Question about Abit VI7 Motherboard
I have a ABIT-V17 Motherboard with intel pentium 4 CPU and 1GB\RAM.. and Windows 7 Ultimate OS... I was doing a system cleaning when I removed the power cord and turned off the power I started taking my components out to clean them... I took out my processor and everything else then took out the motherboard. I cleaned everything off with a paper towel and then vacuumed out all dust from the system frame... I put everything back into the computer wrote every thing and where it went then I started it up and i got to Windows 7 Ultimate login screen and logged on right as it was showing my "Welcome!" it showed a BSOD it was because of Hardware Failure... So I thought its normal because after something like that it would be slow for the first time so I started it up again and it didn't even get past the intel branding screen... so I restarted the computer and it didn't do anything it just sat there with nothing on the screen... I took out the processor and realized it was ice cold. and I have been trying to figure this whole thing out I double checked everything and reset the CMOS and now I decided I need Professional Help with this problem... Please Help with this situation
    Top Expert:
  • Abit Master
  • 12,962 Answers
U indicated that you were able to get into the bios. Strange that all you did was dis assembly the PC, put it back together the same way, and now it does not work. Assuming you put everything back the exact same way it should work. Make sure that all of your connections are good and tight. Also check to see if the PS is working or connected properly. Try disconnecting all components except the memory and monitor and boot. If it works to a screen turn it off and start hooking up other peripherals one by one till you get no video or it stops working.
A bad peripheral can often disrupt a normal boot up process and cause all sorts of mayhem.. Check them all out.
And make SURE that your memory chips are in there properly!!!!!!!!!!!!!!!!!!!!
Posted on Mar 03, 2017
2 Suggested Answers
  • 4044 Answers
SOURCE: I installed everything the CPU, RAM, and
ok, looking at the specifications All I can recommend is the following. double check the Video card to make sure it is properly seated and that it does not exceed the capabilities of the motherboard. 2 Disconnect everything from the motherboard except the CPU and case wiring/power supply and turn the computer on. If the system completes the post test, you will hear at least 1 beep and should hear several for the video card not being connected, then start installing components 1 at a time till you find the one causing the problem. Start with the Video card and then the ram as these are most likely where your problem is unless you have a faulty power supply which will be the problem if you don't get a completed post with nothing else connected.
Posted on Jun 18, 2010
Intel r pentium r 4 cpu 1.80ghz driver download free
try this link Home Drivers Manufacturers Device Types DriverScan Search Contacts Search Driver Name
Newest Drivers:
OPTi Audio 16 OPTi Audio 16 High Definition Audio-Ger?₪t Broadcom NetLink (TM) Fast Ethernet Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C8 MORE ... Top Manufactures
Click here to view more
Intel Dell HP Sony ASUS Top Device Type
Network Sound Card Webcam Printers Modem Useful Links
Drivers ' Microsoft
Intel(R) Pentium(R) 4 CPU 1.80GHz
Driver Information Old drivers impact system performance and make your PC and hardware vulnerable to errors and crashes. We suggest you to download the latest drivers. Keep your Intel(R) Pentium(R) 4 CPU 1.80GHz driver upto date to maximize its performance, fixing any error related to driver. Download Now (1MB)
Intel(R) Pentium(R) 4 CPU 1.80GHz is a windows driver. It's released by Microsoft Type: Processor
Version: 5.1.2600.0
Date: 2004-04-01
Hardware IDs: ACPI\GenuineIntel_-_x86_Family_15_Model_1
Compatible IDs: ACPI\Processor
The following operating system has used this driver: Microsoft Windows XP Professional
Microsoft Windows XP Home Edition
Microsoft Windows 7 Ultimate
Microsoft Windows 7 Professional
Microsoft Windows XP Professionnel
Microsoft Windows Vista?™ Ultimate
Syst?©m Microsoft Windows XP Prof
This download is valid for the product(s) listed below:
Nov 22, 2012 | Intel Computers & Internet
Can 1gb ram supports tally software with atom processor
System Requirements
  • Recommended Hardware Requirements for Tally 9
  • Pentium 4 and above or equivalent
  • 256 MB RAM
  • Minimum Disk Space: 40 MB
  • Operating System Software: Microsoft Windows 98/ME/NT/2000/XP
Hence, your system would definately support Tally.
Hope it helps! Good Luck!
Mar 19, 2011 | Samsung Netbook / Intel Atom Processor /...
What procesors 64 bit will work with Abit IL9 Pro Motherboard Thanks Andy
The Core 2 Duo, Pentium 4, Pentium D will all work in the Abit IL9 Pro Motherboard.
Mar 05, 2011 | Abit IL9 Pro Motherboard
Can the Dell Latitude D610 run any of the following games: Age of Conan Star Trek Online Champions Online Aion
Check your system if it meets the following requirements
Age of Conan
OS: Windows Vista/XP
Processor: 3GHz Pentium IV
Video Card: Shader Model 2.0 and 128MB RAM: NVIDIA GeForce 5800 or ATI 9800
Processor: Intel Core 2 Duo 2.4 GHz (E6600) or better
Video Card: NVIDIA GeForce 7950GX2 or better
RAM: 2GB or more
Enhanced for: DirectX 10, 64-bit processors, multi-core
Supports Parental Controls on Windows Vista
Start Trek
System Requirements
  • OS: Windows XP SP2 / Windows Vista / Windows 7 (32 or 64-bit)
  • CPU: Intel Core 2 Duo 1.8 Ghz or AMD Athlon X2 3800+
  • Memory: 1GB RAM
  • Video: NVIDIA GeForce 7950 / ATI Radeon X1800 / Intel HD Graphics
  • Sound: DirectX 9.0c Compatible Soundcard
  • DirectX: Version 9.0c or Higher
  • HDD: 8GB Free Disk Space
  • Network: Internet Broadband Connection Required
  • Disc: 6X DVD-ROM
Recommended System Configuration
  • CPU: Intel E8400 Core 2 Duo or AMD Athlon X2 5600+
  • Memory: 2GB RAM+
  • Video: NVIDIA GeForce 8800 / ATI Radeon HD 3850+
  • Disc: 6X DVD-ROM
To check your system hardware> click on start>all programs>accessories>system tools> system information.
Thanks for using Fixya
Mar 27, 2010 | Dell Latitude D610 Notebook
Computer Information Manufacturer: JETWAY Model: System Information Chipset: Intel 945G/GZ/P/PL Express Memory Controller Hub PCI standard host CPU bridge Motherboard: LakePort CPU: Intel(R)...
U may always refer to it motherboard to get to know the supported hardware that plug to it. Since u are mention about Intel 945G/GZ/P/PL family motherboard, each type of the motherboard (type G, GZ, P, PL) have their own specification, but the same thing is their are design to support Intel Core 2 Duo. Pentium D or Pentium 4 processor. And all can support DDR2 memory. Here you can refer to the manual of the motherboard for more details e.g. pg17 (availability 2009Nov16):
YBC (/)
Nov 14, 2009 | Intel Computers & Internet
Graphic driver
Apr 29, 2009 | Intel D845GVSR Motherboard
Maximum HARDDISK CAPACITY FOR Intel 865GV motherboard
Yes, your board will support 320gb. I am not aware of a limit to how many gigabytes you can have per computer. I currently have 1.5 terabytes. 1500gb.
Apr 22, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Abit VI7 Motherboard Logo
110 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
