Question about Samsung DV306LEW Electric Dryer
I need to know how to tighten the belt on a samsung dryer
  • Samsung Master
  • 43,501 Answers
The belt has a spring tensioner on it... if the belt is slipping then it needs to be replaced...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 12, 2010
  • 1,531 Answers
The belt has a self adjusting idler pully you can not adjust this to make the belt any tighter. just make sure the belt is properly attached.or replace the belt as needed
How do you tightening drive belt
The dryer has an auto tightener. You will need to replace the belt.
Dec 06, 2012 | Amana NDG5800 Gas Dryer
Help with dryer belt
There is a just nut on the smaller/larger wheel. loosen put belt on and tighten up. If you can't loosen the wheel you will have to lever it in. it will take some force, but i found that the back of two tablespoons help. let ne know please.
Jan 25, 2012 | Frigidaire FEX831CS Top Load Stacked...
I need to know how to put the belt on the pulley system of a samsung dryer DV209AEW
Hello, welcome to FixYa.
Based on your post, you have a Samsung dryer and the belt has come off.
I've seen this many, many times...though the belt usually doesn't break it just comes off. Very common for Samsung dryers for whatever reason.
**Unplug the unit before proceeding...safety first**...
The good news is if you can get to it from the back you can simply remove the small panel around the exhaust tube as shown here,
if it's not accessible from back you'll need to go from the front...that's do-able too, just a little more involved. Let me know.
Once in the back the belt should look like this when routed properly, with the "V" grooves towards the drum and motor pulley.
i.e.
Hope that moves you forward...or even better, fixed up.
Let me know what you find. I will try to help in any manner I can of course as well. Good luck.
Regards,
Macmarkus :)
Aug 26, 2011 | Samsung 7.3 Cu. Ft. Electric Dryer
Loose paddle
Pop the top ... remove the front ... carefully remove the belt ... take the drumout - you are correct, the paddles are held onwith screws - tighten them.
reassemble
Oct 19, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer belt replacement
put belt around drum then around motor pulley, then pull or push idler pulley so as to put belt over this pulley and release,this will tighten the belt,then manually hand rotate drum to self-align belt on pulleys and drum and put covers back on
Sep 04, 2009 | GE Profile Wizard DPSE592EAWW Electric...
Loose belt
No, you have an idler pulley which keep tension on the belt. You may have a problem with the idler pully or the belt may be worn or the drive pully slipping.
Jul 02, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Replacing belt, can't seem to get belt tight. Need to know how to wrap belt around pulleys.
You can find the belt routing for your Maytag here:
http://www.repair-help.com/kb/index.php?article=105
If it won't tension, perhaps you have the wrong belt. The correct belt can be purchased from your local source or this website.
For those of you with other Brands of dryers start here:
http://www.repair-help.com/kb/index.php?category=13
Note: After unplugging dryer; The belts for most regular dryers are accessed by removing the front panel.
Wash and Dry and put the clothes line away!
Apr 25, 2009 | Dryers
I have a Kenmore Series 80 dryer and the belt broke. The pulley came off and I don't know where it goes or how to put it back on. I also don't know the routing diagram for the new belt. Please help ASAP I...
it goes on the shaft of the electric motor the belt goes around the drum should be a set screw on pulley reattach to shaft tighten then looosen bracket on motor apply tension and tighten you may have to go to the hardware st ore and get another screw if yours is lost as a tip apply red loctite to the threads to prevent it from vibrating loose they have that at the hardware store or auto store
Jan 15, 2009 | Kenmore 62622 Electric Dryer
Asko Dryer won't spin...need to tighten belt
Does the Motor turn... We have had many motors with bad capacitors .. check the white capacitors for cracks or metal coming out of it...the motors will run with out a load on the but put a few clothes in the drum and they will just hummm..
Jul 19, 2008 | Asko T721 Electric Dryer
Fixing a gas dryer belt
That I believe is an older model GE with the idler bar instead of the short bar. I believe there is also a rear panel that you can remove to gain access to it. I dont remember for sure if it keeps tension up or down. Loop your belt around the motor pully, then find out which way it keeps tension on the belt, then loop the belt around the idler pully and release so that it keep tension on the belt itself. Let me know if you need further information.
Feb 06, 2008 | Dryers
Samsung DV306LEW Electric Dryer Logo
199 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
