Question about Frigidaire GLEQ2152ES Electric Dryer
I try to start my dryer with clothes in it, And all i get is a humming sound. With out any clothes init i sttill get a humming sound. The other dy, I found the dryer making a wweird sound, and the filter out of it. I put the filter bak in, but found a sock in the filter slot. I removed the sock, and put filter back in place. What could this be?
  • 1,531 Answers
There may be another piece of clothing down in the blower wheel remove the lid then take off the control panel to remove the front panel and look in the blower wheel housing. you may need to also clean the motor from any lint build up this can cause starting issues.
Posted on Sep 12, 2010
  • Frigidaire Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The sock is irrelevant... just happened that your motor is going bad at the same time...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Dryer heats, and runs empty. Once even a small clothing item is added, when the start button is hit, there is a buzzing noise and it will not start. It then will also not run empty for a time. What could...
hum might check ur moister sensor? and also u may have bad motor windings try this If you hear a humming sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Mar 30, 2015 | Dryers
Drum will turn empty but will not turn with heavy wet clothes in dryer. Is it a bad motor?
no, most likely, especially if it sounds right, it is a bad belt. The reason why i say if it sounds right is because the machine don't know the difference. if it was the motor you would hear a really loud hum before it stopped and then maybe it would start back up and hum some more. if your clothes are really heavy like dripping on your feet heavy. then you have a problem with your washer. Probably a transmission.
Jun 27, 2010 | Speed Queen AGS28AWF Gas Dryer
Dryer wont start when start button is pressed, but humming sound
I'd sure start by making sure the belt isn't broken. You can usually see the belt with a flashlight after accessing the panel (some are in front, others in the rear) - don't go probing around bare armed without unplugging the unit....
Jun 20, 2009 | Whirlpool LER5636P Electric Dryer
Clothes dryer stops spinning before clothes are dry
sounds like a bad cycling thermostat!
May 26, 2009 | Bosch Dryers
Clothes dryer don't run
sounds like a bad cycle timer switch
Apr 22, 2009 | General Electric Clothes Dryer Knob -...
Our Kenmore clothes dryer is not starting.
its sounds like you have a broken belt or a bad door swith open the door rotate the drum manually if it feels verry easy to turn that means your belt is broken if not you can check the wires then replace the door switck thanks from gilles
Mar 15, 2009 | Kenmore 84052 Dryer
Dryer Starts... Then Stops!...
Sounds as if you have a bad motor. That humming is a big give away. Unless its less than 3 years. I would replace it.
Oct 29, 2008 | GE DBXR463EBWW Electric Dryer
Maytag electric dryer when i set dial to desired setting i here a humming sound prior to pushing start button it has never done this before also the clothes is VERY hot when i take it out model ...
it sounds like a shorted heater element, this would also cause the heat to stay on at 110 volts which would make the clothes very hot since the element doesn't completely shut down. if it is a loud hum it could be a stuck motor switch but in this case the dryer usually won't start.
Jun 08, 2008 | Maytag Dryers
My washer does not wash the clothes or go through the spin cycle.
It sound like a belt problem. Try to move tub manually first, in case it move smoothly -open the front panel, the belt should be between the motor and the drive pulley (lower front). In case it torn or not in its place, you should replace it. In case it doesn't move smoothly - maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and prevent tub's spining. If this is the situation, it should be removed. Good luck !!
Jun 02, 2006 | GE WSM2700D Top Load Stacked Washer /...
Frigidaire GLEQ2152ES Electric Dryer Logo
88 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
