Question about Singer 3116 Simple
The thread keeps tangling in the metal bobbin contraption, I don't know why?
    Genius:
  • 1,788 Answers
Read your manual, it seems like you do not have it threaded right. Did you take it apart? Look at the diagram at singerco.com and see if you have it together right.
Posted on Sep 12, 2010
I keep getting error E6 on Brothers CS 6000i- I cleaned the thread several times and when I try to restart sewing it happens again. I've removed the bobbin and re-threaded and it keep jammin and beeping....
The motor locked up because the thread is tangled.
Solution:
Remove the tangled thread before continuing the operation.
Clean the bobbin case to remove the tangled thread.
After cleaning the bobbin case, insert the bobbin case properly.
If the needle is bent or broken, replace the needle.
Then, thread the upper thread properly, and continue the operation.
Dec 21, 2013 | Brother CS-6000i CS6000i 60-Stitch...
How do i put threed into the bobbin and keep it from not getting tangled?
Is it getting tangled while you're spooling the bobbin on the top right corner of the Singer 1507 machine? If this is the case, you have to pull the thread through the top tiny hole in the bobbin, and hold on to the thread end. Then click the bobbin to the right to lock it in place, power up your machine. Keep holding the thread as you begin spooling the bobbin. Let go of the thread once the bobbin starts to spin a few rounds and the thread should not get tangled.
Sep 29, 2010 | Singer 1507
I've tried everything that other users have suggested, but the thread keeps gathering immediately in the bobbin case. What should I do?
It has to be in the threading, either your thread is tangled, or incompatible with your bobbin thread. How is your needle?
Is the thread that is tangling from the bobbin? If, so you have your bobbin inserted upside down and the thread is not unwinding right. If, all that does not work, call Janome at 1-800-631-0183 before 5pm est
Sep 17, 2010 | Janome Thread Banger TB12 Sewing Machine
My top thread wont raise the bobbin thread. It just keeps getting jammed in the turning contraption were the bobbin is housed.
Try metal SA 156 bobbins, they seem to work better. You can buy them on ebay 20 for $8.99 and free shipping.
Sep 14, 2010 | Singer 3116 Simple
I keep getting an E6 error message - tangled thread. I think it's the bobbin thread that's getting tangled, and I can't figure out why, or how to fix it. Any ideas?
It could be that the bobbin is being put in upside down check to make sure that you do not need a bobbin with a magnet on one side. also make sure there is no thread tangled inside the bobbin housing it will cause the timing of the machine to be off and cause issues with your needle picking up the bobbin and thus cause a mess inside you bobbin housing
Apr 02, 2010 | Brother BC-1000 Computerized Sewing...
My Brother XL5130 tangled thread on bottom
Check to ensure that you have routed your bobbin thread properly in the bobbin case.
Mar 27, 2010 | Brother Sewing Machines
I can't keep the lower thread from getting tangled. I have rewound bobbins, cleaned the bobbin case, made sure the bobbin case is in the correct position, and played with the upper thread tension. When...
Ensure that you have routed the bobbin thread properly. Also, if the bobbin case is not installed properly it will give you this problem. Ensure that the protrusion is touching the spring on the body of the machine.
Jan 27, 2010 | Brother CS-6000
Bobbin tangling
Sounds like the bobbin is spinning to fast or is winded to loose. Try adjusting the tension on the bobbin.
May 05, 2009 | Sewing Machines
Thread breaks
Hi!
Check to see if the lower thread be tangled. Also, the bobbin could be threaded improperly in the shuttle hook. Rethread the bobbin in the shuttle hook.
How to detangle a thread---
  • When a machine stops operation due to tangled thread, do not turn the pulley by force.
    If the pulley is turned by force then, lower thread might not be picked up correctly and stitches might not be formed correctly.
  • If threads get tangled, remove a needle plate and cut the tangled threads by scissors or cutter.
  • Do rate the solution if you find it helpful & useful.
    Thanks
    Rylee
    Jan 30, 2009 | Husqvarna Viking 1
    Singer 3116 Simple Logo
    Top Singer Sewing Machines Experts
    Tally Girl
    Tally Girl
    mystery_soul
    Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
