Question about GE DSXR453EV Dryer
THE AUTOMATIC SETTINGS ON THE DRYER DON'T WORK RIGHT. WILL DRY BUT NEVER TURNS OFF-KEEPS DRYING INDEFINITELY. TIMED DRYING WORKS CORRECTLY BUT SEEMS TO TAKE FOREVER TO DRY A LOAD.
  • labreajohnso Sep 12, 2010
    Where are the sensor bars located?
  • GE Master
  • 8,220 Answers
This dryer has a sick timer. Not a bad timer mind you. A sick one. Get the timer out of the machine. It ain't hard to wire because of the quick connects. Take the 2 main screws out the timer motor and carefully take the timer apart. Get a file and clean the leaf switch contacts. Put it all back together and party on. OR Replace the timer and spend some money. LOL
Posted on Sep 13, 2010
    President:
  • 1,554 Answers
It seems that there are two issues with your dryer. First, the dryer never turns off during the auto dry cycle because of moisture sensor not working correctly. The sensor bars are likely shorted making it falsely sense that the clothes are still damp. The second issue is with dryer vent duct system. The duct seems clogged with lint that's why it takes almost forever to dry a load.
Check to make sure that the sensor bars are not shorted and the dryer duct including the lint filter and the blower wheel are not clogged with lint. Clean the lint filter after every load and the dryer duct regularly.
You don't have to accept or reject and rate this post to add information or post comments and follow-up questions should you need further assistance. But accepting a solution does not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Sep 12, 2010
  • Jahn27
    Jahn27 Sep 13, 2010
    The sensors are located at the front of the drum near the bottom of the door opening. Please indicate the exact model number of the dryer if you cannot find the sensor bars.
Takes 4 ever to dry clothes. Will run & run when on auto dry.
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Jan 09, 2011 | Amana NDE5800AY Electric Dryer
Maytag Dryer
HI,
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Aug 28, 2008 | Dryers
My kenmore dryer heat element goes on and off. The clothes take hours to dry.
It seems to run forever If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system. Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Dec 31, 2009 | Kenmore Dryers
Dryer does not stop. time shows flashing rectangle.Is this normal
Hi There
I have this for you to read this should get you on the right track. Let me know how it went.
Thank you for writing to fix ya.
Best Regards Richard
Dec 23, 2009 | Samsung WF203ANW Front Load Washer
LG Dryer Sensor
The moisture sensor is in the lint filter. Remove 4 screws from inside the drum and you have the sensor attached by 2 wires. On my dryer I disconnected then reconnected these 2 wires, reassembled the lint trap and auto dry works fine again
Sep 27, 2009 | LG DLE2514 Electric Dryer
Tumble dryer will not dry
Aug 19, 2009 | Dryers
Dryer not turning off when clothes are dry (model LDE 400ACL)
Normally if you have an automatic cycle that turns off the dryer when the clothes are dry, it will do it with a special thermostat or moisture-sensing system. The thermostat tells the dryer to heat until the interior of the dryer reaches a "pre-set" temperature.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. If there is a moisture sensor, the timer advances only if the moisture content of the clothing is low enough. The timer advances until the interior cools, then the termostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But... if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix this problem, clean the vent and/or internal ductwork and make sure the vent is not compressed or kinked. If that doesn't work, then your thermostat, moisture sensor or timer could be the culprit.
Jul 15, 2009 | Dryers
Dryer will not turn off
May 20, 2009 | Dryers
Kenmore 11070702990 Gas Dryer - Timer does not work
May 09, 2009 | Kenmore 60172 Electric Commercial Dryer
Takes too long to dry or keeps running when clothes are dry
May 07, 2009 | Kenmore Elite Oasis 6809 Electric Dryer
Dryers Logo
55 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
