Question about Candy Ovens
How do you change the oven light in a Candy FPP407X built in oven. The glass cover does not seem to turn , just moves a little side to side.
4 Suggested Answers
protek480
  • 1723 Answers
SOURCE: how to change the oven light bulb in a candy f245
The glass cover does come off. Use some latex gloves or non skid material and grasp the lens firmly and turn counter clockwise.
Posted on Jul 15, 2009
Testimonial: "Spot on - I actually used insulating tape and water pump pliers- but I needed to know it would be ok."
  • 3 Answers
SOURCE: how do i remove the glass cover to change the bulb
either a allen wrench or a hexagon screw drive
Posted on Oct 24, 2009
barkencoa
  • 3463 Answers
SOURCE: I have recently moved into a Park Home that has a
If it has not been removed for a long time, then it could be stuck with bunt on grease and fat.If it is a round glass, then it should unscrew anti-clockwise.
Try wrapping a cloth round a pair of grips, and try to unscrew it that way.
Do not put too much pressure on, as you may break the glass.
Posted on Feb 08, 2010
How do I change the bulb inside the cooker of the B5741 cooker
Oven Lighting
Warning: There is a danger of electric shock! Prior to changing
the oven light bulb:
  • Switch off the oven!
  • Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Replacing the oven light bulb/cleaning the glass cover
  1. Remove the glass cover by turning it anticlockwise and then clean it.
  2. If necessary:
Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
oven light bulb.
3. Refit the glass cover.
Dado
Apr 15, 2015 | AEG Ovens
HOW TO REPLACE THE LIGHT BULB IN MY OVEN
Oven Lighting
Warning: Risk of electric shock! Prior to changing the oven light bulb:
- Switch off the oven!
- Disconnect from the electricity supply.
Changing the oven light bulb/cleaning the glass cover
1.Remove the glass cover by turning it anti-clockwise and then clean it.
2.If necessary: replace with 25 watt, 230 V, 300 °C heat-resistant oven lighting.
3.Refit the glass cover.
24472822-skr3uzd4ii43xzwyhmpsswym-3-0.jpg Dado
May 21, 2014 | Electrolux EOB5665G Ultrafan Electric...
I need some help please, The bulb has gone in my oven! how do I change this and where would I get a bulb? The oven is a candy and the model number is FPP403.
Most ovens use appliance bulbs that can be purchased at any home improvement store. Open oven and locate the glass protective cover and remove it. Remove bulb and replace w/new one, place protective cover back.
Apr 23, 2011 | Candy F248P Electric Single Oven
Interior light went out. How do I replace it? I read someone had a similar problem but the expert said to call a service rep.saying that it's beyond the expertise (safety) of owner. So, do I call a...
It is easy to replace if you are handy. There is normally a small piece of glass with clips either side or a glass cover that unscrews which can be a little hard to turn sometimes. If it is the glass cover that unscrews dont be scared to use multigrips as the glass is quite tough but try to be gentle.
Feb 08, 2011 | Ovens
I have recently moved into a Park Home that has a 4/5 year old Candy cooker - the light bulb in the oven has failed and needs changing, but I cannot mov e the glass cover at all, it will not lever/unscrew...
Feb 08, 2010 | Candy FP855 Electric Single Oven
How do a change the element on a candy oven , can't get to the old element
You have to gain access to the element by removing the outer rear panel of oven, if it is built in, then this means removing it from the housing.
Once you have removed the cover, and possibly the top panel, you will see how the element is fitted.
It is a fairly straight forward repair to do.
Please rate my solution.
Thankyou.
Jan 25, 2010 | Candy F248P Electric Single Oven
How to change the oven light bulb in a candy f245. Glass cover on inside doesn't seem to undo - moves a bit each way. No apparent access from outside.
Jul 15, 2009 | KitchenAid KEHC309 Electric Double Oven
I CAN'T FIGURE OUT HOW TO CHANGE THE LIGHT BULB IN MODEL JT910 WALL OVEN.
if i'm correct it should be on the left side of your oven or maybe on the right lol but there is a glass object that looks like a light bulb its thick glass you just twist that offf as its a screw lefty loosy righty tighty and there you go you also might have a litle wire across the big thick glass bulb looking object which you have to just move out the way no snapping of or anything
Jun 07, 2009 | GE Profile 30" Built-In Single Electric...
Glass light cover removal
Try spraying WD40 onto the glass and bulb holder, try to screw the bulb cover back on first, and then try to unscrew i, it may help if you grasp it with a cloth or similar as you try to unscrew it
Plz rate my solution.
Tghanks.
Jan 19, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Cant remove oven light cover
Try a adjustable car oil filter wrench (cost a couple of bucks at Wal-Mart). Simply put it around the glass cover and give it a twist. Worked great for me.
Nov 12, 2008 | Ovens
Ovens Logo
105 people viewed this question
Top Candy Ovens Experts
ashburton
ray gallant
Dado
Are you a Candy Oven Expert? Answer questions, earn points and help others
