Question about Samsung SIRS4120R Receiver
Trouble with Tuner 2
Hello. Our Samsung SIR4120 DVR/ Receiver has problems with Tuner 2, with gridding up and freezing intermittently, very similarly to what happens during storms. But it is happening recently in clear weather.  When this happens, and we're watching Tuner 1, an error message pops up, "trouble with tuner 2."  The picture grids up, sometime freezing, with sound dropping out and occasionally stopping playing completely until we get out of the dropout by fast forwarding, if that works. I have switched antenna leads and it still happens on Tuner 2.  Can just the tuner be tested?   Please help if you can.  Thanks much.
    Problem Solver:
  • 15 Answers
From experience, I suspect that the dish has lost it's optimum "focus" on the satellites, and your signal has dropped. In your case, tuner #2 just happens to need a little more signal than tuner #1 - and that's revealing the root problem.
If you can have a second person handy, use the signal meter function and view the signal. Then one person should move the dish a bit (likely upward a hair). If the signal goes up with just the slight movement of the still tight dish, that's the problem.
If so, it's time to align the dish.
Posted on May 15, 2008
Why does my R15-100 DVR Plus not record 2 programs at same time. What can I do to fix it?
When we had the R15 (we have since upgraded) we could record two channels at once with no trouble. You have to have two satellite connections in the back (since it uses a separate tuner for each channel) and you cannot watch a third channel while recording two others - if you're going to watch, you have to watch one of the two shows you're recording.
May 16, 2014 | Directv Plus DVR DTV Receiver / 100-Hours...
I have a Verizon FIOS DVR connected to the Samsung receiver. After watching TV for a period of about 30 minutes or so I start to get a delay in the volume coming out of the speakers compared to the picture...
common problem, trouble is that the receiver cant keep up with the dvr box. try this, dont use audio from your dvr into your reciever, take the audio out from the tv, and go into the receiver, now the sound is after the picture and should catch up with itself.
Mar 20, 2011 | Samsung HTC6930W Theater System with...
The box keeps freezing and running very slowly, after resetting from the menu the problem goes away for a short while and then returns
david_laws
You don't specify what type of equipment you have. Try unplugging the DVR from the electrical outlet for about 10 seconds and plugging back in. You can also check your cables between the DVR unit and the TV to make sure all cables are secure. I hope this helps.
Ray Calo
DISH Network
Feb 16, 2011 | Televison & Video
I have a 625 dual tuner from Dish. When I do a check switch it shows that I have signals on both satellites on tuner 1 but tuner 2 has none. When I disconnect the cables from the receiver and reconnect...
Hi, Mary with Dish Network Customer Service, I will be happy to assist with this. This receiver needs to have a Separator (splitter) that has one coax cable coming from the Satellite into the single side and then two cables out, which connect to the receiver box. The Separator is marked with a SAT1 & SAT2. They will connect up to SAT1 & SAT2 on the receiver box itself. If you are using a different typr splitter, it is probably not rated for the splitting of the Satellite feed. I hope this helps you, if not feel free to contact me.
Jan 01, 2011 | DISH Network DVR-625 DTV Receiver /...
We cannot watch a show on another channel on other
Hello! Dan Busa here with DISH Network customer service. This is actually how your DVR is supposed to function. A 622 is a dual tuner reciever meaning it's capable of watching or recording two live shows at a time. When you record a show you tie up one tuner, there are two work arounds. You can get an additional dvr receiver or you can set up record preferences and have everything automatically record to tv2.
Jul 20, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Problems with optical input. I am having intermittent problems with the optical sound input on my Onkyo. I am using a DVR with optical output for the source. Sometimes when I turn the DVR and Onkyo on I...
sometimes with cable, satellite, or any dvr, the digital signal actually is intermittent and there is little we can do about it but add an analog audio connection for each device as a backup. per se, and put the receiver in auto input mode. the receiver will utilize the analog signal to fill in where the digital signal fails
good luck
Dec 07, 2009 | Onkyo TX-DS747
Trouble recording on the DVR.
Do you have a Dual tuner DVR? If so, verify that you have 2 cables from the dish plugged into the back, one into each tuner.
If thats not the problem, go into your settings and verify that you do not have one tuner disabled. If both tuners are enabled, check the signal strength. If its good on both tuners and resetting the receiver doesn't fix it, its probably time to call DTV to discuss a new receiver.
Dec 29, 2008 | Directv Televison & Video
Problem with playback on DVR - R15-500 receiver.
Check your signal strength on your second tuner. Dont forget to check all satellites and, if you use the signal meter instead of system test, a few odd and a few even transponders.
It sounds like it may be low.
Dec 02, 2008 | Directv (R10) DTV Receiver / 70-Hours...
Samsung SIRS4120R Receiver Logo
124 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
