Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
I just purchased a used Sony KDF-60XS955 Projection TV. I have replaced the lamp unit, however, the picture remains fairly dark. The picture is only clear when you are positioned directly in front of the set, and even then the picture is fairly dark. When viewing anywhere off from center, the picture is extremely dark. Does this issue suggest a specific problem? I was thinking I might attempt to clean some of the dust from inside of the set and see if that helps the situation.
  • Sony Master
  • 5,138 Answers
Replace the Light Engine,but you can try cleaning the lenses inside light engine you have 3 red, green, blue,You also want to be very carefully when cleaning.
Posted on Sep 12, 2010
Tv picture blinks on an off, is the lamp failing ? i have been told that replacing the lamp will correct the picture going on and off.
Yes possible cause is the lamp, but if you replace the lamp you should also reset the lamp timer of your unit good day and best regards.
Aug 20, 2011 | Sony Grand WEGA KDF-60XS955 60" Rear...
Picture and sound go on and off every few seconds
If it is Sony KDF-60XS955 then its lamp is near to end and needs replacement.
Lamp replacement procedure would be written in user manual and its easy.
If tv model number is different than above mentioned, please let me know.
Jul 05, 2011 | Sony Grand WEGA KDF-60XS955 60" Rear...
I have a Sony KDF-60XS955 tv. It won't power on,
I have that manual. There are three lights to the left of the power button. One is labled LAMP. The manual states "The projection lamp, which illuminates the picture, has a limited life. If the screen becomes dark, the color looks unusual, or the LAMP indicator on the front of the LCD projector TV flashes, it is time to replace the lamp with a new one (not supplied). Use a Sony XL-2200 replacement lamp (not supplied) for replacement. Use of any other lamp may damage the LCD projection TV." I also found in a different page " LAMP LED lights up in red when the lamp for the light source has burnt out." I guess burnt out would be extream. I found one other if you had opened the light bulb cover and didn't close it properly. " If the lamp cover is not reattached securely, the self-diagnostic function may be triggered and the POWER/STANDBY indicator flashes three times." You can down the sony manual at http://www.docs.sony.com/release/KDF60XS955.pdf
Jun 02, 2011 | Sony Grand WEGA KDF-60XS955 60" Rear...
My TV picture has become dim and dark. The lamp light is not on. Rest all is ok.
Lamp is weak in result but not dead yet that will turn on lamp light. Lamp is going to die so replacement will solve the problem.
lamp replacement procedure would be written in user manual of tv.
Thanks.
May 14, 2011 | Sony Grand WEGA KDF-60XS955 60" Rear...
My sony kdf-60xs955 rear projection tv has started to turn itself off, then on again frequently
This is symptom of weak lamp that has reached end of its working hours life, replace lamp in tv to fix the issue.
Lamp replacement procedure is easy and written in user manual.
Thanks.
Oct 26, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Hi all,\r\n Ok, I have a Sony KDF-60XS955, about 5 years old. Yesterday, the picture started dimming noticably. Today, it's so dark it's unwatchable. I've read that it may not be a lamp issue, since...
http://www.nodevice.com/manual/sonymans/manual3400pdf/get4917.html
Above is your user manual, below is your service and repair manual. http://www.fixdevice.com/smanuals/tv/sony/kdf60xs955.html
This may very well be a lamp problem, or it may be the "Driver" for the lamp, or indeed the Power Supply to that lamp, unfortunately one must troubleshoot these issues to isolate the actual problem, Please use these manuals, and you should soon be able to isolate and effect a repair.
Jun 15, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
My Sony Wega KDF-60XS966 is dark You can see the picture and the brightness is turned all the way up but it still looks dark Do I need a bulb?
Yes, its time to replace lamp in tv.
Lamp replacement is easy and procedure would be written in user manual.
Thanks.
Jun 10, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
The picture goes off, the power/standby light
Sony KDF-60XS955 picture goes and power/standby light light flashes
Most likely you have bulb failure. First step in troubleshooting is "Change the Lamp or Bulb". Lightning, power line bumps and collisions with vacuum cleaners can all shorten lamp life. Rough handling in shipment can also happen without your knowledge.
+90% of all Sony LCD Rear Projector "No Picture or Intermittent Picture" faults are related to bulb failure.
If new lamp does not improve the situation, then hands-on troubleshooting by someone that has parts and knows how the unit works is the only practical remedy.
easyab
Mar 14, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Picture is dark even after ajustments
Is it Sony KDF-60XS955 TV and have you replaced its lamp?
Symptom shows TV needs new lamp.
Let me know if lamp is replaced or not to provide you more info.
Aug 30, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Thermal fuse on sony KDF-60XS955
check out link below for part. i have 55cs955 and just ordered one. I still do not know where to find in TV but as most post says its somewhere near lamp housing.
http://www.partstore.com/Part/Sony/Sony/191002393/New.aspx?ModelMfgName=Sony&ModelBrandName=Sony&ModelNumber=KDF55XS955
Apr 01, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
130 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
