Question about Westinghouse WWSR1 Iron
Are you supposed to replace the filter? I don't have filter information...
How do I replace breville ironing catriged
Hello there,
From Breville website, there is NO insruction manual for the VIN 002 !!!!!
Go here for all of them
http://www.breville.co.uk/cat-search?cat=Irons&term=Manual
I don't know what you meant by 'cartridge' but Just looking at one randomly, it says.......
Anti-scale filter
Your iron is fitted with a permanent anti-scale filter. This filter is fixed and cannot be
removed for cleaning
Hope this helps
Sep 16, 2014 | Breville IN002 Iron
Steam iron model 14884. Need replacement filter. Can I get locally or only order online
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Please provide manufacturer name of your steam iron. Also which city are you located in.
Jul 31, 2014 | Irons
It is my first time using it, I brought it from USA and it is not working at all!!
follow this steps and fix it. God bless you
If the iron doesn't heat, make sure power is on to the outlet, check the electric cord and check the thermostat .
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat
If the iron does not spray properly, inspect and clean the nozzle
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Jun 11, 2013 | Black & Decker Irons
My iron is getting hot but giving no steam can anyone advise
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle (see below).
Jan 31, 2013 | Breville Vin227 Extreme Steam Steam...
Bosch Sensixx B25L
see the instruction from your manual:
Check the owner's manual for your iron to learn the manufacturer's suggestions for cleaning, what water to use, and storage tips.
Soft-water systems add minerals that can harm an electric steam iron and your clothes so don't fill the iron with softened water. Instead, use filtered or distilled water.
2) if the iron does not heat a( test the power cord for open or defective b) and thermostat for adjust c) test the thermal fuse d) test the heating element for open.
God bless you
Jul 31, 2012 | Bosch Irons
How do i reset filter flashing on my breville iin195,just replaced filter but still flashing
how do i reset my filter on my steam genorator iron breville iin195 many thanks if some 1 could help please
Sep 28, 2011 | Breville Irons
I am trying to find a replacement filter for the russell hobbs steam station Model RHTC102ST
where can i purchase a filter for Russell Hobbs steam station model rhtc102st
Mar 19, 2010 | Irons
Replace filter beads
how do I open the compartment to replace the filter beads for my iron?
Jul 30, 2009 | Westinghouse WWSR1 Iron
Iron shut off; will not go back on
There is a thermal fuse in the iron which blows when overheated. This fuse has to be replaced.
You can probably find one on-line at radioshack.com -- match the temperature rating of the old fuse. It'll have to be crimped in -- if you solder it, the heat will blow it.
Apr 29, 2009 | Black & Decker AS100 Iron
Westinghouse WWSR1 Iron Logo
32 people viewed this question
Top Westinghouse Irons Experts
Are you a Westinghouse Iron Expert? Answer questions, earn points and help others
