Question about Sunkist Commercial Citrus Juicer
Need help dismantling a Sunkist juicer to replace a part. I need to replace the bottom piece of the bowl/spout assembly. Took out all the screws but the middle piece will not release to take of the bottom. This is a vintage Sunkist juicer.
My juicer leaks under the spout. I can not figure out why. I have checked all the assembly and all the directions. It is only the second time I have used this. My machine is brand new. Any though
The spout, itself is hinged. It has two positions, an upper and a lower position. (Similar to a light switch). Make sure it is in it's lowest position when making juice, otherwise the liquid will collect in the inner bowl and leak out the sides of the juicer. Move the spout to the upper position to temporarily stop the flow of juice, such as when you change glasses or receptacles. Then, put the spout in the lower position to resume the flow of juice.
Dec 26, 2012 | Jack Lalanne Power Juicer 250 Watts
Dash juicer wont turn on
Just fixed this problem!
Take bottom off juicer. The 4th screw is an "odd" one...I drilled the center out and used a flat head.
When you look up inside the juicer, you will see a silver lever arm. It touches the arm lock mechanism (so the juicer will only run when the arm is engaged).
The lever arm should be behind the black lever arm part on the side. When I opened mine up, the silver level arm was on top of the black post thingy. I took a screwdriver and pushed it off the black post thingy, so it the very bottom of the silver lever is behind it. (I can no longer see the entire silver lever easily when it is in the correct position.)
Totally fixed it.
I think it bounced out of the correct spot when I juiced some hard veggies or when I moved it, it hit the counter pretty hard.
Anyway, good luck....I am not a mechanic so sorry if the language is non-technical.
Oct 05, 2012 | Juicers
I am taking my juicer apart. I took the three screws out and the grinder plate. How do I get the filter out that is beneath the grinder plate.
Don't take the screws out! That plate is not meant to come off.
The filter unit is removed from the base by unscrewing it counterclockwise using the two holes in the plate that you unscrewed. The juicer originally came with a plastic tool with two prongs that fit in the holes and acted like a sort of handle you could use to unscrew the assembly.
If you don't have the tool, you can use two small screw drivers or jury-rig a tool out of a piece of coat hanger shaped into a U to gain leverage to dismount the entire filter/blade assembly for washing.
Hope this helps!
Mar 03, 2011 | Jack Lalanne Power Juicer 250 Watts
Spout
Try this site for the juicer part you need ..
https://www.unitycart.com/pjss/accessories/parts_elite.asp
Please vote !!
May 12, 2010 | Jack Lalanne Power Juicer 250 Watts
I have a Jack Lalanne Power Juicer. The top piece
I am also looking for the same part. I have been unsucessful so far.
May 07, 2009 | Jack Lalanne Power Juicer 250 Watts
No power. Thanx for help.
Cha-Ching. Finally. I could not sit still until tomorrow to call customer service. For a moment I thought my power juicer motor was shot. :( I was a bit sad. I patiently took apart all of the screw to realized that I only need to unscrew 3 screws on the bottom to get to the motor. Once the bottom part is open I see that one of the cables are loose and just reattached it. It is very simple wiring inside. There is only 3 cable and 3 attachment spot inside...so pretty simple. :) Happy again and Juicing :)
Apr 21, 2009 | Jack Lalanne Power Juicer (Stainless...
Breville JE95XL juicer
I used needle nose pliers, it took a bit of patience but I got the screws out. I think I might replace them with regular screws. My juicer does not run either. Let me know if you find the problem with yours.
Dec 26, 2008 | Breville JE95XL Juicer
The pulp collection receptacle has a tiny clear plastic button on the bottom. If this has broken off (it happens often) the machine won't turn on. The button must be present to depress the safety switch at the bottom of the machine. If everything else is properly assembled and the machine won't turn on, this is probably the cause. Check the bottom of the pulp collection receptacle to see if the button has broken off. (picture #2) If so, replace it with a piece of pasta or a tiny piece of wood. Sounds silly, but it works. The safety switch at the bottom of the machine must be depressed before the machine will run.
Nov 04, 2008 | Jack Lalanne Power Juicer 250 Watts
Rotel Juicer
Once the handle has been pushed aside, it is easy to dismantle down to the perforated bowl. This is a push fir onto the black plastic boss and should wriggle off quite easily for cleaning.
Jun 03, 2008 | Juicers
Sunkist Commercial Citrus Juicer Logo
Top Sunkist Juicers Experts
Tom Chichester
David Payne
David Payne
Are you a Sunkist Juicer Expert? Answer questions, earn points and help others
