Question about True GDM-69 Refrigerator
How can I replace the transformer on True GDM-69 for the interior lights? Is it accessed through the interior ceiling of the refrigerator?
  • 531 Answers
SOURCE: gdm 69 true cooler wont cool. smels like its
check compressor or fans
Posted on Apr 06, 2009
  • 1078 Answers
SOURCE: true gdm-69
http://www.truemfg.com/pdf/InstallManuals/GDM/gdm_english.pdf
The above will take you to the installation manual for your unit. This is to make sure you have set up the unit to their specs.
There are multiple things that can cause a lack of cooling. Let's cover a few of them.
1: Make sure the condenser coil under the unit is clean. You have to be able to take a flashlight and see light through the coil and fins. Be sure unit is off when cleaning. Use vacuum, compressed air, or a long, stiff bristle brush and go with the fins direction so they do not bend over.
2: The termostat may be set wrong or is not working as designed. Look for the compressor and fan on the condenser to cycle off when temp is met and on when it gets too warm. If unit is running all the time, look for frozen up evap.
3: If evap is frozen up, no air can pass through so no cooling is taking place. Air can not go through a solid block of ice. Clear ice with warm water. Again, make sure unit is off first.
4: Door not sealing or closing all the way. Seal on door should have magnets that help seal them to the door frame.
5: Again, if unit is running all the time, as in #2 above, unit may be low on refrigerant (freon). If you suspect this to be the case, have a qualified tech do the repair. Make sure he locates and repairs the leak. Adding freon without the repair means he will be back to do it a second time. The system is a sealed one and you should not have to continually add freon.
Good Luck and hope this get you going.
Posted on May 10, 2009
  • 906 Answers
SOURCE: GDM-41 Refrigerator: True GDM-41 Refrigerator getting too cold...
good day,
hope this link below will solve your problem.
ref
Posted on Aug 03, 2010
heatman101
  • 43501 Answers
SOURCE: Some of the refrigerators True
If you check into it further I think you will find that the units are low on freon and the coils are froze up causing the leaks....
Turn them off let them defrost and then have the correct charge placed in the system.....
They will work well, and also save you money because they will run much less...
heatman101
Posted on Dec 27, 2010
heatman101
  • 43501 Answers
SOURCE: I have a True refrigerator
You will need to find out why the unit is not shutting down properly....
It may be that the thermostat sensor will need to be placed in a different spot...or the temperature may just need to be raised higher...
Does the thermostat turn off the unit if the temperature is raised??? If so, then place a thermometer in the cooler and then adjust the thermostat to 38F by that thermometer and not by the t-stat calibration, it may be off even if it is new...
If the t-stat is not cycling the unit then you will need to use an electrical meter to trace out the power to the unit and find out why it is not shutting down...
heatman101
Posted on Mar 31, 2011
What size light bulb for a GDM 12 coke fridge
  • Safety shielded fluorescent interior lighting.
  • Cabinet lighting utilizes electronic ballast and T-8 bulbs for brighter illumination, longer bulb life and increased energy
  • Remove yours and take to THD or Lowe's. Could call first; make have to go to specialty lighting store if not available at the DIY stores.
    Mar 05, 2014 | True GDM-12 Refrigerator Commercial
    Model GDM-69
    A GDM 69 three doors. Each door closes using a string attached to a weight, which runs through pulleys or copper tubing, and is held to the top of door. The pulleys or copper tubing can be accessed by removing the aluminum siding located inside cabinet on either side. The left side contains the pulley and weightfs or left and center door, the right for right door (each held on by 4 1/4 screws) . To make the door close, simply make sure string is attached to weight, running though pulley, and attached to top of door.
    Nov 07, 2013 | True Refrigerators
    Cant get my GDM 69 to go below 40, seems to cycle fine just won't go any lower even after turning the thermostat knob
    Unplug the unit. Clean your condensing coil, the one by the compressor. Nothing fancy, just get a narrow plastic or brass wire brush and follow the lines of the coil fins. If you like, spray in some heavy duty de-greaser like you use around your restaurant and rinse thoroughly.
    Sep 11, 2013 | True GDM-69 Refrigerator
    Where do i find the starters for the florescent lights on a true gdm-72
    They should be located under the front access cover below the door. Under that cover there may be another smaller covered box that they may be located in.Make sure you disconnect the power source before removing any covers.
    Nov 12, 2009 | True GDM-72 Refrigerator
    Flourescant lights flickering
    is there a ballast or a starter? if there is a starter (little silver metal or white plastic can), then replace the transformer inside the lamp housing. if there is a ballast (long black rectangle with many wires) and you replaced that and the lamp, then there must be a power drain in the unit somewhere.
    Aug 25, 2009 | True GDM-12 Refrigerator Commercial
    Both lights went out at same time , replaced them still doesn't work .. Is it a Fuse ?? Where is the fuse box ?
    Bad ballast. Located in the frame work under the door.Take off the panel to access it.
    Jul 14, 2009 | True GDM-69 Refrigerator
    Interior Lighting on True Refrigerator Unit
    A starter may be located in the top area inside the cooler. Not all true coolers have starters. Check the connections where the light pins slide into. Also may need new ballast.
    Jul 24, 2008 | True GDM-9 Beverage Cooler
    True GDM-69 Refrigerator Logo
    49 people viewed this question
    Top True Refrigerators Experts
    Dennis Boxerman
    John Tripp
    John Tripp
    christian nielsen
    Are you a True Refrigerator Expert? Answer questions, earn points and help others
