Question about Gateway Computers & Internet
I have gateway laptop and the touch mouse has got hanged also all the icons have become large and streched what to do?
    Guru:
  • 277 Answers
Right click on the desktop and select properties
then in the properties select settings
change the screen resolution from 800 by 600 pixels to anything more than this figure. click apply and see that the icons will get small. for the touch mouse try reinstalling its driver. Go to control panel, then device manager. in that select touch pad or something like that and the option which will be inside the touchpad option, right click it and select update driver, while remaining connected online. this way it will search for the latest driver for the touchpad
Posted on Sep 13, 2010
Gateway HDMI laptop T series charger output 19 vgets v.hotbut works . burser pointer starts jumping frm place to place on screen dificult to control ?
run it in battery to see if fixes cursor problem
also try a different mouse see if that makes the cursor move correctly
this way you see if its the mouse or power supply
might also a touch pad problem anything that controls the cursor
May 07, 2015 | Gateway Computers & Internet
How do I get the pinch and zoom to work on Toshiba satelite
Open the "Control Panel" Then change from "Category" in the upper right of the screen to "Large icons". Then find the "Mouse" icon. From there you can change settings for everything related to your mouse.
Jul 23, 2014 | Toshiba Satellite Computers & Internet
Fix scrolling touch pad
Do you use Synaptics or a similar add-on for Windows? Then go to Start>Control Panel[Large/Small Icons]>Mouse>Last tab to right and double-click your touch pad in the upper list, and you will be presented with a plethora of settings for your touch pad. Scrolling should be one of them. Mack sure your desired options are checked, and click Apply or OK on that window to save those settings. Then click OK on the Mouse properties to exit.
Dec 13, 2013 | Gateway NE56R10u Laptop
How do I disable touch pad from Dell Latitude E5400
You may disable the touch-pad by following the steps mentioned below:
  1. Click Start and then Control Panel
  2. In Control Panel, click on the Mouse icon. Note: If the Control Panel is in Category View, under View by, click either Large icons or Small icons.
  3. In the Mouse Properties window, click on the Device Settings tab.
  4. In the Device Settings tab, click on the Settings button.
  5. Check or uncheck the checkbox next to Enable Tapping then click OK.
  6. On the Mouse Properties window, click Apply then OK.
Hope this helps..
Feb 20, 2011 | Dell Latitude E5400 Laptop
Gateway laptop mouse not responding
In the rows above your Function keys (F1-F12) you should see some icons above F7-F12 (these are capacitive touch keys). If you see one with a square with a hand pointing with a plus sign, and it's red, just touch it. It's a touch key to disable your touchpad.
Nov 01, 2009 | Gateway Computers & Internet
How to turn off mouse on laptop when using wireless mouse
Now depending on the model of your laptop, the procedure may defer. I will just show you the various basic ways available with most laptops.
1. Look around your touch pad (especially the area between it and the keypad). Some laptops have a button here that turns the touch pad (laptop mouse) on and off. If you see one just press it.
2. If you do not see this button. Then check your fn keys (They are usually labeled in a different colour, e.g. blue). Usually they are on the normal function keys. Look for the one that resemble a mouse figure. If you see it, you need to press it in combination with the Fn key; press the Fn key first. (The Fn key is usually near the Ctrl key). This will turn on and off your touch pad (laptop mouse).
Sep 13, 2009 | Gateway Computers & Internet
The icons on my monitor become large after a call
if your os is vista.go to desktop
press and hold control and now scrol your mouse
Jul 04, 2009 | HP Pavilion dv7-1132nr Notebook PC
Mouse moves on its own
Your palm might be brushing on the touch pad while you are typing that is probably why the cursor jumps to a different location. as for disabling the touch pad I think that it is not possible unless you install a synaptics driver for your laptops touch pad.
Apr 01, 2009 | Gateway Laptop Keyboard for MX6930,...
Shortage?
There is a ribbon cable between the laptop & the screen. It sounds like you have a short in that cable. If you're not good with tedius electronic repairs, it would be best to have a shop repair it.
Mar 25, 2009 | Gateway Computers & Internet
How to set up mouse pad so it works with touch
Check in the control panel under mouse. There should be a setting to enable tapping. If there is a touch pad icon on the bottom right of the screen you can also right click on that and select options.
Dec 31, 2008 | Gateway MT3705 Notebook
Computers & Internet Logo
49 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
