Question about Peg Perego John Deere Gator HPX Ride on Toy
Where is the plug in to charge it - Peg Perego John Deere Gator HPX Ride on Toy
    Genius:
  • Peg Perego Master
  • 1,508 Answers
The battery is behind the front grille, you have to remove the screw in the middle and then pull out on the green plastic clips on each side then fold down
Posted on Jun 13, 2012
How do I charge my watch?
To charge your Apple Watch: Plug the Apple Magnetic Charging Cable, Apple Watch Magnetic Charging Case, or Apple Watch Magnetic Charging Dock into its USB power adapter. Plug the adapter into a power outlet. You can also plug the charging cable into a USB port.13 Sep 2016
Check your battery and charge your Apple Watch - Apple Support
https://support.apple.com/en-gb/HT204608
Dec 09, 2016 | Watches
I have Acer Aspire 5349 its shows plug in not charging. How do i troubleshoot
If you power it down, plug the adapter in and wait for the charge light to illuminate then power up the laptop. You may find it only charges when not in use.
Feb 25, 2016 | Acer Computers & Internet
AT&T Impulse 4g says phone is charging when it is not plugged in. Will not charge when plugged in!
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jul 26, 2012 | Huawei Impulse 4G
When i plug my charger in i have to move it around for it to start charging and if i move my phone it quits charging its not the chargers i have tired im thinking it my phone. what do i do?
The charging socket on you phone needs to be resoldered, OR the plug on the charging adapter is faulty and needs to be replaced.
To determine which is faulty, use a different charger and plug it into your phone and move the charging plug to see if the it quits charging. If it quits charging then the charging socket on the phone needs fixing (re-soldering).
May 07, 2011 | Cell Phones
Have a Sunrise Aspire chair w/new batterie, charged by the repairman. Want to keep it charged regularly (not let it run down). DO I NEED TO TOTALLY DISCONNECT THE POWER HOOKUPS IN THE BACK when I...
You do not need to unplug the large 9 pin beau plug in the rear or the smaller 3 pin molex plug when you charge the chair. Do not unplug them or you will not charge the chair.
Use your charging cord as you describe "plug it into the front, plug it into the wall and charge, then unplug the charger cord and GO". Hope this helps.
Jan 05, 2011 | Quickie Wheelchairs Quickie Aspire Power...
My handheld camera model does not seem to charge. I leave it on charge all day and it only has one bar of power when not plugged in?
ok,just figured it out,the plug that goes into the socket vertically is pretty much useless. As soon as you plug it into the handheld device to charge, it shuts off. I took the plug that goes into the socket horizontally and plugged it into the handheld and it began charging. So to use the product, you need to charge the handheld fully and then use the same plug to plug in the actual video camera that is pointed at baby,then you will be set to go. The company should send 2 horizontal plugs.
Dec 17, 2010 | Summer Infant Slim Secure Handheld Video...
Garmin will not take a charge
Are you using the car charger adapter plug? If so the plug may have a blown fuse... I would unscrwew the silver end of plug and check fuse ...its spring loaded so be careful...
If the fuse is good try plugging the unit into your computer with the usb connector to see if it charges .... its a slow charge so may take a few hours to fully charge
It fuse is good and unit takes a usb charge the car plug needs replacing
Oct 25, 2010 | Garmin StreetPilot C330 GPS Receiver
I neglected to plug in the cord to my cigarette lighter and the charge ran down to 0.I am on a trip and did not bring the charging cord. i tried plugging into lighter in car but it stays on for a feww...
leave it switched off and plugged in.
This would give it chance to actually charge as using it from dead with it plugged in does not always allow some GPS to charge properly.
You neglected to say which brand so its hard to give a 100% answer.
Most GPS should have enough charge withing 4 hours but from dead some older units require anywhere up to 18 hours according to some of the manuals i have laying around
Bob.
Bob
Jun 23, 2010 | GPS
How do I charge?
Mine charged itself when if was plugged into the computer. I don't know if that is how you formally charge it, but it worked for me and I see no other way to charge it. Good luck. =)
Jan 02, 2008 | MyMusix PD-6070 MP3 Player
Peg Perego John Deere Gator HPX Ride on Toy Logo
22 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
