Question about Gateway 835GM (835GH) PC Desktop
My monitor would not come on after a thunder strom. Llights flickered off & on. I have installed a new motherboard. Montior will still not come on. Also my computer fans on the power source will not start.
    Sergeant:
    Champion:
  • 324 Answers
Do you have a surge protector? if not then you probably popped the little fuses in the back of the monitor, at the very least.. you could have blown a diode as well, as far as the comp, see if it has a fuse, it should be close to where the power comes into the machine
Posted on Sep 12, 2010
Testimonial: "Thank you"
Got a flickering in my video, installed brand new
You may have failing power supply or inverter circuits, or worst, the lamp asemblies.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Free services manual: http://elektrotanya.com/?q=showresult&megnev=ACER&megnev2=AL2017&kategoria=&kat2=all
May 10, 2010 | Acer AL2017 20" LCD Monitor
Got a flickering in my video, installed brand new Video card. No change. Unplugged everything, except monitor (I meam mouse & all). Still flickers Monitor Acer AL2017
I had this problem once. Turned out to be the VGA plug connecting to the computer. Make sure this is inserted at the computer properly. Wiggle the plug and see if that effects the monitor display. If it does, then replace the VGA lead. Also check that your video card is inserted properly and go into the BIOS on your computer and make sure that the onboard Video chip is disabled (if your motherboard has one). If all this doesnt correct the fault, try uninstalling and installing the video driver again. If you are still having problems you may have a faulty video card.
Mar 17, 2010 | Acer AL2017 20" LCD Monitor
My Monitor is flickering. I changed the monitor twice (CRT & LCD). But the problem does not solve. I read few forum, they said it is a common problem of magnatic field by TV, Refrigaretor, etc. But now...
if you can borrow a compatible video card to some of your friend replace it if your monitor still flicker then change the psu of your pc, hope this help
Sep 18, 2009 | Computers & Internet
Ethernet has stopped working. there is no problemb
Thats not good bye a new cable or it destroyed the connection
Jul 30, 2009 | Microsoft Xbox 360 Console
ECS L7VMM2 Rev 1.0a motherboard I keep getting 1sec beep
did your new montior come with driver disk ?
if not look for the maker online and see if you can find the drivers for it ..
Jul 12, 2009 | EliteGroup L7VMM2 (L7VMM2 NO CARD READER)...
External montior is blank
Are you sure the laptop is powering up?
Do you hear the laptop boot up and the hard drive spinning and the power LED is on when you connected the external monitor?
The monitor must be powered up before the laptop for the video info to switch video port automatically.
If the external monitor is blank then you can't make it work, your video card is faulty and it is not possible to replace as it is built-in on the motherboard. You could replace the motherboard but this may not be a cost effective solution,
May 05, 2009 | Dell Latitude D610 Laptop Computer -...
Montior in Sleep mode
Take out the newly installed memory chip... If your sure its compatable with the motherboard, reseat it correctly into it's slot and fire up the computer. OR try rebooting with just the old memory installed. Monitor blackouts happen when the incorrect Memory is installed OR when the Memory is not seated properly.
stop chasing video and monitor problems...... :)
Regards..
Mar 27, 2009 | E-Machines eMachines Desktop PC
Montior
okay make sure your plugging the monitor back in securely
Either you need a new monitor or video card if what you are saying is correct did the video card in your system become lose
Jan 18, 2009 | Acer Aspire T135 PC Desktop
MOTHERBOARD DRIVER
Well it is not the computer that has a problem... It's your monitor, it needs to be checked by a technician to fix those cold solders that causes the flickering on your screen.
Have it repaired then... Fixya me okay..
Feb 11, 2008 | Intel Motherboard
Gateway 835GM (835GH) PC Desktop Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
