Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Cub Cadet 2166 The PTO Belt broke THEN the replacement belt . SHREADED within one hour of use. That is, it did not break it came apart , then the next one did the same. i really do not want to keep doing this at $ 20. 00 each. i wonder if the tension spring is not doing it's job. i checked all of the Sheaves and lay of the belt. Please, what is happening ? Thank you
4 Suggested Answers
panilling9
  • 284 Answers
SOURCE: engine stalls when electric PTO clutch is engaged
check your spacers to be sure you havent locked the clutch assembly directly to the motor shaft
you should be able to turn it fairly free less some clutch drag
Posted on May 26, 2009
  • 33 Answers
SOURCE: I need a deck belt for a cub cadet 2166 what
http://www.cubcadet.com/webapp/wcs/stores/servlet/category1_10051_14101_1100505_Y_-1
Posted on Aug 21, 2009
  • 110 Answers
SOURCE: Cub Cadet LT1042 PTO won't disengage
If its an electric PTO then the switch on the dash is bad, Its a lever type ungagement then the little break shoes that rub on the blade spindles are either worn out or mis adjusted.If it started when you changed the blade drive belt its possibly the wrong belt??
Posted on Nov 01, 2009
How do i replace v belt on ltx 1040 cub cadet.
Nolan, Check the attached links,instruction and guides for belt replacement on Cub Cadet. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Change the Deck Belt on Cub Cadet Riding Lawn Mower Using Model...
How To Install or Replace Drive Belt on Lawn Mower Cub Cadet
How to Change the PTO Belt on Cub Cadet Riding Lawn Mower
cub cadet belt replacement diagram Google Search
Jun 30, 2016 | Garden
Model 2166. Where can I get diagram showing PTO belt installation?
http://www.cubcadet.com/webapp/wcs/stores/servlet/ARIPartFinderView?storeId=10051&catalogId=14101&langId=-1#/s/CUT/2166//1
Oct 07, 2015 | Cub Cadet Garden
I need a schematic for installing a cub cadet LT1050 drive belt. The old belt broke and I'm just not sure how to replace it. It appears you need to remove the clutch for the mower blade firat.
To replace a transmission drive belt on a Cub Cadet LT1045 or LT 1050 you need to remove the deck, preferably put the front wheels up on blocks or stands, unplug the PTO power (directly under the engine, which can be a pain ), use an impact wrench (you need the speed of the impact wrench because the engine will turn) and a 5/8" socket and reverse the bolt out of the PTO.
The PTO may be sized on there so you may want to tap it with a hammer and a block of wood carefully to release it. AT this point remove the 4 engine mount bolts from underneath (1/2" I believe). You will need to remove the left steering nut and arm to have access to the 4th bolt. Do not remove or replace engine mount bolts with impact wrench or bolts may break. Loosen old belt from tensioner pulley. Place pry bar under engine to slightly lift engine and move aft to expose belt from pulley and remove from pulley. Remove old belt from engine pulley first, transmission pulley last. Remember how belt goes around pulleys before doing so, draw a map if needed.
You'll need to put the belt on the transmission pulley first then thread the belt up to the engine pulley. Carefully push engine back into place and exhaust pipes into forward muffler will take some patience. Bolt engine back on being careful not to over tighten bolts. Place steering arm and nut back in place. Thread your belt back through the pulleys and tensioner (make sure your spring is strong enough to tension the belt or buy a new one).
The PTO is "keyed" on the shaft. Replace bolt and washer. Put your deck back on and you're ready to mow again. Give yourself an hour for this one.
Aug 16, 2014 | Cub Cadet Garden
GT 2550 cub cadet tractor. PTO belt will eaither fall off or break into pieces. It has done this from fist week a purchased tractor in 2010. within last 10 days 3 belts has broken into pieces.
look in manual and look to see if you are routing it the right way. Ive had this prob before. The belt seems like it fits and moves the mower but its rubbing on something that just chews it up
Aug 14, 2013 | Cub Cadet Street Sign- tractor lawn riding...
I have a 2166 cub cadet and the pto belt keeps breaking why
Check that belt is mounted properly according to the diagram on the tractor. Frequently people put the belt on the wrong side of the steel guide springs so that the belt is abrading the springs instead of smoothly riding on the pulleys.
Jan 12, 2013 | Garden
I have a cub cadet 2166. Blades are not kicking on when the pto switch is engaged
hello, the pto or belt is bad,for the pto repair see u tube,,
Feb 18, 2012 | John Deere Garden
PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
May 10, 2010 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
Engine stalls when electric PTO clutch is engaged
Apr 11, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
235 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
