Question about Paragon 8145-20 Defrost Timer
I have a bad Paragon 8145-20 its Sunday all I have in stock is a Paragon 8045-20. I know voltage is the same. Will the 8045-20 work? What is the difference betweentime out and temperature out. If the 8045-20 will work I am sure it will be wired differently I will need wiring diagrams. Thanks Ray erhanco@twlakes.net
See wiring diagrams and manuals at following link:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
8145-20 is 240V time initiated, pressure or temperature terminated with back-up time termination.
8045-20 is 240V time initiated, time terminated.
So 8145-20 has pressure or temperature limit switch that connects to terminal X that turns timer off, and ends defrost cycle. This timer is for hot gas defroster that has pressure/temperature limits. Check and see what the back-up time termination is set at on 8145-20. Look at small inner dial.
The 8045-20 timer does not use pressure/temperature limit switch, and instead you have to estimate length of time you want defrost cycle to run, and set inner dial to that time. Use same time as back-up time termination on 8145-20. Of course the pressure/temperature limits would not be exact and defrost cycle might not work correctly.
Here's the change-over wiring from 8145-20 to 8045-20.
There are other wiring variants depending on equipment.
240V hot wires from breaker box are L1 and L2
a) 8145-20 L1 is at terminal 1 > move L1 to terminal N on 8045-20
8145-20 L2 is at terminal N > move L2 to terminal X on 8045-20
b) 8145-20 hot gas defroster is at NO terminal 3 > move defroster to NO terminal 3 on 8045-20
Complete the 240 circuit to defroster by connecting to L2 at terminal X
c) 8145-20 refrigeration is at NC terminal 4 > move refrigeration to NC terminal 4 on 8045-20
Complete the 240 circuit to refrigeration by connecting to L2 at terminal X
Posted on Feb 06, 2011
Can you show me paragon timer 4003-0 the wiring
1) Copy following links:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
http://waterheatertimer.org/images/Paragon-4000-series-wiring.jpg
2) 4003-0 is 120Volt timer so clock voltage is 120V
Timer can control 120V or 240V loads
Use diagram 3
3) Paragon is no longer making this timer or parts for timer.
If you purchased timer from ebay, then assume motor is bad or X2772 trippers are worn out.
Always buy new timers. Buy Intermatic and parts are easily available.
4) Replacement timer is Intermatic T101
Feb 16, 2013 | Paragon Hardware & Accessories
I need a manual for a 8025-00P paragon timer.
8025-00P is 120Volt timer in Nema3R indoor/outdoor enclosure.
Timer has 2 NO terminals and 1 NC terminal
This timer is mechanical, and will work with fluorescent lights, and also certain defrost applications.
Copy following links for information.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#42000
http://waterheatertimer.org/images/Paragon-8045-image-large-50.jpg
Connect Hot to terminal 3, and Neutral to terminal X
Load Wire going to light has black and white wires: Connect Load black to terminal N or to terminal 2. Connect Load white to terminal X
Aug 01, 2012 | Hardware & Accessories
Need a wiring digram for a pargon5x455 defroist timer
5x455 is WW Grainger number for 240Volt time initiated - time terminated Paragon 8045-20 timer.
Open following links to identify timer and download wiring diagram:
http://www.grainger.com/Grainger/PARAGON-Time-InitiatedTime-Terminated-Defrost-5X454?Pid=search
http://waterheatertimer.org/Paragon-timers-and-manuals.html#8045
Aug 21, 2011 | Paragon 8145-20 Defrost Timer
I need a set of trippers for a Paragon timer Model number 4001-00. Where can I get them. Thank you. My name is Jim Vivone
Google search for X2772 tripper and some places may still have them.
Paragon is no longer making timers and parts except defrost timers.
Paragon 4001-00 120Volt timer uses X2772 tripper:
Paragon 4001-00 crossover to Intermatic is T101 120Volt timer.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Crossover wiring:
Paragon 4001-00 has terminals 1 2 3
T101 has terminals A 1 2
Paragon terminal 1 connects to Intermatic terminal 1
Paragon terminal 2 connects to Intermatic terminal 2
Paragon terminal 3 connects to Intermatic terminal A
Aug 03, 2011 | Hardware & Accessories
I need to purchase 6 (six) more sets, 1 on and 1 off, trippers for the churches' 7 day timer. Do you need to know voltage of motor? The voltage it is switching is 240 volt.
1) You posted under paragon 7008-00 timer.
It is not necessary to know voltage of motor to order tripper
2) Model number of timer is usually located on inside door panel
3) Paragon is no longer making timers or parts.
Open following link to identify timer for sure:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#7000
http://waterheatertimer.org/Boxtype.html
4) Following link from Paragon gives links for folks who might still sell parts:
Expect some suppliers to overcharge for parts.
I've seen paragon trippers selling for $60.
http://portalgb.knowledgebase.net/display/1/index.aspx?c=15121&cpc=XobrEdQ5Lsnv624T2PBS4Exx6S5VyiL7gw3am4YYt6&cid=13013&cat=&catURL=&r=0.485034763813019
5) It might be easier to buy another time clock.
Refer to Intermatic Competitive cross reference chart.
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
For example replacement for 7008-20 is Intermatic T7802B which is a 7-day, 40 amp 240V timer.
http://www.intermatic.com/products/timers/mechanical%20time%20switches/7%20day%2040%20amp.aspx
6) You are working for your church, probably as a volunteer.
I also volunteer several places in my community.
I have extensive files on timers and can help you choose and install a new timer if I know the model number.
Just add a comment to this post and I will answer if needed.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 07, 2011 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
Trying to replace a 8045-20 w/ 8145-20 need wiring info
The 8045-20 & 8145 are 240V timers.
My maintenance buddy at McDonalds says the defrost timers are interchangeable, BUT I have not wired these particular timers.
You may want to post your question to a paid answerer who specializes in refrigeration:
This being said:
The 8045 is for 'Electric Heat Defrosting'
The 8145 is for 'Hot Gas Defrosting'
I posted the manual:
http://waterheatertimer.org/pdf/8000-series-defrost-sell-sheet.pdf
I also posted the 8145 and 8045 wiring side by side:
The wiring changeover looks like the following:
Hot1 on 8045 is connected to terminal N => move this wire to terminal 1 on 8145
There is a jumper plate on 8045 that connects terminals 1 N 2
Jumper plate on 8145 connects terminals 1 and 2
If jumper plate is missing on 8145, use jumper wire to connects terminals 1 and 2
Hot2 on 8045 is connected to terminal X => move this wire to terminal N on 8145
Other wires on 8045 that are connected to terminal X => move to terminal N on 8145
Thermostat on 8045 is connected to NC terminal 4 => move this wire to NC terminal 4 on 8145
Heater on 8045 is connected to NO terminal 3 => move this wire to NO terminal 3 on 8145
Terminal X on 8145 is bare since this goes to cycling limit switch which is not used on 8045
The wiring diagrams appears below:
Nov 10, 2010 | Paragon 8145-20 Defrost Timer
Looking for timer pins-trippers
The Paragon 4000 series uses the Paragon X2772 tripper
Google search for Paragon X2772 tripper turns up sellers
Pair of on-off trippers appear to sell for about 9$
Oct 28, 2010 | Paragon 4001-00 24-hr Timer Control 120v...
Paragon 8145-20 Defrost Timer Logo
508 people viewed this question
Top Paragon Hardware & Accessories Experts
Gene Haynes
jdthefixer
Andrew Taylor
Andrew Taylor
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
