Question about Vizio VO47L 47 in. LCD TV
How do i switch channels on my pip Vizio 47" HDTV
pgh_pa_guy
  • 2992 Answers
SOURCE: HDTV CHANNEL NUMBERS
Channel numbers depend on the station, not your TV. Check the channel listings in your local paper for channel assignments.
You can also go to www.antennaweb.org and click on the "choose an antenna" button. This brings up a page that asks for your address. It wants this information to pinpoint your location, but all you need to give is your zip code. Continue through the next couple of screens and you will get a list of all the stations in your area and their distances. The channel number information is there as well.
Please take a moment to rate this solution a fixya, and thanks for asking here!
Posted on Mar 22, 2009
  • 13 Answers
SOURCE: vizio remote
The remotes for the TV and Direct TV box are universal remotes that can operate very basic functions for whatever else they are programmed to control. If you can program the TVs remote to operate the Direct TV box it will basically only control power and channel. Maybe something else, but not much. The same goes for the Direct TV remote. It will control basic functions on the TV; power, channel & volume. Best bet would be to purchase a universal remote that can learn functions from the original or just keep both remotes available by the TV.
PIP (Picture In Picture) - Your television should have the capability because it has two built in tuners. It can show two channels at the same time or show one channel and one video source (whatever is connected to the audio/video inputs). However, because you are using DTV (Direct TV) you are very limited because you are not using the built in tuners on your television. You should be able to see one picture from the DTV channel and one from lets say your DVD player. If your DTV box has two tuners built in then you should have the PIP capabilities from your DTV and not your television. I'm guessing your DTV is a single tuner (one satellite cable to your box). If you want to watch two different channels you'll need to either upgrade your box or attach another box to your television.
Option: you could also connect an antenna to your television this way you can use the PIP function. Obviously you'll only be able to view whatever local stations you can get with the antenna. Depending on where you live you might or might not have a lot of channels to choose from.
Posted on Apr 19, 2009
SOURCE: Vizio 47'' LCD HDTV (Model SV470M). This TV is
I have been having the same problem!! Did you get a solution? Thanks for the help!
Posted on Feb 23, 2010
  • 5 Answers
SOURCE: I got a top of the line 47
maybe your t.v. doesn't have that feature call up manufactor to see if it does
Posted on Mar 10, 2010
milkburp
  • 416 Answers
SOURCE: Vizio 42 in TV LCD HDTV white line across to of
That white line (usually jagged) is actuallly part of the transmitted picture. However, you are not intended to see it because it is located in what is known as the 5% overscan area. Your TVs today are more than just cable ready... they are a versital, technology filled multimedia display. You can see that line because the screen size or wide mode you are using is intended for 1080p/24 signals. You have 0% overscan with this screen size setting. This allows you to see ALL of the picture, including portions of the picture the broadcaster did not intend for you to see. You can change your screen size using the Wide feature in the Setup menu. See pg.62 of your user manual for details and descriptions of the various wide modes.
Posted on Mar 14, 2010
What symptoms will a bad tv board/tuner cause
That does sound like the most likely issue is you MAIN PCB. You will need your complete model/serial# then see the following web site:
https://www.encompassparts.com/model/VIZM470SL/_/_/VIZIO/M470SL/47-INCH_120HZ_EDGE_LIT_RAZOR_LED_LCD_HDTV
Mar 11, 2015 | Vizio M470SL 47 in. LCD HDTV
Where can i get a new screen for my 47"vizio hdtv
Ouch, will most likely cost as much as a new set. You can try Shopjimmy.com, retechtv.com, or EBay.com
Jan 17, 2013 | Vizio Recertified - 47" Class 46.96" Diag....
VIZIO E470VA LCD HDTV Dish Hopper remote doesn't change volume
Try another remote code, many of the Dish or Cable TV remotes will have multiple codes for a particular brand of TV's
Sep 01, 2012 | Vizio E470VA 47 in. HD-Ready LCD TV
My Vizio SV472XVT 47" HDTV
Unplug the TV from the wall. There must be something wrong with your circuit board. Call customer service for what to do to fix your TV or get a new one.
Mar 05, 2011 | Vizio SV472XVT 47 in. LCD HDTV
I have a Vizio 47 inch LCD HDTV hooked to a Dish system. The volume fluctuates from very loud to very soft between ads and programs. It also goes from moderate volume to very soft within a program. Help!
Either unplug dish from tv or use the antenna side which is HD and program channels and see if volume the same, if not and is OK then it's your Dish bring your sound down or audio cables bad.
Feb 18, 2011 | Vizio E470VA 47 in. HD-Ready LCD TV
How to split the screen to look at 2 channels.
try looking under your TV's menu, find the pip or split option and set them up, then on your remote, you should have a pip/split button..see if you can now watch tv with pip or split. If you need more help please be more specific about what the tv is doing when you push those buttons on the remote etc.
Dec 27, 2009 | Panasonic PT-47WX53 47" Rear Projection...
I want to load my tv code from my vizio on my remote for my 321
I used 0178 to program my universal remote. You can also try 10056, 10178,10864,10885,11756,10056,11758, and 11499. Then you can try by dropping the "1" from the front of these codes.
Most good remotes have a programming function if this does not work, where the remote will "learn" the proper code.
The actual button remote codes are as follows:
0 00117
1 00121
2 00119
3 00123
4 00116
5 00120
6 00118
7 00122
8 00245
9 00249
Vol + 00183
Vol - 00187
Mute 00057
Channel + 00181
Channel - 00185
Power 00053
Enter 00164
Last 00247
Menu 00171
Guide 00244
Up 00168
Down 00166
Left 00170
Right 00037
OK 00164
Sleep 00054
PIP 00197
Info 00251
PIP Swap 00198
PIP Mode 00199
Exit 00216
Audio 00059
Input 00090
Wide 00138
TV 00110
AV 00105
Component 00231
HDMI 00174
MTS 00055
CC 00025
Zoom + 00165
Zoom - 00169
Freeze 00200
RGB 00253
PIP Ch + 00196
PIP Ch - 00203
PIP Input 00199
PIP Size 00201
Good Luck
Nov 30, 2009 | Vizio VW32L 32 in. LCD HDTV
47" Vizio Flat screen HD LCD freezes up and remote will not work.
could it be Ch 9's digital signal is not broadcasting right? what is your refresh rate on your tv? 60 or 120hz? if its 120hz, then its more then likely the digital broadcast, if its 60hz I think its your tv can't keep up with their signal that may be at 120hz. Make since??
Jun 16, 2009 | Vizio VO47L 47 in. LCD TV
Vizio remote
Apr 19, 2009 | Vizio L32 32 in. LCD HDTV
Vizio VO47L 47 in. LCD TV Logo
47 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
