Question about Alps MD 5000 Thermal Printer
Help with aligning cartridge
I have an ALPS MD-500, when it powers up you will hear the carriage move but does not pick up any cartridges. then the error ( orange ) light comes on. If you push the reset button it will cycle but only repeat the same process. Is this a mis-alignment problem or a mechanical problem?
  • 58 Answers
You may need to clean the sensors - it sounds like it's not detecting the presence of any cartridges
Posted on May 20, 2008
Alps MD1000 printer won't do anything.
Do you get the green ready light when you first turn on the printer?
Nov 05, 2012 | Alps MD 1000 Thermal Printer
How do i put new ink cartridge in
The printer must be ON. Open the Front Access Door of the Printer. You should see a Carriage ( the part that holds the cartridges ) move from left to right. Wait for the Carriage to Stop ( usually in center ).
Open the packaging tape from the cartridge and slide the cartridge inside the Cartridge slot. Insert the cartridge from below and Push the cartridge upwards to snap. You will hear the snap sound.
Close the front access door and wait for the Cartridges to be aligned. After the printer has printed alignment sheet, Place it face down on the Scanner glass and press OK button.
The alignment will be complete.
Dec 02, 2011 | HP Deskjet F4140 All-In-One InkJet Printer
Cartridge appears jammed
There was a discussion of this issue on the ALPS yahoo group. It's a great resource.
Nov 12, 2011 | Alps MD 5000 Thermal Printer
My alps 1000 will not pick up cartrage, head goes back and forth, paper feeds, then goest into error mode
Try cleaning the cartridge carrier sensor. This tells the carrier where to stop to pick up the differnt cartridges They can get dusty with time which can cause a failure.
Nov 19, 2010 | Alps MD 1000 Thermal Printer
I have an alps 5000 that won't pick up the ribbon cartridges?
It could be a serious error with the cartridge changer. Take a close look at the chagner for anything that looks bent or mis-aligned. Also, may sure all of the positioning sensors are clean.
Mar 26, 2010 | Alps MD 5000 Thermal Printer
We have Alps MD 1000 which makes a grinding noise when we power it up, and then the error light comes on. Is this normal, or is what could be the problem? Where would we need to send it for repairs?...
All ALPS printers make noise when they are turned on. The error light is not normal. Do you have cartridges in the printer? there are two kinds: ones with gray plastic cassettes and ones with dark blue plastic cassettes. For the 1000, you want the gray ones. Are the cartridges installed correctly? Side B should be facing up.
Feb 06, 2010 | Alps MD 1000 Thermal Printer
Check the cartridge carrier for bent pins. Clean the bar code reader on the carrier with a cotton swab and alcohol. This sensor locates the position of the cartridges.
Aug 12, 2009 | Alps MD 1000 Thermal Printer
Alps MD 5000
When you moved, did you secure the print head and remove the ink cartrdiges? A Changer Error message is bad. Check the changer for any broken or bent parts.
Sep 06, 2008 | Alps MD 1000 Thermal Printer
Alps MD 5000
Did you pack the printer correctly before moving? When you got the printer, it would have had a packing piece preventing any carriage movement. If you did not put this in place before packing the printer for the move, you have most likely damaged the printer beyond repair.
May 22, 2008 | Alps MD 5000 Thermal Printer
RECYCLING of ALPS MD-1000 Color Printer
You can buy OKI MD 5000 Cartridges or Citizen Printiva Cartridges. Are the same.
There are also resellers that sells only ribbons to exchange in cartridges.
Dec 16, 2007 | Alps MD 1000 Thermal Printer
Alps MD 5000 Thermal Printer Logo
192 people viewed this question
Top Alps Office Equipment & Supplies Experts
Jesse Walters
Jesse Walters
Samuel Konger
Samuel Konger
Are you an Alps Office Equipment and Supply Expert? Answer questions, earn points and help others
