Question about Riccar 8955 Upright Vacuum
Where is the belt located? - Riccar 8955 Upright Vacuum
  • 377 Answers
The "belt" is normally the drive device that turns the beater brush found on the bottom front of the vacuum. Its purpose is to beat the rug and cause dirt and debris to rise up from the carpeting and be sucked into the vacuum. If the belt is missing, you may not see it. If the belt is in place, it will loop around the beater brush and back to a drive motor. Since belts can break on a regular basis any covers over it should be easy to remove via small slide levers or at most by removing a few screws from the bottom of the vacuum. The new belt must be attached properly in order for the brush to move in the correct direction. If you are going to replace the belt it is probably a good time to clean the beater brush and lubricate the end pieces of the brush with some WD40 as well.
Posted on Sep 12, 2010
Kirby heritage 2 How to put the belt on. I'm having a problem getting the belt on the rod
The belt goes around the brushroll before you install the brushroll in the nozzle compartment, you must then twist the belt lifter casting which will rotate the belt lifter hook to lift the belt into the proper location to allow you to install the nozzle compartment on the vacuum. Then rotate the belt lifter casting to release the belt onto the motor shaft.
Sep 14, 2017 | Kirby Vacuums
Where is belt for ul70120 found
Hi there! The belt for the Uh70120 can be purchased from Hoover.com directly or from an authorized service center. This unit takes belt number 562932001. Below you will find a link where you may go to purchase the belt, as well as a link to our service center locator.
http://bit.ly/1lzmUv1
Service Center Locator
Hope this helps!
Aug 12, 2014 | Hoover Vacuums
I pugged the dirtdevil 087800 to do some cleaning and it started smelling like there a burn wire
If it's been over six months since belt replaced start there first. Belts may look ok and brush might spin but when sweeping the belt will slip on the brush roll.
Dec 30, 2013 | Dirt Devil Vacuums
Belt
Look underneath where the brush roller is located. The brush roller is removed to replace the belt. The new belt is installed on the motor shaft and the brush roller then the brush roller is reinstalled
Jul 27, 2013 | Eureka Whirlwind 4481 Upright Vacuum
The bristles will not spin.
See if the belt (that drives the bristles) if is loose or need replacement.The belts are located either on the left or right side of the bristle brush(you can locate it by putting the vacuum upright and see under the brushes). If it is loose or broken replace it(walmart has replacements for it or any hardware store)just bring the belt for the replacement number written on the belt,or know the brand and model number.
Nov 19, 2010 | Bissell 3522 PowerForce Bagged Upright...
Vacuum has burning smell like a belt but cant figure out how to tear apart
First job is unscrew the 3 retainers (arrowed) they turn a quarter turn.
If your belt hasn't snapped it will need pulling off the motor shaft
The brushbar can now be pulled out (this brushroll had a groove scored into the side of it caused by a hair grip its visible just to the left of my thumb)
With the new belt positioned on the new brushroll insert it into the hole and locate brushroll
(To make the belt easier to locate on the motor shaft give it a bit of a stretch)
Ensure these lugs are located correctly
Pull the belt over the motor shaft
Refit the soleplate cover and tighten three screws
Before switching the machine back on rotate the brushroll to make sure the belt hasn't been trapped between the soleplate.
I hope this helps and good luck!
Nov 11, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Self propulsion doesn't work on my upright. Vacuum works fine otherwise
You will need to look @ your owners manual to see where the self propell belt is located i am sure yours is broke and need to replace,- it will not be hard to replace-Lance
Oct 21, 2009 | Hoover Vacuums
Where is the belt located, and how do i get to it
THE BELT IS LOCATED UNDER THE BRUSH COVER TURN VACUME UPSIDE DOWN AND THERE SHOULD BE SOME SCREWS THAT HOLD THE COVER ON REMOVE THE SCREWS AND YOU CAN REMOVE THE COVER WHERE THE BELT IS LOCATED
Sep 16, 2009 | Dirt Devil Vacuums
Nobody seems to be able to answer the question on how to change the belt on a bissell steam cleaner ..... Bissell is horrible for never giving customers proper instruction manuels .... THUMBS DOWN FOR...
i have the same prob. this is what i found
Since changing the belt is the easiest fix, we suggest you check that first. (Before attempting any repair be sure your machine is unplugged from the electrical outlet). Most Proheat models have two belts; a cogged belt that turns the brush roll, and a flat belt that turns the pump. If the pump belt is stretched or broken it needs to be replaced. The pump and belts are located in the front of the machine on the operator’s left. Turn the machine over and you’ll see a red retainer with 2 screws. Remove the retainer to gain access to the pump and belts. While you’re there check the red pump pulley, it’s where the two belts are. If that pulley is broken or loose you’ll have to replace the whole pump, the pulley is not available separate.
on your housing you will see a plastic cover adout 4 inches long remove this piece and you should see where your pump belt goes. flip your steamer over and remove the little red retainer that sits by the belt you have located. at this point you can take your brushroll out and slip the pump belt over the pump and onto your motor. then reassemble.
Jan 12, 2009 | Bissell 1699 ProHeat Clear View Upright...
Belt is burning?
is the brush turning?  remove any debris that is keeping it from rotating.  It does sound like the belt is burning because the motor is trying to turn it and the brush/sweeper is jammed.
Oct 16, 2007 | Eureka 2996AVZ Bagless Upright Vacuum
Riccar 8955 Upright Vacuum Logo
63 people viewed this question
Top Riccar Vacuums Experts
Chris Nomland
Chris Nomland
Jim Parker
Jim Parker
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
