Question about Whirlpool Washing Machines
Front control lock light is on. How do I make it go off?
Whirlpool Front control lock light is on. How do I make it go off?
Posted on May 14, 2008
Fuses panel described in English
Hope this helps your out. I know the diagram and locator is a bit blurry but hopefully it gets what you need.
Drivers kick panel:
Front wiper 20A - Front wiper system Cigar 15A- Cigarette lighter Audio 10A- Audio, remote control mirror Air Bag 10A -Air bag diagnostics Stop lights- 15A -Rear brake light, high mounted stop light ECU B+ 10A - Shift lock actuator, transaxle controle module, radio, engine control module Room 10A - Interior light, clock, ignition key reminder, rear cargo area light switch ABS 10A- Anti lock brake system control unit ECU IG1 10A - Transaxle control module, shift lock actuator, ABS control unit, DRL unit Meter 10A - Instrument panel, back-up switch, electronics time control module, inhibit switch Turn signal 10A- Hazard switch ,front and rear turn lights, turn indicator IGN1 20A - Ignition switch ABS 30A- ABS pump motor TNS 30A- Tail light, license plate light COOL/FAN 30A- Cooling fan Cond/Fan 20A- A/C condenser fan Starter 15A- Start signal , Fuel pump Blower 25A- Blower Motor SR/ACC 10A - Ignition switch Hazard 15A - Hazard and turn signal light D/Lock 25A- Door locks ABS 30A - Anti lock brake system control P/W RH 20A- Power window motor right hand P/W LH 20A- Power window motor left hand IGN2 25A- Ignition Switch
Engine compartment :
Head 25A- headlights IG 2 30A- Ignition switch IG coil 15A -Ignition coil, condenser,generator IC regulator, diagnostic connector. O2 down 10A- Rear O2 sensor O2 up 10A- Front O2 sensor Fuel pump 10A -Fuel pump unit Injector 10A -Fuel injector ,camshaft positioning sensor, purge solenoid valve, EVAP, IAC actuator, Mass Airflow sensor, EGR stepper motor. fuel pump relay coil, vehicle speed sensor. A/Con 10A - A/C compressor controls, cooling fan BTN 30A- Brake light , high mounted stop light. Tail light LH 10A- License plate light, tail light , rear combo light, instrument panel illumination Tail light RH 10A-License plate light, tail light , rear combo light, instrument panel illumination Head low 15A- Headlight Head Hi 15A-Headlight Horn 15A- Horn jlmacman.png jlmacman_0.png
Mar 07, 2011 | 1995 Kia Sephia
Tip
The front light lit on my Whirlpool dryer is showing control locked
Hi.
If the front light lit is control locked, that means that your Whirlpool electric dryer had been set in control lock mode.
Control lock is a special mode that will prevent user from changing settings or using control until the dryer gets unlocked again.
The machine is set to control lock mode by holding down the CONTROL LOCK/UNLOCK button for several seconds. In the same way you can stop the control lock mode when the machine is already set to Control Lock.
When the dryer is running and Control Locked is on, the dryer can still be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If the front light lit is control locked but the dryer door opens and it does not turn off, then you are probably in this situation. In that case, the door will be opening , but the machine still stays locked.
Disconnecting the machine from power, either unplugging power cord or tripping circuit breaker, won't help. The control lock system is designed to stay on in case of power failure.
If the machine is control locked, try unlocking it with the following procedure.
To unlock: Press and hold the CONTROL LOCK/UNLOCK button for 3 to 5 seconds to turn the control lock feature off.
If that does not work, try disconnecting power for five minutes to reset the machine, and eventually do unlock again. As said, cutting power alone will not cause the machine to unlock.
If the machine is still not responding, the lights stay on all the time, the dryer panel does not respond to control unlock procedure, and the door does not lock anymore, then it may be a defective control board.
If you are in this situation, before replacing the control board more parts, including the door lock must be tested. In that case the best option may be contacting the Whirlpool support number listed on the Dryer use and care manual, usually in the last pages.
In this case try resetting control lock as explained above, as told the dryer is more likely control locked and then stopped.
Regards.
Ginko.
on Feb 01, 2010 | Whirlpool GEW9250 Electric Dryer
Control locked light is on, what does that mean?
To unlock the controls: Press and hold the End Of Cycle Signal button until the Control Lock light goes Off.
To lock the controls: Press and hold the End Of Cycle Signal button until the Control Lock light comes On.
Feb 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Front door wont close control locked light is on
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Thank you !!
Jun 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control is locked
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED Status light turns off.
Feb 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control Locked
Locking controls
The Control Lock prevents unintended use of the washer. You
can also use the control lock feature to prevent unintended cycle
or option changes during a cycle. When CONTROL LOCKED is
lit, all buttons are disabled. You can lock the washer while it is
operating.
Select and hold END OF CYCLE SIGNAL for 3 seconds.
The CONTROL LOCKED status light glows.
Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
Oct 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control locked light on
First remove the plug for 5 minutes and this will reset the system.
Check to see if the light beside the LOCK ICON is lit on the status lights. If it is, then the controls are locked. Press and hold the OPTIONS and SELECT buttons simultaneously until the lock light goes out. This should free up your controls so that the washer will operate normally.If the console will not respond, then you could have a failed control or a stuck button.
Apr 03, 2009 | Whirlpool LHW0050PQ Front Load Washer
Control Lock is on my front loader.
You should be able to unlock the control lock by holding the "end of cycle" signal for 3 seconds or until the "control locked" status light turns off.
If that doesn't work, please post your model number.
Mar 07, 2009 | Whirlpool GHW9400 Front Load Washer
check your panel closly the lower right hand button is marked"control lock" hold for 3 secs and youll release the control lock
Dec 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag washer panel show a red light that say control lock what if anything i can do to releaseit
Try the "End of Cycle" button to the right of panel front, next to Start button. Mine says hold for three seconds to lock/ unlock control.
Mar 10, 2008 | Washing Machines
Washing Machines Logo
29 people viewed this question
Dan Webster
Dan Webster
Sal De
