Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
MY A/C WAS WORKING FINE THEN JUST CUT OFF AND THE ELECTRONIC THERMOSTAT WENT BLANK I CHECKED THERE IS NO BATTERIES CHECKED THE DRAIN PAN AND THE BREAKERS ANY IDEAS WHAT IT MIGHT BE
  • 674 Answers
Check the transformer. Remove the thermostat face and use a voltmeter to check for 24vac between the R terminal and the C terminal. If it's not there check for power on the transformers primary and secondary sides. Replace the transformer if you have power on the primary and none on the secondary. If you don't have any on the primary you should look for a fuse or another circuit breaker.
Posted on Sep 13, 2010
The thermostat went blank and the unit quit working
Likely a float switch on the drain line or in emergency pan. Or batteries in the tstat are dead
Jul 13, 2017 | Heating & Cooling
Carrier blank thermostat
Hello, sometimes this happens when the condensate overflow switch trips duento a clogged condensate line. You need to find the outlet of the condensate pipe and use a wet/dry vac to clean it out. The pipe will be 3/4 inch PVC. Let me know what you find. If the drain is clear then the problem could be related to a burned out transformer or dead batteries if the thermostat uses batteries.
May 23, 2012 | Carrier Heating & Cooling
I have a braeburn 3200 thermostat that has went blank on me yesterday. I have checked the fuse box, no tripped breaker, i have checked the switch on the furnace, its on, and there are no batteries. Im not...
If there are no batteries in the thermostat then the furnace was being used to power it. To make sure it is just a thermostat problem, you can jumper the power and heat wires that connect to the thermostat, usually red and white, or terminals R and W. If the furnace comes on, then you need a new thermostat. If that doesn't work, you have lost power at the furnace somehow. If the breakers are good, and the furnace switch is on, then you can have a bad door switch inside the furnace, a bad transformer in the furnace, or a bad circuit board if equipped. If there is a circuit board, they usually have fuses somewhere on them too that can blow. Just be sure to cut power off at the breakers before checking. Hope this helps and good luck!
Dec 11, 2010 | Honeywell Electronic Programmable...
I have a Honeywell T8601D thomastat. It has been in service for 5 years and operated well. In the last month, it has gone "dark" (stopped working) 3 times. The first time it stopped working for a couple...
If you have a float switch on your drain line and the drain is backing up this will cut power to the tstat. Drain slowly drains, float switch resets, power comes back to tstat. That's my educated guess. But, is there batteries in the tstat?
Jun 25, 2017 | Honeywell Electronic Programmable...
Carrier a/c thermostat was working fine, then display went blank!
if it has no batt I would ck transformer for 24to26 volts no voltage replece transformer be sure trans has 115 volts to it trans should be in furnace section
Jun 09, 2010 | Carrier 38CKC030 Air Conditioner
Compressor for air will not cycle on.
Check and see if you have a common wire on the thermostat. If you do not, then you will need to replace batteries if applicable.
If you do have a common wire, then batteries are not necessary for thermostat operation.
Even though the thermostat wires are secured properly and the thermostat worked fine in the heat mode, it doesn't mean it will work for the AC mode.
If you want to check the thermostat in an easy manner, you will need to jump out the Red and Yellow terminals at the thermostat. Be sure to turn off power first to the furnace. After jumping out, restore power to furnace. If the unit comes on, then your thermostat is bad. If the unit fails to come on, you have another issue. You can repeat this process at the outdoor unit with the low voltage lines if you feel capable. If unit comes on, your problem lies between thermostat and outdoor unit. If your unit fails to start, your problem lies within the outdoor unit.
Be sure to check any drain pans, float switches, or cut-out safeties installed that may cause this. Many contractors will wire in drain safeties to the outdoor unit to shut down the compressor in the event a drain line has clogged and backed up into the emergency pan. Of a condensate pump has failed.
If you do not feel you are capable of this, you may need to contact a local professional to come diagnose the situation. But those are a few simple tasks that you can complete yourself to narrow down a problem.
May 26, 2010 | Heating & Cooling
THERMOSTAT DISPLAY GOES OUT AND A/C DOES NOT WORK UPSTAIRS. TOOK SAME UNIT AND PLACED ON DOWNSTAIRS BASE AND IT WORKED.
check drain pan in attic to make sure water has not caused float switch to cut low voltage to thermostat off.
Oct 18, 2009 | Heating & Cooling
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
133 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
