Question about Hobart Handler 187 MIG Welder 230 Volt 180 Amp
I have a handler 187 would like to use a dp-3035 spool gun . they say i have to use a kit # sga100 can i direct wire the spool gun cause the direct plug gun is a lot cheaper than the straight 3035
  • 407 Answers
NO you need the SG100 to control the wire speed.
Posted on Jan 12, 2011
Anyone know what spool gun I would use on a miller syncrowave 300(s) welding machine. I think it might need an adapter but not sure.
  • You can contact direct, but here are some links.
  • Miller Spool Guns for Aluminum and MIG Welding - MillerWelds https://www.millerwelds.com/accessories/guns-torches/spool-guns Spool Guns. Spoolmate™ 100 ... Reliable direct connect Spoolmate™ 150 spool gun provides 20 ft of cable reach and accessibility. ... Miller respects your privacy ...
  • AD/4.6 Syncrowave 210 Series - English - Miller https://www.millerwelds.com/~/media/miller electric/imported mam... · PDF file Syncrowave ® 210 Series TIG/Stick/MIG ... Miller Electric Mfg. Co. ... Spoolmate™ 100 Spool Gun #300 371 Includes 12-ft. (3.7 m) ...
  • Miller Spoolmatic 30A Spoolgun 130831 - Cyberweld.com store.cyberweld.com > ... > Miller Spoolguns & Spoolgun Adapters
    • 5/5
    • 11 RATINGS
    • $1,013
    Miller Spoolmatic® 30A Spoolgun is the professional's choice for ... connect to a Miller 300 pro we would ... spool gun plugged into our Miller ...
  • Manuals & Parts - MillerWelds https://www.millerwelds.com/support/manuals-and-parts ... operations/setup information, and maintenance to troubleshooting and parts lists, Miller's manuals provide detailed answers to your product questions. ...
  • Re: Miller syncrowave 180sd & MM 185 w Spool Gun weldingweb.com > ... > Shop, Trade, Sell Forum
    • 3 POSTS
    • FIRST POST: 2013-04-19
    2013-04-25 · Re: Miller syncrowave 180sd & MM 185 w Spool Gun ... The Syncrowave has about 300 hrs. run time and 350 Arc Starts ... Miller syncrowave 180sd & MM 185 w Spool Gun
  • Spool Gun Hookup Chart - MillerWelds https://www.millerwelds.com/.../spool-gun-hookup-chart Find spool gun hookup information for Miller welders. Determine which spool gun works with each ... Spool Gun Hookup Information. ... Millermatic® 300 without Meters:
  • Spool Gun Hookup Chart MillerWelds
    Jun 10, 2016 | Miller Welding Tools
    Can I use my spool gun with steel wire
    you can use spool gun but-you won't be able to switch it to aluminium-if you don't do al not a problem-and spool doesn't hold much wire-gun is heavier and big -not able to get into tight or angled places-cheers Denny
    Nov 04, 2013 | Welding Tools
    Spool won't turn
    are the rollers tightened enough, also maybe the wire is jammed in gun.
    Feb 02, 2013 | Hobart Handler 125 115 Volt 30 To 125 Amp...
    Hello, I would like to purchase 3035 spool gun and attach it to my self made welder. Could somebody to tell me which power supply I have to provide for spool gun motor? DC voltage, amperage ? Can I use...
    the spool gun is a 12volt motor, i usely hook it to the power feed for the feed motor in the welder. it is also 12 volt . i have heard of some welders that have 110 volt feed motors but have not seen one yet but just to be save i would test the power feed to the feed motor before i made the connection.
    Mar 11, 2011 | Hobart Handler 210 Wire Feed MIG Welder
    My hobart handler 120 will not feed wire. took the feed motor off and tested. Its good. checked the trigger connections and they are both in good shape. The gas valve does click when the trigger is pulled....
    First take our the spool of wire, then without any wire restriction, disconnect the gun from the machine and bridge the trigger connection, if the solenoid valve opens then the motor shoulod run. If it does, then check the trigger on your gun, take it off and bridge the cables, if it runs then your trigger switch is faulty.
    Dec 28, 2010 | Welding Tools
    Welding aluminum and wire keepscoming out of rollers
    your hobart machine it's not suit up for standard aluminum welding, the lenght of the gun it's too long therefore the wire will nest at the drive rolls. You need to buy a spool gun. Or change gun liner for a teflon one (instead of metal one), then change the drive roll for knurled ones and finally oversize your tip if you can. No need to do ALL this if you buy a spool gun.
    Oct 24, 2010 | Hobart Handler 140 Mig Welder
    My fm140a will not feed wire
    You may need to adjust the tension just in front of the wire spool
    Your gun liner maybe shot
    Dec 28, 2009 | Hobart Handler 125 115 Volt 30 To 125 Amp...
    Sporatic wire feed not smooth wire seems to be jumpy
    This has happened to me when I tightened the wire spool too tight in the welder,or I had a bad tip that caused some binding,and once my cord had a small kink that damage my wirefeed cord I had to replace.
    Jul 12, 2009 | Hobart Handler 125 Ez
    Wire burning betwen rool and feed drive
    When you pull the trigger the entire spool of wire and anything metal that touches it becomes electrically hot. If the tail end of the spool is hanging loose and touches something on or connected to the chassis it will do that, and could have welded the connection so it's solid.
    May 13, 2009 | Hobart Handler 140 Mig Welder
    Need wiring schematic for miller 140 wire feed welder
    No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
    Dec 27, 2008 | Miller matic 140 Mig Welding Package W/As...
    Hobart Handler 187 MIG Welder  230 Volt 180 Amp Logo
    181 people viewed this question
    Top Hobart Welding Tools Experts
    Matt Olenzek
    Matt Olenzek
    oneStan
    oneStan
    Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
