the air cleaner and duct assembly.
  • Fill the cooling system.
Hope it helps
Jan 12, 2011 | 2004 Buick Rendezvous
Easy way to change thermostat on 2004 buick rendezvous
Hi, below are the removal/installation instructions for your thermostat.
REMOVAL:
INSTALLATION:
Jan 11, 2011 | 2004 Buick Rendezvous
My 2004 Rendezvous makes a clunking noise when I make turns. I was backing out of a parking space last night and the radio went off and said "locked" then the dash flashed "security-service this vehicle...
Wheel bearing. Ive had to replace my front passenger wheel bearing at 75000 miles when a clunking noise came about. another problem it might be is a tire rod malfunction.
Jan 06, 2010 | 2004 Buick Rendezvous
My 2002 buick rendezvous radio lock came on and my dash lights will not come on now
my radio and power options wouldnt work and it said security. My boy friend disconnected the battery cables and quickly rubbed the positive and negative ends together which rebooted the computor. I do not know if its good for it or not but it definately worked my power options are back.
Nov 20, 2009 | 2002 Buick Rendezvous
2004 Buick Rendezvous how do I override the ambient light sensor to keep dash lights on all the time
That sensor also turns the headlights on/off, not just the dash lights. You should be able to adjust the brightness.
Nov 12, 2009 | 2002 Buick Rendezvous
Car Audio & Video Logo
200 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
