Conia 250 dvd player
I was silly and i tried messing around with the settings menu on my dvd player as a dvd i tried to play wasnt playing. I am not totally sure what i did but now nothing shows up on the screen at all. I remember the dvd asking me if my tv could handle the change and i said yes, that was my mistake. is there any way of resetting the player?
  • Sophiecharl May 20, 2008
    thank you, all fixed, my tv couldn't support the setting, i tried a better tv and the cord you suggested and was able to return it to its original setting
  • 28 Answers
You may have switched to progressive mode.
If you have your DVD player hooked up to your TV with anything other than composite video (single, yellow RCA cable), for example via component or HDMI, than disconnect that cable and use composite.
This may help, but only if that's really what you did, and if the DVD still sends the interlaced signal out over composite (which doesn't handle progressive).
Posted on May 14, 2008
I have a HD video file to burn to dvd. Need to know What compression function I can use , so I can use to burn and play on the Conia dvd player
Winrar compress it if it is too large to be loaded on a CD. You can compress to parts then extract the parts to he burned on a CD
for the burn cd you can download nero for free
May 07, 2015 | Conia Televison & Video
Every time I play Avatar in my samsung blu ray player bd-p1000 the screen on the dvd player says interactive but then it starts playing the opening credits and it wont go into menu mode, I can't do...
We have finally managed to get avatar to play!!!!! We had the same problem. Frustrating I know - but after returning the DVD back to the shop three times, trying updating previously, then waiting for another update from Samsung from Sept (they have not provided a further update) - we are feeling jubilant!
We copied the firmware to a CD disc once again. It did not initally look as if it was loading but if you wait you are asked if you if you want to upgrade eventually. Once you affirm - it takes a good five to ten minutes to process the firmware/ upgrade. It tells you when it has completed. We discovered by chance that you need to then switch off the player and switch back on again for the update to become functional.
Initally we still could not get AVATAR to load as far as the menu screen. We tried newer Blue Ray DVDs purchased December that previously would not play - and now do! To get AVATAR to play we switched off & on the blue ray player with the disc still loaded a couple of times and each time we got a little further towards the functioning menu screen.
A lot of messing around, so be sure you have the time available to persevere!
Dec 09, 2010 | Samsung BD-P1000
Will not play DVD, makes rubbing noise when DVD goes around, then says cannot play this disc
If it has a paper label on it That can cause the rubbing sound. Is it only this one DVD or will non play? Try using a cleaning disk to remove mess from the laser eye, as well as cleaning this problem disk with a suitable disk cleaning kit
remove any paper labels if it is possible
Please rate my help++++Thanks for uisng FIXYA
Jun 11, 2010 | Sony DVP-NS715P DVD Player
This is a silly question, but our JVC DVD Player started playing only in Black/White, so I went into the Display menu trying to fix that problem, and instead mistakenly changed the resolution of the screen...
if you have a modern tv you could change the format (pal, ntsc) on the tv and then on the dvd. I have set my dvd player and tv to auto, they are both newer models.
Jan 05, 2010 | Televison & Video
Audiologic DVD-108, music plays, cannot hear regular conversation
This sounds like a setting on your DVD player in its menu settings. You could try a couple of things, first being to unplug it for a couple of moments (5-10 minutes) or going through your menu on the DVD player with the remote or the front of the player. I assume that all of your DVDs have this problem.
Jun 09, 2009 | Audiologic DVCR-251
Will not play rented DVD's
This may sound silly, but have you tried a DVD lens cleaner?
Oct 18, 2008 | Bose Lifestyle 28 System
Conia plasma 42inch connecting to macbook pro - ??
Hi, i also have a conia plasma (and sony 510 amp). Which video connection are you using? DVI-VGA? DVI-component? Note that the tv probably defaults to using YPBR rather than VGA so you may need to play with settings in the menu ...
Aug 12, 2008 | Sony STR-DG510 Receiver
Dvd only playing in black and white
Make sure that you connect all of these connections to the right colored cables.
It seems like you only have the green cable connected. Go back and connect the red and blue for both the tv and dvd.
Aug 06, 2008 | Sony DVP-S500D DVD Player
RCA RC5215P DVD Player only plays in black & white
Dear brother at first u insert a original copy righted disk and check .And there is an option for swithing in menu for PAL and NTSC.And also please check ur TV is supported NTSC3.15 colour system,If not check ur player in a multi system TV.
Dear brother if u r a technician please can u mail me the IC number of IC104 in signal board under the lense mechanism in the same RCA RC5215P DVD player,becouse I have missed this IC from my player
Jul 15, 2007 | RCA RC5215P DVD Player
Conia dvd player problem
Dale, Have you tryed yet to clean the lens surface on the dvd player yet ?? A small build-up of film or dust can make a cd/dvd player's tracking ability to go downhill quit fast. The lens Im talking about it on the Laser Pick-Up assy. Us an approved cleaning disc to do this or take off the top cover and take a small q-tip with just damped with alcohol. Very carefully clean the surface in a circular motion and let dry then clean again with a dry q-tip to get off anything lefyt on the lens. Now for the disc. Those small scratchs can be gotten rid of with a disc resurfacer. The disc resurfacer will work on very minor and shallow scratchs. you can only get rid of them if you dont see any dark inside the scratch or you can barley feel the scratch with your thumb nail. If the cleaning dosent assist you then the unit will neeed a tracing/focus alighnment and thi is something you cannot do unles you have an alighnment/service manual and the proper equipment-ie scope & alighnment disc's. Good Luck
May 02, 2006 | Conia DVD8500 DVD Player
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
Electro Med Services...
