Question about Craftsman Garden
Pressure washer schematic on ser.#580752600, mdl #1008442913, psi 2600, 7.0 hp ohv intek platinum plus, specifically the pump schematic?
  • 2,176 Answers
Go to Managemyhome.com and under manuals type in the number 580752600. The manual is 28 pages long and can be downloaded. The parts list section specifically the pump is towards the end of the manual. Let me know if you need more assistance
Posted on Sep 12, 2010
Can I USE SAE 30 NON DETERGENT OIL IN MY HUSKY 2600 PSI PREASURE WASHER.
Gasoline-powered pressure washers use an SAE 30W motor oil (10W-30) in the engine. Always consult the engine manual for specific instructions and be careful to put the correct oil in the correct place.
Pressure Washers Buyer Guide
Aug 03, 2015 | Psi Garden
What kind of oil to ues on pump ona husky 2600 preassore washer
I use the SAE30 Non-detergent Mineral Pump oil as it is formulated for the high pressure pump.
Feb 28, 2015 | Homelite 308653009 Blackmax Husky Pressure...
I HAVE AVANGUARD 9HP PRESSURE WASHER NEED TO KNOW PSI @GPM OF THIS
most rarely exceed 2600 psi as these can blow right through your hand..gpm maybe 40-45..there should be a plate with all that on the unit..
Jul 10, 2014 | Briggs & Stratton Briggs Stratton Vanguard...
2600 PSI Pressure washer will not draw detergent up
I posted an answer to no soap on the Karcher Factory-Reconditioned 2,600 PSI 2.3 GPM Gas Pressure Washer G 2600 VHR. Same machine I suppose, but use the black 65 l degree low pressure nozzle.
It's in the manual , I missed it and had a hell of a time trying to figure it out. If that doesn't work check the check valve on the pump(Where the soap hose is) , see if it's gummed up.
Be careful taking it off there's a spring and ball bearing in there.
Apr 09, 2013 | Karcher Garden
Where can I get a rebuild kit for pump?model XR-2600.
remove the pump and throw it away. Buy a better designed pump on eBay. just search your pressure washer model number or the obsolete rebuild kit part number a14292 you'll find the better pump.
Apr 03, 2012 | Honda Black Max 2600 PSI Pressure Washer
Pressure washer with Honda GX160 5.5 HP OHV-Starts easily but...
what about the linkage between the governer and the carb. Is that working and not binding?
Dec 20, 2009 | Honda Pressure Washer PSI 3000
Jet of water from a bent-elbow fitting when pulling gun trigger
the elbow may be cract insight, try to open it, but first diskonect it from power jet.
Jul 15, 2009 | Karcher 2500 PSI Pressure Washer
7.0 hp OHV Platinum Plus engine on a power washer will not start. Drained gas and put up for 2 years, refilled with gas and will not start. checked the gas lines; all clear, will run for a few seconds when...
If you can get the carby bowl off the main jet is up the centre sounds like its blocked there should be a model type and code on the engine cowl or on the rocker cover you can look up an exploded view on a site called pats small engines
Jul 13, 2009 | Parks Optical 13.5hp Briggs And Stratton...
Garden Logo
601 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
