Question about Whirlpool DU1055XTSQ Built-in Dishwasher
Top rack not getting clean - Whirlpool DU1055XTSQ Built-in Dishwasher
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
heatman101
Posted on Sep 12, 2010
Dishes in the top rack not getting clean. Bottom rack is fine.
Your filter/chopper is clogged. You have to clean it out and that will restore water pressure to the top rack.
  1. Remove the bottom rack.
  2. Remove the top rack
  3. Remove bottom Spray arm (turn top nut clock wise)
  4. Take off the delivery tube by turning it clock wise over the heating element ( undo the two clips one at the back and one on top)
  5. Take out the screw for the top screen and remove top
  6. Take one screw out for chopper housing and remove
  7. Remove chopper and clean or replace chopper if broken
Reinstall all parts and test.
That should help please rate your experience. Thanks
Dec 11, 2010 | KitchenAid 24 in. KUDP02CR Built-in...
Only bottom rack cleans. Re-plumb or replace?
Do you have a garbage disposal? If I run mine while the dishwasher is running, dishes do NOT get clean!
Jan 09, 2010 | GE 24 in. Profile PDW7800 Built-in...
Kitchenaid KUDP02CRB - top rack dishes are not getting clean
maybe not... if unit is incorporating more than one spray arm,chances are the upper spray arm is not getting water.pull top rack forward,gaze under top rack near rear manifold.slowly push rack back in.notice if manifold inserts into upper wash feed.if so,possible motor issue. if not,bingo was his name-o!
Nov 13, 2009 | KitchenAid Dishwashers
Top rack whisperquiet dishwasher no water
http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/8573754.pdf
I know this isnt the same model, they dont carry your manual as of yet. But it does have some suggestions to look at on page 17. I had the same problem and I looked really carefully and found my sprayer arm was blocked. I cleaned it out and havent had a problem with it again. I do check it regular now.
Sep 27, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
My whisper quiet dishwasher is not cleaning the top rack dishes
I'm having the same problem. Did some testing and found that the sprayer on the top rack is not even moving and hence not getting any water. Not sure what to do.
Sep 07, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
TOP RACK WILL NOT GET CLEAN
look in the owners manual on how to clean the food particle grate on the pump.....
Dec 27, 2008 | GE Nautilus 24" Built-in Dishwasher
Only some cups on top rack are getting cleaned
It sounds as if you have some rollers missing on the bottom rack which lets the rack sit on the sprayer therefore not letting it spin. You should have 4 rollers on front and 2 on back of rack. If you are missing two on one side, take one from the other side until you can get some more. Just make sure you have a roller on all four sides of the rack
Jul 18, 2008 | GE 24 in. GSD4030Z Built-in Dishwasher
Does not clean dishes on top rack
DG:
There is a rubber boot connecter in the back of the top rack which slips over a pipe coming up the back of the unit. This is how the water gets to the top rack. That boot is subject to rot and breaking. Check and see. It should be easy to replace, if you can get the part.
May 11, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Whirlpool DU1055XTSQ Built-in Dishwasher Logo
203 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
