Question about Keurig Platinum B70 Coffee Maker
I have the Platinum Keurig, but it will not take in any water from the tank. I've tried to descale, but if it won't take the vinegar solution, what else can I do?
  • 40 Answers
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
Posted on Oct 07, 2010
Water pump makes a lot of noise when pulling water from tank
You may need to descale the coffee machine... Use white vinegar and put into reservoir and run until reservoir is as empty as it will get. Fill with water and run to clear....I do this twice to make sure the vinegar odor is gone.
Oct 10, 2013 | Keurig Platinum B70 Coffee Maker
It says descale but I don't know how. It won't let any vinegar or water go through.
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Sep 08, 2011 | Keurig Platinum B70 Coffee Maker
I have B60... I have descaled it twice wit vinegar... water is coming out although not as fast as it should. Descaling light still on... what should I do?
Vinegar is really not good for cleaning coffee machines.
You should rather use acetic acid.
1) put 4 cups of water into the coffee makers tank.
2) pour 4 cups of acetic acid also in the coffee makers tank.
WARNING !!! ALWAYS pour ACID into WATER and NOT the opposite !!!
If you pour water into acid, it can explode and cause severe damages !!!
3) Let it run through the coffee maker.
4) pour hereafter water in the tank and let it run through 2 times.
If this does not help to decalc your coffee maker, it is time for a new coffee machine.
Good luck
Aug 22, 2011 | Keurig Platinum B70 Coffee Maker
My Keurig has not been filling up the cup all the way lately. Last night the descaling light came on. We put white vinegar in it, ran it, and then water. Now it is not working at all. The machine is...
Sometimes the descaling sets off another whole set of problems...
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Mar 24, 2011 | Keurig Platinum B70 Coffee Maker
Keurig Platinum B70 Coffee Maker Logo
1,520 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
