Not all teh keys are functioning properly, keys like p,m,i,u show up as *,0,5,4 respectively...they only work properly if i keep teh function key pressed...nothing spilled on the keypad and i do not remember pressing anyother key...i dnt know what to do...kindly help...
Check to see if your shift, control, alt, or other modifier keys are stuck on your keyboard. These can cause your keyboard to act erratically. Also, if this is a wireless keyboard, you may need to change the batteries, as this can also cause a keyboard to act erratically.
Procedure
1. Press the COUNTER.
2. Press the following keys in this order:
STOP 0 0 STOP 0 1
3. Enter the code number corresponding to the function to be used from the KEYPAD.
4. Press the START.
<Exiting the Mode>
• Press the AUTO RESET until the initial screen reappears.
Here are some important informationabout Sigma S30.
Programming a New PIN Code: The standard PIN code can be changed following thesequence below: i) Type in to the keypad ** ii) Type in to the keypad the "existing PIN code" then * iii) Type in to the keypad 92 * "new PIN code" * "new PINcode" # Programming Remote Keys to the System: Remote keys can be added or removed to/from the systemfollowing the sequence below: i) Type in to the keypad ** ii) Type in to the keypad the "existing PIN code" then * iii) Type in to the keypad 91 * " the number of keys to beused" # iv) Press the first remote key button until bleep sounds,release and press next key. Continue until all keys have been taught to the system. Note the maximumnumber of keys is 4 and all keys required to operate the system must be taught during this operation- any key not included will no longer operate the system. Full Programming, Diagnostics and Features This section contains all the information that the dealersuse for programming and diagnosis of the Sigma M30 alarm system, using the MK1 keypadprogrammer.. Programming can also be carried out using a dealers CP1 programmer. MK1 Keypad Programming Introduction It is important the keypad buttons are not pressed tooquickly- Each time a button is pressed the LED on the keypad willflash once as confirmation. The next button should not be pressed before this confirmation. It is important the keypad buttons are not pressed tooslowly- When in programming mode, if a button is not pressed for aperiod of 10 seconds or more, the alarm will automatically exit programming mode. This will be confirmedby repeated flashes from LED on the keypad. You must wait until the LED stops flashing and then startagain. All programming functions are entered after typing * andthen the programming PIN code. The programming PIN code is 17856. To enter the programming PIN code, the alarm system mustfirst be armed and then disarmed using a valid remote key. (Or keypad using the PIN code) * 17856 * must then be entered within 30 seconds ofdisarming the system. This is then followed by a 2 digit function code, then another * and then sometimesoptional parameters as shown in the following tables. It is important to remember the * key is used to separatethe various parts of the code like this: * programming PIN code * function code * parameter #. The# key is pressed at the end of all sequences and is used like the "enter" key on a computer keyboard. Programming Features On or Off: Programming PIN Function Code Switch Code (where 0=off and 1=on) Function Default * 17856 * 00 * 0 or * 1 then # arm/disarm bleeps * 0 (off) * 17856 * 01 * 0 or * 1 then # door open warning bleeps *0 (off) * 17856 * 02 * 0 or * 1 then # auto-lock * 0 (off) * 17856 * 03 * 0 or * 1 then # auto-arm * 0 (off) * 17856 * 04 * 0 or * 1 then # auto-arm to include doorlocking * 0 (off) * 17856 * 05 * 0 or * 1 then # auto-rearm * 0 (off) * 17856 * 06 * 0 or * 1 then # engineer mode * 0 (off) * 17856 * 07 * 0 or * 1 then # hold-down remote key button= -ve output on wire 4 * 0 (off) * 17856 * 08 * 0 or * 1 then # hold-down remote key button = extends lock pulse * 0 (off) * 17856 * 09 * 0 or * 1 then # after disarm -ve output onwire 4 * 0 (off) Programming Timing Settings: Programming PIN Function Code Variable(s) Function Default * 17856 * 10 * 1 to * 30 then # stall to ignition on timein seconds 30 sec * 17856 * 11 * 1 to * 99 then # unset to ignition on timein seconds 30 sec * 17856 * 12 * 1 to * 99 then # panic time in seconds 05sec * 17856 * 13 * 1 to * 51 then # lock time in seconds (51gives two short pulses) 01 sec * 17856 * 14 * 1 to * 51 then # unlock time in seconds (51gives two short pulses) 01 sec * 17856 * 15 * 1 to * 99 then # settle time in seconds 15sec * 17856 * 16 * 1 to * 99 then # threshold setting time inseconds 15 sec * 17856 * 17 * 1 to * 99 then # auto arm time in seconds60 sec * 17856 * 18 * 1 to * 99 then # auto re-arm time and also-ve output time after disarm , on wire 4 (green/red) in seconds 60 sec Displaying System Diagnostics: The dashboard LED displays the value of settings as anumber of flashes. Programming PIN Function Code Function * 17856 * 30 then # time elapsed since last trigger (inminutes) * 17856 * 31 then # as * 30 above - but each flash = 256minutes * 17856 * 33 then # wire 7 (orange) ignition trigger count * 17856 * 34 then # wire 1 (blue) -ve door trigger count * 17856 * 35 then # wire 2 (blue/red) -ve boot triggercount * 17856 * 36 then # -ve bonnet switch trigger count (blacksingle wire on siren plug) * 17856 * 37 then # ultrasonic's trigger count * 17856 * 38 then # last trigger register (see tablebelow) * 17856 * 39 then # reset all above trigger counts to 0(zero) Setting Up Pre-set Programs: Keying in the following sequences on the keypad sets up afixed set of features, which can be used as a starting point for further tailoring: * 17856 * 80 # everything off, lock and unlock pulses 1second. * 17856 * 81 # as for * 80 above, with auto-rearm on. * 17856 * 82 # as for * 80 above, with auto-arm on. * 17856 * 83 # as for * 80 above, with auto-rearm andauto-arm on. * 17856 * 80 # Default setting configures the values shownin the previous tables 1, 2 and 3.
Hope this will help you. Good Luck.
Thanks for writing Fixya. I am Marion and let me help you with this.
There are reasons why your phones keypad is not working, first, have you tried re aligning your keypad if it fits exactly on the button, also, you may try pressing the keys without the keypad tofind out if the problem is just on the keypad or on the phones hardware already. Also, the keypads functionality may affect if it had a water spill or had dropped previuosly.
your laptop should have a blue FN key (Function) that will work in conjunction with other blue keys on teh keyboard. most laptops this is located in the lower left, next to the ctrl key. Look to the right top on your keyboard for a one labeled numlk. hold down teh left FN key and tap the right num lk key and you just turned off the numbers lock.
There is another option that is a little more intense - if interested let me know that laptop type you have.
You may have a bad key, or a key with something under it.
Try this:
Turn the netbook upside down so that the keysj face the floor.
Bang on the back side that way you would to burp a baby.
Then, take a vacuum cleaner and **** out the spaces between the keys.
If this doesn't work, you may have to make an @ symbol manually by using the ALT key. (ALT plus 64). This should work in most Word Processing programs.
Make certain that the Num Lock key has been pressed to activate the numeric key section of the keyboard.
Depress the Alt key.
While the Alt key is depressed, type the proper sequence of numbers (on the numeric keypad) of the ALT code from the table above.
Release the Alt key, and the character will appear.
On a laptop computer, there usually is no numeric keypad. So, instead, depress the Fn (function) key, then the Alt key, then the numerical code sequence. The numbers are on the fronts of certain keyboard keys: M=0, J=1, K=2, L=3, U=4, I=5, O=6, 7=7, 8=8, and 9=9.
I think your keypad is screwed up!! If you changed teh original keypad please put the original back. And keypad issues are not solved by software or tricks you need to contact service person to fix it!!
I found it by myself, I can help you.
1. Press (AC)
2. Hold (Rate) for about 2-3 second
3. Press (Set / TAX+)
4. Input the tax rate
5. Press (Set / TAX+)
6. Hold (Rate) for about 2-3 second again
7. Press (Set / TAX+) again
And Then you can test the rate .
