Question about Philips 42PF9936 42 in. HDTV-Ready Plasma Television
We have a Philips Plasma 42" model 42PF9936d that was turned off all summer. When we returned home and tried to turn it on, the tv will power up for just a second, and then shuts right back down. The indicator light goes green, and then off to red. We have to manually push the button on the side of the TV to even attempt to turn it on again, but it never stays on. Thanks!
  • 45 Answers
SOURCE: plasma won't stay on red light flashes and shuts unit off
I had similar problem with 42fd9932, run for a few secs or minutes, shutdown and flash red led for ever. Fans in this unit were not causing shutdown although I could stop one and get the red led flashing thing.
Replace c2212 100uf, c2508 4.7uf changed to 10uf, c2664 100uf. I also added clip on heatsink to U7203 8.5v TO-220 case regulator( next to c2212) and a drop of oil to each fan(poked a hole through label center). Something else I did was add a 47 ohm 5w in parallel with fan ps 100 ohm 5 w resistor.
These parts are all located on the two power supply boards. Use Caution 380V is present on these boards. Allow a few min for caps to discharge.
Posted on Nov 04, 2007
  • 7 Answers
SOURCE: 42" Philips plasma screen goes black
You have a Ysus problem. Sounds like a cold solder joint or loss connections on ysus main board.
Posted on Jun 07, 2008
  • 52 Answers
you need to replace y-sustain board.
Posted on Jul 25, 2008
mumma_1
  • 903 Answers
SOURCE: 42" philips plasma
when a television turns off by itself and flashes as you say, it indicates that there is a problem inside the tv. If you keep trying to turn it on you may do more damage. It could be something as simple as a faulty fuse inside. If you have no expierience with electrics I suggest you get it checked out by a professional. I had a similar problem with another tele model and it was the fuse in the back of the tele that needed changing. I did try to this on my own but unfortunatley didn't have the right fuse so i took it to a repair shop and he done it really quickly.
Posted on Oct 23, 2008
SOURCE: Philips 42" Flat Screen Plasma - blinking red light 7 times - HELP please!
I had the same issue with 2 of these sets. It ended up being 2 capacitors were bad on the power supply. They are located towards the bottom of the board, you can visually see they were buldging and leaking slightly. I replaced them with 2 I salvaged out of an old computer (of same values) and the tv works as it did before.
Posted on Jan 08, 2009
Hi i have a magnavox 42" plasma TV (model
I'd look for the manual and see what it says about that red light. I can't find squat for "Magnavox KM42010P".
May 28, 2011 | Philips Magnavox MRD120 - home theater...
42PF9630A 42 in. Plasma Television: hi there, I have a phillips 42 inch plasma flat...
This is because the power switch operated the socket that your TV is plugged into. Unplug it and plug it in another socket that is not operated by a switch. Appliances should not be plugged into a socket operated by a switch because of the inconsistency of power to the socket. Lights are about the only thing that should be plugged in.
Dec 23, 2017 | Philips 42PF9630A 42 in. Plasma Television
I have a Philips plasma 42 with black lines across the screen
I would first check if there is an available firmware upgrade for your model .Upgrade requires you to download firmware from philips website.Then transfer it to a memory stick .Then use a memory stick reader to plug into tv for firmware upgrade.Other wise the set would probably need repair .Possible a bad SSB board or another issue
Aug 26, 2009 | Philips 42PF9630A 42 in. Plasma Television
My philips 42 inch plasma model # 42PF9966/37 wont turn on. Red standby light is not on
Hi. Try, in back yours tv on left side of the power corde connector have on hole, inside of this hole have one main switch, using one insulated stick and sheck if this switch is off ( may be not ) but try. If you heva esperience take out the back cover and check the fuse on power board. Good lock
Jan 03, 2009 | Philips 42FD9932 42 in. Plasma Television
Jun 03, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Power issue
The Philips Plasma TV have a problem with electrolytic capacitors going bad. I believe you heated some capacitors and your problem may return. If so, try replacing 2540 (100ufd@25v)
and 2508 (4.7ufd@50V).
Apr 11, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Philips 42PF9936 42 in. HDTV-Ready Plasma Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
