Have jvc av-850 older,1998, model tv hooked up to dish box. will show dish picture for 1 second then screen will go to blue with rolling diagonal lines tried all in manual
  • 11,800 Answers
The vertical scanning unit inside the tv has lost the sync with the signal coming from the box. Most likely this has been caused by the aging of the components and all you will have to do is to compensate for that by changing (or adjusting, if possible) a resistor in the vertical oscillator.  It's a 10 minutes job if you know what to do. If you don't you can make the things very bad. Take the tv to a repair shop, they might fix it on the spot for a small fee.
Posted on Sep 12, 2010
My JVC model AV-20F476 has a black-out box that covers most of the bottom half of the screen.
Go into menu and under CLOSED CAPTIONS look to see if TEXT is engaged---if it is set to text 1 turn it off or to text 2,3,4, etc
Text was a feature never really used but it is there, some cable boxes also have this setting/feature.
Let me know if you have questions.
Jan 11, 2012 | JVC Televison & Video
I HAVE A MAGNAVOX TV MODEL 255102-OODD, A MOTOROLLA (VERIZON) SET TOP BOX MODEL QIP2400/1006 AND A JVC DVD MODEL DR-MV150BJ. I HAVE TRIED ALL THE HOOK-UPS SUGGESTED BY JVC AND STILL CONNOT GET A PICTURE. ...
ok, The issue will be in the sequence you have things connected. The connections sequence is going to be controlled by what connections are available. I assume the Set Top controller is connection to your Antennea connection on the TV. Your TV should be on channel 3 or 4. The next step depends on what type of connectors you are using for the JVC DVD. I have an Antennea output on mine so I connected them in series. If you don't have an Antennea output from teh DVD player you will need to connect the DVD using Audio/Video cables which means you will need to connect to the TV alternate Source connector and to watch DVD's you will need to change to that source. Much like you would switch between regular TV and VCR tape on a VCR player connected to the Antennea connector.
Sep 23, 2009 | Televison & Video
Need Help with tv problem
tiene que revisar la tarjeta de comvergencia
Aug 26, 2009 | JVC AV-48P575 48" Rear Projection...
Help
What video out put you connected between JVC player and TV ?
Look at back of your JVC player for Video out (yellow color) pin, hook RCA cable there and plug it to Input-1 or 2 in TV.
Now select AV 1 or 2 (what ever you hooked) in TV by remote and hopefully picture will in TV.
need further help, let me know model number of your TV.
Oct 11, 2008 | JVC TH-M45 System
JVC AV-36870- After watching for awhile, screen goes blue and sound squeals
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
Oct 14, 2017 | JVC AV-36890 36" TV
Blue Screen
I just wanted to suggest some things for you to try, if you have not done them already. Try hooking up a known good signal, such as the main input cable from your cable or dish, hook it straight to your tv, and see if you can change channels, and get a picture on low band...2 thru 6, and then if not, how about any picture above channel 6, if you get picture on 2 thru 13 now, it could be whatever you have hooked in between the input cable and the tv...be sure you have the tv on the right channel for your receiver, usually 3 or 4, or if you are using another type of video input cable, make sure you have tv on the right input for that cable and that cable is good...check the in and out of your component unit, for correct cable hookup as well as your cables, in reference to using RCA video and audio left and right in and out...a lot of sets and vcr's will go to a blue screen if they lose signal to them....I hope this helps you out some.If you cannot get a picture from hooking your signal straight to your tv, it could be the tuner got a spike from a thunderstorm, or has lost the B Plus source for the tuner circuit. Be sure that it is not selected for an input signal,other than the cable or antenna mode, the onscreen text should verify this, if you can change channels with or without getting video...a picture....Good luck with it. T.
Jan 15, 2008 | JVC AV-27S33 27" TV
Blue Screen
I don't have a solution, but wanting to know if you ever resolved your problem? I'm having the same issue with my JVC 32" model # AV-32D500.
thanks
Jan 12, 2008 | JVC AV-32D500 32" TV
JVC Screen problem
using your remote ,off the close caption. the black rectangular box that you see for the message but since you have message in the box. that why you see a rectangular black screen.
Jan 09, 2008 | JVC AV-32D305 32" TV
JVC AV-32F704 32" TV Picture is blurry - cannot read any writing on the screen
You didn't mention if you saw fine white diagonal lines running through the screen from top to bottom. If so, you likely have a shorted Picture Tube which is not usually fixable. If there are no lines seen running through the screen, then it is possible the High voltage transformer which also has a screen voltage and focus control built in that could be bad. I would expect the cost of that part to be about $100, so the repair cost total could approach that of a new set I would guess.
Apr 12, 2007 | JVC AV-32F704 32" TV
Hooking up external DVD player
if you tryed to hook up into another video input you also have to switch the inputs on the remote in the input menu from input 1 or 2 to the same.
May 27, 2006 | Toshiba MW20FM1 20 in. Combo
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
