Question about Daewoo DSP4210GM 42 in. Plasma Television
Daewoo DSP4210GM 42 in. EDTV Ready Plasma TV
Hi All, HELP!!
Just got given a Daewoo DSP4210GM 42 in. EDTV Ready Plasma TV this afternoon, We tested it in the office on a pc it worked fine, we turned it on with only the poer supply connected it said no input signal, everything was fine...i got it home less than an hour later plugged it into the wall, turned it on the screen very briefly lit then went off..now only the power light comes on, it comes off of stand by and the light goes green but the tv justmakes a buzzing noise for around 3 seconds then makes a click noise as it urns off...nothing! but the green power light stays on help help help me!!
regards
Daryl
07910359590
  • dazza12345 May 14, 2008
    I carried the tv with a friend for about 3 mins I live round the back of the office, we didnt knock or bump it or drop it?
    once in doors we laid it flat on its front on the carpet, attached the fittings for the stand and that was it?
    just tried turning it on again..still the same problem.
  • Anonymous Mar 16, 2014
    turn on tv with remote green light comes on for 3to4 seconds and then goes back to standby
I have exactly the same model and exactle the same problem with this plasma TV, please is someone knows a solution for this I would be most grateful?
Posted on Aug 11, 2008
Hi a quick update on this, when I turn the tv on the screen flashes for a split second then turns off? an y ideas anyone?
seems as though it turns on, buzzes then turns off am thinking of drop kicking it!! HELP
Posted on May 20, 2008
    Problem Solver:
  • 12 Answers
What way did you set the tv in the transport vehicle. something has been knocked loose inside or the videomask has been damaged?
Posted on May 14, 2008
Hi, my Daewoo Plasma 42"
If the power light stays green then the current absorbed by the different boards appear to be normal. If that is the case then most likely you have a bad contact in the data cables or in the mainboard.
You will need to open the tv, inspect for damage and reseat all the components then (if that doesn't fixes it, you will need to extract the mainboard and check the soldering on the board and the status of the processor.
Jul 24, 2011 | Daewoo DSP4210GM 42 in. Plasma Television
Broken plasma screen on the TV screen
You just need to purchase another TV. Panels cost as much if not more than a new TV.
Apr 14, 2011 | Daewoo DSP4210GM 42 in. Plasma Television
Hi my plasma tv doesn`t switch on?
could b flyback transformer, hard to tell with out benc testing , no power is cheaper to fix than picture problems and normally a lot less God Bless
Apr 15, 2010 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Restore factory bettings
Hi friend,,,
welcome to fixya
I think the installation manual is provided with your Haier 42EP24S 42 in. EDTV-Ready Plasma Television,,,check the manual sure there will be given How to restore settings,ok...
if your satisfied with my solution PLEASE RATE IT
thank u...
Apr 09, 2010 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Black vertical line about 3 inches wide from top to bottom on rig
See if you can center the picture in the setup menu. It sounds like it's just off center.
Jan 15, 2009 | Daewoo DSP4210GM 42 in. Plasma Television
Broken glass on plasma tv
The glass is part of the screen. It will probably cost more to buy the part than a new TV would cost.
Dec 08, 2008 | Daewoo DSP4210GM 42 in. Plasma Television
SCREEN PROBLEM
he same problem with my deawoo plasma
Sep 26, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Flicker
I had the same problem with the flicker. Mine was a Flicker followed by a greenish line through the screen. It got worse then after 2 months the tv stoped working the power didnt come on at all. I Im taking it to bget fixed. The guy said it has somthing to do with a burnt out switch in the unit.
Oct 13, 2007 | Daewoo DSP4210GM 42 in. Plasma Television
Daewoo DSP4210GM 42 in. Plasma Television Logo
388 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
