Question about Bushnell "Insta-Focus" Binoculars
How do I treat the rubber of my Binocular that went sticky, to restore it?
Where can I get new rubber eyecups
There are a number of vendors who sell them, with varying degrees of match, depending on your model of binocular. Some spots include B&H Photo, Amazon, and EBay.
Good Luck!
Binocular Eyepiece Accessories
Amazon com binocular eyecups Camera Photo Electronics Binocular Eye Cups eBay
Oct 24, 2015 | Optics
Where can I get new soft rubber eyepiece covers?
There are a number of vendors who sell them, with varying degrees of match, depending on your model of binocular. Some spots include B&H Photo (
Binocular Eyepiece Accessories ) Amazon (
Amazon com binocular eyecups Camera Photo Electronics ), or eBay (
Binocular Eye Cups eBay )
Good Luck!
Sep 13, 2015 | Optics
Citroen C5 Exclusive V6 2001. The dash has gone sticky. Even strong solvent will not remove the stickiness. Has anyone else had this problem and solved it please?
If there has been any form of dash cleaner used or preservative used (armoral etc) other than that recommended you have a break down in the plastic material used in the dash. Take the car to an upholsterer /restorer for an opinion but I think the answer will be to have the dash restored
Mar 02, 2014 | Citroen C5 Cars & Trucks
Sticky interior parts
If you are talking about the plastic parts around the center console, they are sticky most likely because of the heat of the sun and the effect it has on the rubber coated plastics. The only way to correct this is to buy all new parts from Ferrari.
Feb 27, 2011 | Interior for Ferrari 355
The rubbers on the eye pieces are deteriorated are they available anywhere
You'll need to measure your eyepiece in "mm". Also determine if your eyepiece has an outer ring the eyepiece will slip over. You can find eyecups/guards on Ebay. Search under Binocular Eyecup or Binocular Eye Guard. There are also eyecups under "rubber eyecups/rubber eyeguards" but alot of these are for Microscopes and may not fit. You will need to pay close attention to the mounting type and measurements.
Sep 22, 2009 | Tasco Off Shore OS21 (7x50MM) Binocular
Replacement parts for Tasco binoculars
Sep 18, 2009 | Tasco Wide Angle and Rubber 2023 (10x50MM)...
I have Vivitar binoculars where the outer rubber surface of the body has become "sticky".  I can't tell you why, as they are kept in my air-conditioned office. I don't see any reason why Vivitar...
walmart sells vivitar,why not contact them for a source to replace them, sounds like vivitar is more of a toy than a quality binocular though. sounds like a sticky situation to me....good luck...larry@reichinstruments.com
Dec 17, 2008 | Optics
The rubber armoring is "melting" or getting all sticky
It can be easily resolve, just go to the youtude, check for sticky melting solution. The sticky surface can be treated and back to normal.
Dec 11, 2008 | Bushnell Optics
Rubber coating breaking down
Try it with rubbing alcohol first - just keep it away from the optics, and you may get lucky. The only thing that ever seems to work with these is an abrasive cream cleaner (jif/cif or similar) - you just have to use lots of cream and be careful not to polish the optics - unfortunately the stickiness will come back quicker than before though. I haven't tried myself, but i have heard that once you have carried out the cream cleaner routine, you can paint the unit - ask your hardware shop what sort of rubbery paints they have - ideally oil based and not acrylic. It wont last as long as the original finish or like quite as good, but it should stop the stickiness for a while at least. Try and keep your binoculars out of the sun - most of the stickiness is either caused by that, or contact with a damaging chemical such as most insect repellents, or petroleum products. Hope this helps :)
Aug 08, 2006 | Sigma Elite 8x22 Binocular
Optics Logo
116 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
