Question about HP PSC 2175 All-In-One InkJet Printer
Have a HP psc 2174 all in one printer and when i turn it on, on the main window it comes up firstly as initializing and then all three main buttons continually flash and it says remove and check cartridge which i do and put them back and then it says it again what has happened?
Junoon007
  • 1011 Answers
SOURCE: checl print cartridges light flashing
Hello sir,
It's not a problem... please check the advanced setting. Or better reinstall the Printer Driver. And in the tray bar u show the print status or some icon of printer. u just right click and check the all settings. After that it will be flashing means u just leave that bec. it not a problem at all. ok
Good luck
Don't forget to comment
Posted on Feb 24, 2008
  • 19 Answers
SOURCE: Error Message - PSC 1310 All-in-One
Sorry I posted the solution as a clarification request please allow me to re-post:
Here is what HP has to say about this issue:
This Link. Will take you to the site.
-Hope this helps.
Posted on May 27, 2008
SOURCE: HP printer PSC 1410 ALL in one printer showing "Check print cartridge" error
please let me know what is rail and carriage bushings ?
Posted on Jul 09, 2008
rakeshpramod
  • 234 Answers
SOURCE: hp psc 2210 all-in-one printer
Try the steps in the following link
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00042820&dlc=en&product=79499
Posted on Aug 28, 2008
  • 685 Answers
SOURCE: CHECK PRINTER CARTRIDGE LIGHT CONTINYES TO FLASH
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00094661&dlc=en&product=374568
Anything on that page help? Not sure what you've already tried.
Posted on Sep 26, 2008
Error 68.2 permanent storage write How do you fix the error?
all you have to do is initialize hard disk even if you do not have one. Just turn off the printer. Turn the printer back on and when the memory starts to count hold down the menu key until all three lights come on. When all three lights are on solid release the menu button and press the arrow back button and initialize disk should appear in the menu. Just hit the check mark button again and it should take care of the problem
Feb 16, 2011 | HP LaserJet P4014n Printer
I do not know how to install my HP PSC 2410xi model in my windows 7 OS laptop. I tried the windows update but it does not have the PSC 2000 series, it only has PSC 2100 and up. I tried installing the PSC...
Following are some of the tips, which you must follow while you are using a printer with Windows 7 system.
Ensure that the cables are properly connected; you need to ensure that your printer is properly connected, and plugged in, and also the cable is accurately connected to the computer as well.
Check the power; make sure that the printer's power is switched on, ensure that all the computer necessary computer components are also turned on.
Make sure that the hardware is properly plugged in, and also turned on. Apply troubleshooting.
A troubleshooter is a tool, which is generated automatically and which can easily fix the problems that occur with your system.
Thus, if you are coming across different issues related to your printer, then you can consult the troubleshooter.
You require driver applications to run your hardware devices.
Make sure that the drivers are not outdated, corrupt, or incompatible, resulting in disrupting the communication between the printer and the computer.
Always make sure that you are making use of the most recent and latest device drivers, and also that are compatible with your system requirements and specifications, as this can be extremely useful in resolving printer issues.
Jan 07, 2011 | HP PSC 2410 All-In-One InkJet Printer
Hp psc 1210 printer driver is not installed sucessfully in window 7 64 bit
When you connected the product to the computer with a USB cable, the Windows Update installation failed. Solution You can manually install the driver. Make sure you follow the steps in the order given to reset your printer, remove the product, restart your computer, and then manually install the driver. Step one: Turn the printer off and then on
  1. Disconnect the USB cable from the printer.
  2. Turn the printer off and then back on. Clear any blinking lights or error messages.
Step two: Remove the product from Devices and Printers
  1. Click the Windows icon (c01319360.gif ), and then click Devices and Printers .
  2. Right-click the product icon (c01813941.gif ) representing your HP product, and then click Remove device . Follow the on-screen instructions to complete the process. (If the product is not listed, skip to Step three: Restart your computer.)
  3. If multiple icons exist for the product, remove them all.
  1. Restart your computer. You might want to bookmark this page so that you can quickly return to it.
  2. Make sure your computer has a valid Internet connection by opening a web browser and surfing to an Internet site.
Step four: Manually install the driver
  1. Make sure that the USB cable is not connected to the product. If the USB cable is connected to the product, disconnect it.
  2. From the Windows taskbar, click the Windows icon (c01319360.gif ), and then click Devices and Printers . The Devices and Printers window opens.
  3. Click Add a printer . The Add Printer window opens.
  4. Click Add a local printer .
  5. Click Use an existing port .
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port) , and then click Next .
  7. Click the Windows Update button and wait for the updates to complete.
  8. In the Install the printer driver window, under Manufacturer click HP , and then search for your driver under Printers . If the driver does not show up under HP, try looking under Hewlett Packard. NOTE: The print drivers are displayed by their series names, which means the last one or two numbers may show as zeroes. For instance, the HP Photosmart 8750 displays as HP Photosmart 8700, and the PSC 1210 displays as the PSC 1200 series.
  9. Once you find the appropriate driver, plug the USB cable back into the printer.
  10. The Installing Device Driver Software window should briefly display in the bottom right corner of the computer screen. Wait for it to disappear.
  11. Click the Cancel button on the Add Printer window.
  12. The newly installed printer now shows in the Devices and Printers window.
Jan 05, 2011 | HP PSC 1210 All-In-One InkJet Printer
Hp psc 2179 all-in-one printer
Using the instructions found here
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00553775&dlc=en&product=90809
I opened the scanner and found that the cold-cathode lamp is failing. Moving the optical assembly away from its home position (to the middle of the scanner) allows the unit to initialize so at least the printer works.
I'll investigate availability of replacement lamps.
BG
Feb 15, 2009 | HP PSC 2175 All-In-One InkJet Printer
Hp psc 950 initializing
press and hold enter and setup at the same time and then release.
Dec 05, 2008 | HP PSC 950 All-In-One InkJet Printer
Printer
i cNNOT FIND THE HPPSC1510DRIVER WHEN I DONLOADED THE C240 IS COMING WHY
Sep 15, 2008 | HP PSC 1510 All-In-One InkJet Printer
Cannot run printer...stuck on Initializing
hi,
please go through the following link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01330821&cc=us&lc=en&dlc=en&product=390328
thanks and regards
agnel
Jul 15, 2008 | HP PSC 1610v All-in-One Printer
Hp psc 1510 scanning difficulty
After upgrading the driver as above suggested, try initiating the scan by using the printer software. You can prescan and scan from that window. Another program may have disabled the manual buttons
Mar 08, 2008 | HP PSC 1510 All-In-One InkJet Printer
Keeps printing test sheet
I just had the same problem after putting in a new black cart. Try this:
  • Open HP Director
  • On the main window select Settings>Print Settings>Printer Toolbox
  • Open the Configuration Tab
  • At bottom right click "Factory Settings" button then "Apply"
A configuration warning popped up explaining that 'd be changing settings used by the driver. I clicked ok. AOK. (I did do an alignment just before this, but it's probably not required to fix the prob.
Jan 09, 2008 | HP PSC 1350 All-In-One Thermal Printer
HP PSC 2175 All-In-One InkJet Printer Logo
54 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
