Hotpoint wma57 Hi, My Washing Machine Was Needing New Brushes Which I Bought And Fitted, Unfortunately I Didn't Notice When Removing The Old Ones What Position They Were Lying In And Have Now Found Out I've Put Them In Wrong.Can Someone Let Me Know At What Angle To The Motor Should They Be As They Fit More Than One Way ?????
The filter is at the back where it enters the machine undo the cover you will see a big black tube clipped in a few places undo and the filter is inside there
Posted on Dec 23, 2008
Sorry, haven't got a clue but perhaps you could help me by telling me where the filter is?
Would really appreciate. Have lost manual.
Many thanks.
Jacckkie
Posted on May 26, 2008
Where are the carbon brushes in this model
Hi Thomas , the machine is fitted with a polyphase induction motor and has no carbon brushes .
Nov 19, 2012 | Hotpoint Ultima WF860 Front Load Washer
How to fit a drive belt on a wma57
Please check on this link for tips to fit a drive belt.
click on : drive Belt
Sep 02, 2012 | Hotpoint Washing Machines
Where can i download the user manual fior a wma57 for free
I can send you a hotpoint wma57 manual free it covers wma56 to wma59 /wma53/ allthough it does not say wma57 this will cover your machine I will email it to you if you give me a email address all i ask is that you give me a top rate thanks ****
Dec 11, 2011 | Washing Machines
Hi how do i fix brushes to a hotpoint wm52 washing machine
Remove lower rear cover of washer
Remove drive belt.
undo 2 bolts securing motor to drum.
Push motor away from you, it may be tight.
Unplug motor lead, noting which way it is plugged in.
Remove earth lead.
You will see the brushes at the rear end of the motor
There are several types of brushes fitted to these washers, it all depends on the type of motor you have, but all the brushes are readily available.
Reassemble in reverse order.
Please your comments.
Thanks
Barkencoa.
Nov 25, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Fitting new belt on hotpoint washing machine
check if plug is loose on motor,in the general area where the belt was changed has anything been disturbed,cables i mean?,sounds like the motor brushes may be worn(this would cause motor to stop),they are situated 180degrees apart at one end of motor,they are easy to change,there is a spot at brushes to put a screwdriver in to remove brushes-hope this helps
May 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washing machine not working
My suggestion would be to use a ,Hair Dryer to dry out areas effected. Please make sure that Washer is Unplugged first.
Thanks
George
Apr 30, 2009 | Hotpoint WMA58 Front Load Washer
Washing machine brushes
what make of washer is it
Jun 09, 2008 | Bosch Washing Machines
Fitting new brushes on a hotpoint washing machine
Remove lower rear panel.remove drive belt, undo screws that secure motor. unplug motor lead, noting which way it is fitted.,lever motor back and remove, replace brushes and refit motor and belt.
Mar 30, 2008 | Hotpoint First Edition FEW10P Front Load...
Washing Machine 1200 Aquarius- Hot point- will not spin?
hotpoint use two types of brush depending on the motor. if motor mounted at top of machine, brushesw are clip in and very easy to replace. look at new brush and you will see how it clips in. no need to remove motor. if motor at base of machine, brushes are screwed in with two screws per brush. rather fiddly to do in situ and you may be better of removing motor and doing job in an easy position
Apr 27, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WM 62
Hi, Does the drum turn during the wash cycle? When it comes to the spin cycle does it go through to the end without the drum turning? It sounds like it could be the motor needs new carbon brushes. Regards, Tom.
Apr 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
565 people viewed this question
Top Washing Machines Experts
