Question about IBM ThinkPad T30 2366 Notebook
Says sytem been tampered with code 0176 - IBM ThinkPad T30 2366 Notebook
    Guru:
  • 277 Answers
0176 error meaning the system cover had been opened. To fix this error, you need to enter CMOS setting or BIOS setting. press F10 to save before exit. Then the error will be gone.
Did you ever open the system cover before this error happened?
Posted on Sep 13, 2010
I have a iBM t40 2373 Thinkpad when i turn it on i get 2 codes one is 0176 and the other is 0271
The first code is a tamper alarm indicating that the case has been opened and the second code is complaining about the time and date settings. It may just be that the cmos battery is dead and needs replacing because you will also get a tamper warning if the system thinks the battery has been disconnected. A lithium ion battery is good for about 10 years and this computer came out in 2003. Reboot, go into the setup for the bios, set the correct time and date. If this doesn't do it, you need to replace the battery and then configure date/time.
Nov 06, 2016 | IBM ThinkPad T40 2373 Notebook
How do i remove fault 0176 from my z60t thinkpad ?
Go to the BIOS and cancel it. The code was caused by tampering with the laptop.
Nov 07, 2015 | Lenovo ThinkPad Computers & Internet
How can i remove the 0176 fault on a lenovo z60t?
You need to enter BIOS and reset the tamper warning.
Nov 06, 2015 | Lenovo ThinkPad Z60t (2511-ECU) 14in....
Error 0176 ibm
Lots of issues with 0176 error. Could be caused by a dead cmos battery or the system thinks it has been tampered with. I found a couple of clues for you;
The T41 Hardware Maintenance Manual gives the following instructions in case of error 0176:
"Run BIOS setup utility, and save the current settings by pressing F10."
To get into BIOS, you need to press the F1 key when you see the splash screen. I suppost that the splash screen on a T41 will display a ThinkPad or IBM logo, and something similar to "to interrupt normal start procedure, press the blue thinkvantage button".
The idea that a new motherboard might be necessary comes from the T41 Hardware Maintenance Manual. It says that in case the first instruction, i.e. get into BIOS and save current settings, doesn't fix the problem, a new motherboard should be installed.
You could try the following:
Disconnect the AC adapter from the notebook, disconnect all other cables. Remove the battery pack. Press the power button ten times in one-second intervals. Then press the power button again, and hold it pressed down for 30 seconds. Then install the battery pack again, connect the AC adapter. Press the power button.
Re: 0176 Security - The system has been tampered with
The padlock came up after removing the BIOS-battery. It is a security-feature and cannot be bypassed.
Removing the BIOS battery does not remove the supervisor-password but locks the system, if one hat been set to protect the computer from illegal use.
So either try to get the SVP from the previous owner ore replace the board.
Mar 20, 2014 | Lenovo ThinkPad R60 Notebook
0176 code error what can i do to fix the problem
What were you doing to get this error code? When does the error appear?
Apr 09, 2012 | IBM ThinkPad X30 2672 Notebook
0176, enter CMOS setting or BIOS setting we do this but error not removed
0176 System Security. The system has been tampered with.
  1. Run BIOS Setup Utility. Then save current setting by pressing F10.
  2. System board
Feb 10, 2012 | IBM ThinkPad T42 Laptop
THINKPAD R40 TYPE 2682
search the internet, most BIOS manufacturers leave a back door for problems like this.
Sep 18, 2009 | IBM ThinkPad R40 2722 Notebook
Hp 4288 all in in one scaner is not working
Suggest the following
1) if not installed - install service pack 2 for vista - remove and reinstall HP software.
2) remove any software for Kodak digital Cameras (found by Googling and may not work)
3) Contact HP ;-)
Jul 07, 2009 | HP DeskJet F4280 All In One Printer InkJet
Trouble resetting error code on my t-30,error code reads 0176
Error code 0176 concerned with System Security. The system has been tampered with.
Try to enter the bios setup. Save the bios setting and exit. Lets see if it resolves your problem
Nov 25, 2008 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T30 2366 Notebook Logo
489 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
