I have a boiler ( hot water heat) oil fired. Can I convert this boiler to propane?
  • 455 Answers
Hello YES! They have power conversion burners for that.Make sure you ask for a L.P. conversion kit as some can ship already set up for natural gas.Try CARLIN.com
Posted on Sep 13, 2010
Boiler won't ignite for hot water unless heating is on.
If this is in a RV the propane monitoring valve may require more gas flow to turn on than the water heater requires. A central heating system requires substantial gas flow so when the monitoring valve opens to fire the central heating, there is enough gas flow to also fire the water heater.
Jan 26, 2016 | Water Water Heaters
Boiler ok for hot water but no heating
What boiler do you have and is the controller a radio controlled thermostsat
Dec 14, 2014 | Water Water Heaters
Boiler ries to fire on heating or hot water but then shuts down after 10 seconds to F1 with the flashing red light, any ideas. clearly same principle as any boiler but I'm looking for someone who has...
that would indicate that the boiler is not firing up
If oil fired, been there done that
it is out of oil
the oil filter is clogged
the nozzle could be clogged/burned
the igniter wires need adj/replacement
if gas fired - similar issues but no experience
Dec 08, 2014 | Water Water Heaters
I have a Heatslave 12/14 oil-fired combi boiler installed approx 8 years ago. A problem has just developed on the domestic hot water side. My local heating engineer has investigated but so far hasn't...
Symptoms sound like crossover might be part of problem:
Crossover is when cold water enters hot water line due to faulty plumbing part like check valve, mixing valve, or bad faucet cartridge.
http://waterheatertimer.org/Crossover.html
Jun 12, 2011 | Bosch Water Heaters
I need a diagram for an indirect hot water system heated by a solid fuel boiler and an oil boiler
If you are using more than one heat source you will have 1 more pump than the heat source pumps Main pump = SYSTEM pump pumps through the indirect hot water system and back into itself. This is the system loop. The other two boilers tee into this loop upstream of the indirect tank, downstream of the SYSTEM pump. The cold water return to each boiler tees into the system loop next to and upstream of where the hot water for that boiler tees into the system the loop. The oil boiler will have its own pump on its return line from the sytem loop and the solid fuel boiler will have its own pump. When any boiler fires, it turns on its own pump AND the system pump. If you want a drawing email me -pipesster@gmail.com send a fax number and I'll fax you a drawing.
Jan 15, 2010 | Aquapure AP431 Hot Water System Cartridge
Amtrol 41 hot water maker :not working when calling for hot water,contols are on showing temp,but tank is cold.oil fired boiler is fine,the whole system is 5 yrs old.
The problem is probably with the circulator pump or the zone valve, which ever way your water circulating from the boiler is controled.
The water needs to be moved through the boiler and the coils in the Hot water maker to heat water. If this is not happening then no water will be heated.
Check for power and then is the pump is running or the zone valve opening.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 21, 2009 | Dishwashers
Alpha 240e boiler wont fire up for hot water, will for heating
most likely the diverter valve.. when hot tap turned on the movement of the water through the valve operates a diaphragm which pushes a pin/button//switch to tell the boiler to fire up
Aug 21, 2009 | Water Heaters
Have an oil fired boiler for baseboard heat and it also has a tankless heater for domestic hot water. No heat being called for only getting hot water for use. Boiler goes to 210 degrees before it knocks...
These boilers usually have multiple controls. The control that would take it out of the circuit at 210 degrees is a safety.
You should definitely have a professional take a look at this unit before you continue using it.
Sep 18, 2008 | Heating & Cooling
Heating & Cooling Logo
65 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
