Question about Coleman 2 Burner Dual Fuel 424-700G Grill
How do i find out the age of a coleman stove - Coleman 2 Burner Dual Fuel 424-700G Grill
Where can I find a manual for a Coleman Peak 1 Model 576 stove
Try Coleman!
The Coleman Company, Inc.
3600 North Hydraulic
Wichita, KS 67219
1-800-835-3278
TDD:316-832-8707
Aug 19, 2014 | Camping, Backpacking & Hiking
How do you connect the propane to the stove
Assuming you are referring to the Coleman Campers Grill Stove which is a side by side grill and stove unit than it is a pretty simple set up. All portable Coleman stoves set up basically the same. There should be a arm known as a regulator that came with the stove. The narrow end of this attaches to the right side of the stove and screws in. Then the propane bottle screws into the other larger end. make sure all connections are screwed together tightly. For more clarification check out these instructions:
http://www.ehow.com/how_2106008_use-coleman-stove.html
https://www.youtube.com/watch?v=dbYil-YQ8-Y
Good Luck!
Jul 07, 2014 | Coleman Campers Grill
Can I buy a replacement grill?
You could try Coleman, they might be able to supply one.
Wichita, KS 67219
1-800-835-3278
TDD:316-832-8707
Jul 03, 2014 | Coleman Vintage Bernzomatic Deluxe Propane...
How do i light 533
can you tell me more about your model?
Mar 14, 2014 | Coleman Camping, Backpacking & Hiking
Coleman 5423b701
Try Coleman directly.
Wichita, KS 67219
1-800-835-3278
Sep 01, 2013 | Coleman Camping Stove 2 Burner Propane W/...
Parts for a coleman model 4136 stove
You could try Coleman directly if there is no repair depot near where you live.
Wichita, KS 67219
1-800-835-3278
Apr 14, 2013 | Coleman Vintage 4136 Camping Stove
How do you convert a coleman 425e into a propane stove
Is there a reason or a need? I cannot imagine why you would want to, except as a point of interest for your camp kitchen. A new propane stove would work better and not cost all that much, relative to the work and cost of putting fittings, pipes and burners into the old stove box.
Feb 07, 2013 | Coleman 425e 2 Burner Vintage Used Camping...
I have an older (20 yrs) coleman cook top camping stove that does not work. It runs on coleman fuel. What are somethings i can try to fix it
Here is Coleman's web support. I also need some work on my stove.
http://www.coleman.com/coleman/manuals/manuals_resp.asp?category_id=1100
Jul 07, 2008 | Kitchen Ranges
Coleman instastart propane stove regulator wanted
Check to see if Coleman has an attachment to replace the regulator, so that you can use a five gallon cylinder with your stove and your own regulator.
Jun 26, 2008 | Grilling
Coleman 2 Burner Dual Fuel 424-700G Grill Logo
Top Coleman Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
