Question about Poulan Garden
14 inch poulan chain saw air filter are they oil saturated or dry
    Brigadier General:
  • 4,088 Answers
Most are saturated due to the proximity to the carburetor throat which tends to spit fuel as it runs, especially at idle.
Posted on Sep 14, 2010
Testimonial: "Many thanks for the advice"
Poulan 2150 chain saw starts after priming and dies after a few seconds
Take the exhaust off so you can see the side of the piston, if it is scored or damaged it means it has probably been run without oil added to the petrol.
That can cause the problems you are having, if it is throw it away, its not worth repairing
Dec 14, 2012 | Poulan 2050 2055 2975 2150 2155 2175 Air...
How to put the chain back on a 14" Poulan electric chain saw
Remove the cover that cover the rear of the chain bar.Now,loosen the nuts that attach the bar and slide the bar reward.Now set the chain in the slotted part of the bar,pull it forward until there is abut 3/8 of an inch slack in the chain an tighten the nuts.Re-install the cover.
Sep 12, 2010 | Poulan 14 in. 2.0 Peak Horsepower Electric...
My poulan saw keeps stalling and has no power
Check the fuel filter, air filter, and muffler for clogging. Check the fuel lines for condition. The carburetor may need cleaning and re-kit. Make sure the chain is being properly oiled and sharpened. Good luck!
Jun 10, 2010 | Poulan PP4218AV 18" Chain Saw
Poulan Pro Chain Saw Bar Chain Oiler Stopped Flowing
The filter can usually be caught with a hooked wire and drawn up far enough to deal with the filter. Oil filters are not prone to plugging unless the oil used is contaminated. If you run the engine without the bar and chain attached, oil should ooze out of the engine side port. If nothing, suspect problems with the oil pump. Some saws use a plastic gear in the pump and can strip the teeth of the gear. You should find it located behind the clutch assembly. Once you have oil flowing from the engine, clean the bar drive-end oil ports that go from the large holes out to the chain groove on each side. Finally, run the bar tip near some cardboard--it should throw off a thin line of oil. I have no idea what the plastic tube might be (a manual pumper perhaps?). Hope this helps!
May 23, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Chain saw won't start
Check the fuel filter for plugging (which is common when fuel is left in the machine over winter storage). You should run the carburetor dry after emptying the fuel tank for storage.Hope this helps!
Apr 14, 2010 | Poulan Pro Chain Saw 46cc 20"
What is distance from coil to stator 14 in. poulan chain saw
I think you are asking for gap between the fly wheel and the ignition module. A business or index card works great. 0.1 - 0.3 mm. GL
Lou
Oct 09, 2009 | Poulan Pro Chain Saw 46cc 20"
I need t find an air filter for poulan 306a chain saw
I got 1 hit for your filter, if you haven' already give them a try "Poulan air filter 530023046"
http://www.lawnmowerpros.com/Poulan-Parts-Search.asp
Lou
Sep 04, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Do you use air filter dry or saturate with oil
The Poulan Wildthing air filter should be installed dry. It can be cleaned with warm, soapy water, rinsed well, dried thoroughly, and then reinstalled if there are no breaks in the filtering media.
Aug 04, 2009 | Poulan Garden
Bar sprocket smokes, gets hot spot
Sounds like you're not getting enough oil to the chain. Basically you've got an oil pump, pickup and filter involved in getting oil from the resovior to the chain/bar. If you cleaned the obvious area and the chain is not coated with oil, you may have a clog further up (inside) the oil delivery mechanisms. Also, drain the oil from the tank, and see if you can "blow" air through there. With the saw running & pointed down, you should be able to see oil on the ground being slung off the chain, if not, you are not getting enough oil to the chain.
Nov 29, 2008 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
