Question about Kodak EasyShare M1033 Digital Camera
When camera is switched on, it says reset date and time and no key functions
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. Please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 12, 2010
How do I set the time date stamp
• Setting Date & Time Use the Date & Time function to set the date and time of your camera. This function is useful attaching date stamps on captured images. Your camera uses a 12-hour time format. 1. Press the navigation controls to adjust date and time value. By holding down the up arrow or down arrow keys, the numeric values change continuously. 2. Press OK to apply changes.
or you can get help from manual here
https://images-na.ssl-images-amazon.com/images/G/01/00/00/10/67/62/13/1067621330.pdf
at page 73
Good Luck
Jan 09, 2011 | Polaroid i1437 Digital Camera
How to date change in camera for display see date
Switch on the cameraPress MENU at the back You will 2 icons. One for camera and other for tools. Select tools settings
Scroll down to Date & Time settings. Press Set/Function. Change the date and time as per our time zone. Press again Set/Function. For display of date Select camera icon and on the drop down menu select display. By pressing the function key select the date /date and time. Press Set. The camera is set. Whenever you view picture it will display the date and time
Apr 26, 2010 | Canon IXUS 80 IS Digital Camera
How do you reset the time & date onthe new
This information is in your cameras owner's manual.
Select the camera menu. Time is a system function. Go to system settings. Set the clock.
Here is the owner's Manual for your camera
Apr 19, 2010 | Video Cameras
Date to appear on photo
Set the image size to 'postcard'. Press the Function key, scroll down to the bottom icon and select postcard (L, M1, M2, S, postcard). Press Function key again.
To turn the date imprint on, go to the Record menu and set the option for Date Stamp to Date or Date & Time.
Jan 06, 2009 | Canon PowerShot SD300 / IXUS 40 Digital...
Turning off recordng message.
You can turn the display off during playback mode, however, if the display was on during recording, that cannot be turned off. . 1. Press the DISPLAY button on the left side panel. 2. Each press of the button toggles the OSD function on and off. When you turn the OSD off : * In CAM mode: The STBY, REC, EASY.Q modes are always displayed on the OSD, even when the OSD is turned OFF and the key input is displayed for 3 seconds then turned off. * In PLAYER mode: When you press any Function button, the function is displayed on the OSD for 3 seconds before it turns off. Turning the DATE/TIME on/off * The DATE/TIME is not affected when the OSD function is switched ON or OFF. * To turn the DATE/TIME on or off, access the menu and change the DATE/TIME mode.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Settings affected
The functions available from the arrow pad, which are Self-Timer (arrow left key), Exposure Compensation for adjusting brightness (arrow up key), Macro and Super Macro Modes for close up photos (arrow right key) will all be reset using the RESET arrow pad button. Also, the quality/resolution will be set back to the default of HQ, but settings such as the language, the date and time, sleep time settings are not changed by using the reset button. These settings need to be manually selected through the menus in order to reset or change them.
Aug 31, 2005 | Olympus D-545 Zoom Digital Camera
Settings affected
The functions available from the arrow pad, which are Self-Timer (arrow left key), Exposure Compensation for adjusting brightness (arrow up key), Macro and Super Macro Modes for close up photos (arrow right key) will all be reset using the RESET arrow pad button. Also, the quality/resolution will be set back to the default of HQ, but settings such as the language, the date and time, sleep time setting and video out to either NTSC or PAL are settings which are not changed by using the reset button. These settings need to be manually selected through the menus in order to reset or change them.
Aug 31, 2005 | Olympus D-535 Zoom / C370 Zoom Digital...
Settings affected
The functions accessed from the arrow pad—Self-Timer (arrow left key), Exposure Compensation for adjusting brightness (up arrow key), Macro and Super Macro Modes for close-up photos (right arrow key)—will all be reset using the RESET arrow pad button. Also, the quality/resolution will be set back to the default of HQ. Settings such as language, date and time, and sleep time settings are not changed by using the reset button. These settings need to be manually selected through the menus in order to reset or change them.
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
Settings affected
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
Kodak EasyShare M1033 Digital Camera Logo
83 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
