Question about mares Pneumatic Spear Gun Hand Loader with Metal Insert
Is there any kind of loading assist to help **** a banded speargun I lack the strength to pull the last few inches
The tires on my shop fox 19 inch w 1729 come apart after a few months
There's a possibility that your tires do not last longer. The issue might there might be the quality of the tire or how you installed them . I recommend you to use urethane tires . Urethane doesn't need gluing but lasts longer . I purchase my tires with www.bandsawparts.com and you may want to read this blog http://bandsawblog.com/160/ . Hope that helps.
Jan 05, 2013 | Shop Fox W1729 19-Inch Bandsaw
I have trouble replacing the blade on my Porter and cable band saw plese help!
I might be able to help you if get a bit more specific. Replacing band-saw blades is pretty much the same basic thing for any stationary band-saw, and similar (but not really the same) for any hand-held type band-saw, but I don't know what kind of saw you have or what kind of trouble you are having. As a catch-all solution, you might try checking out a book on how to use band-saws at the library (or buy one on Amazon). These general kinds of how-to books are much more helpful than the user manuals that the manufacturers provide. Good luck.
Oct 15, 2012 | Dewalt DW872 14 Inch 355mm Heavy-Duty...
Hello, I've been attempting to adjust the band length on my Casio MTP-1239 but have been unsuccessful as I lack the necessary tools to do so myself and none of my local jewelry stores and retailers...
Your local jewelers are for sh**. DIY and google the procedure and I am sure you will be rewarded and save a few bucks at same time.
Sep 22, 2017 | Watches
Stretchy band with two handle to pull and velcro thats supposed to go around something, what is it?
You can use the resistance band to stretch and build strength in your muscles. You can use the velcro to attach it to your limbs and use your body as the load or attach it to a post and use it to stretch out muscles in your arms or legs.
Jun 09, 2011 | Exercise & Fitness
JBL Carbine Speargun what type of line should I use with it?
Any stout cord will do, nylon or HEAVY monofilament. Use no more than four wraps of line. Effective range of most band guns is about three times the length of the spear shaft.
Mar 18, 2010 | JBL Scuba Diving & Snorkeling
Does 6mm come before 5/16
5/16" is equivalent to 0.3125 inches
6 mm is equvalent to 0.23622 inches
Sep 30, 2009 | JBL 4´´ Gulf Slip Tip for 5/16´´ Shaft 6...
Useing my band saw i get burn marks
You are applying too much pressure to the saw blade...let the blade do its work...slow down a bit...the burn marks indicate too much heat is building up...the blade is not cooling nearly enough as it goes around, from too much pressure in the cut, or the band blade may be dull, too. When the blade overheats, it loses its strength and its ability to cut as well, and it will become dull much faster. Make sure the blade is the proper type---teeth per inch and type of teeth--for the material you are cutting. Take your time...you, the saw and the blades will last longer! Be safe!
Sep 16, 2009 | Saws
Delta bs100 runs backwards
It's wired wrong. You'll have to change the wiring at the motor to correct this.
If it's a new saw, I'd exchange it for one that was put together right.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 06, 2009 | Delta BS100 Shopmaster 9 Inch Bench Top...
Need part for delta shopmaster bs100 band saw
Here's alink to an online parts diagram and list, from which you can choose and order parts for your saw.
Click here
Apr 04, 2009 | Delta BS100 Shopmaster 9 Inch Bench Top...
Chrysler Sebring convertible top closure
I would suggest using something like a handle (cabinet or drawer handle) that you can screw into the inside of the top's frame so when she goes to close it she can use this as a means of more leverage to help pull it that last 2 inches so it can be latched down
Jan 18, 2009 | Porsche Boxster Cars & Trucks
mares Pneumatic Spear Gun Hand Loader with Metal Insert Logo
83 people viewed this question
Top mares Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you a mares Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
