Question about Craftsman 20 Hp 42" Deck Lawn Tractor
I have a craftsman dlt 3000 and it will not engage. I cleaned out underneath and found fire ants living up in the drive column. They had only been there a week because that was the last time I had used the lawnmower and did not have a problem. The lawnmower starts fine but when I try to engage the blade it does not engage. Any suggestions?
SOURCE: Craftsman 18.5 briggs/str 42''won't cut
It sounds to me like a very loose belt or very worn out belt and also an adjustment problem.
Posted on Mar 24, 2009
joboo1
  • 257 Answers
SOURCE: Craftsman 18.5 riding mower when I engage the
Hi Jeff, If you look at the deck, one or more of those pulleys is a tensioner, It pushes against the belt to tighten it, The rest of the pulleys can be identified by the fact that they only have a bolt through the middle, whereas the tensioner is mounted on an adjustable arm with a slot to allow adjustment. It should also be the only one that the belt doesn't go around the pully it just pushes on one side.If the tensioner arm is all the way to the end of the slot, the belt is streched and will need replaced but sounds like it may have come loose. Some of these decks also have a spring on the tensioner arm and those come off from a stick or other debris. Check it out and if you have a problem let me know and I will try to come up with a diagram. If your mower is that new there should be a belt diagram on the deck. i will need a model number of the deck or mower for that. Good luck!
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Mar 29, 2009
  • 79 Answers
SOURCE: Craftsman GT5000: Dies when switch is pulled to engage blades
Hi
Check for burnt fuse behind dash. If no burnt fuses check if getting power to magnetic clutch mounted on bottom of engine crankshaft. Make sure wires are not broken by magnetic clutch. Make sure the safety seat switch is working. Make sure you are sitting on the seat when you try to engage the blades. If that does not work try pushing and wiggling the seat sensor. Check make sure wire is attached to safety switch under seat.
Posted on Apr 08, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
  • 77 Answers
SOURCE: Craftsman 18.5 42'' mower, blades won't engage
You deffinately have a loose wire or connection coming off that switch,youll have to investigate to find out where it is.
Posted on Aug 09, 2009
I have a craftsman DLT 3000 that is firing but not turning over i think its either the gasket or the piston rings that are bad because when i check the spark plug it looks milky
CONFUSED It will not fire if not turning over I have a 4000 that when it quit , it was because of a bent intake push rod .made of aluminum, replaced with an exhaust rod of steel and works well.
May 31, 2017 | Craftsman Garden
My Craftsman DLT 3000 Riding Lawnmower will not go into gear.Could something have come loose? a spring orwire to the mower?
At the rear of the mower at the very back is a transmission disingauge lever, it may be set, this lever is so u can easily push the mower when it is not running...!
Oct 26, 2014 | Garden
INSTRUCTIONS ANT 104
This is a very outdated post but, I have posted the installation guide here:
http://www.eserviceinfo.com/downloadsm/67093/Quantum_ANT-104.html
Jan 24, 2010 | Quantum DLT 4000 DLT Tape Drive
Craftsman rider dlt 3000 throwinng gas out muffler won't start can anyone help.
Turn off fuel and do not try to start because it can shear flywheel key or catch fire.It sounds as if the float needle is not seating {closing}properly and must be cleaned or needle/seat replaced.Check to see if fuel has raised oil level on dipstick,if so you must change oil as well as the oil filter.
Nov 16, 2009 | Craftsman Garden
Tractor won't go forward or reverse
Check the drive belt. It has probably broken or has come loose.
Sep 01, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
102 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
