Question about KitchenAid KDRP407HSS Dual Fuel (Electric and Gas) Kitchen Range
Kitchen Maid KDRP407 - after power failure oven would not work. This has happened in the past and resetting the breaker took care of it. This time we cannot get the oven working. The oven light reads PF. The stove top still works.
fridgetech
  • 473 Answers
SOURCE: Kitchen Aid KESC300 smooth top electric stove
Look on the back of the oven for a tech sheet. This will tell you what the code means and what to check. May be an oven temp. sensor or oven control bad. Can't remember what f7 is without looking at the tech sheet.
Posted on Oct 06, 2007
  • 833 Answers
SOURCE: kitchen aid stove problem
Peter,
First...be sure you cut power to the stove before you do anything. This is 220 volts and it can kill you. 220 Volts is based on two different lines of power coming to the stove, each of which is 110 volts...but opposite each other in phase. This may mean that some power to the stove is on and some is not. Let's go on.
I suspect a few things: First, the coil control for the burner is probably finished. What I also suspect is that it opened one of the two breakers (they are usually tied together in the panel and are either 40/50/60 amp units) causing some lights but no action.
What to do: Reset the breakers as a pair by turning them off and on. If one snaps off, you have a problem at the stove. If not,...which I doubt...you're in business.
Let's look at replacing the control. Shut the breakers. Now, take the burned control and remove it. Note the wiring positions if they are not on a plug. If they are terminals, tape the ends. Now, reset those breakers. If the other burners work, replace the control. Take the old one to the parts store. If it doesn't work, look around the burned area for broken wires. Repair and tape them up. Try again. Oh, and don't let anyone touch the stove while you're working with those breakers.
Posted on Dec 03, 2007
  • 77 Answers
SOURCE: glass top stove hard to work
Glas tops usually detect both heat and time of unit on cycle. notice how burner turns on and off when on lower settings. the biggest issue i get on glass tops is cookware. the cookware should "FLAT!!" bottoms, owners manual suggests using a straight edge to determine. I have tested very expensive cookware ($200 a pot) and it seems to not be flat enough. much expensive cookware is designed to be used on gas tops. pans should also be of a medium weight. I tell people before they buy a glass top, plan on spending nearly as much on your cookware as on the range. A good set of Calphalon (not an advertisement) non-stick is about $500 -$600.
The top has built in sensors that shut the burner down when heat is trapped in an air pocket under the pan. this causes the burner to shut down prematurely and take much longer to cook.
Posted on Jun 14, 2008
SOURCE: Broiler element comes on on Kitchen Aid KDRP407 on all settings
Have you resolved your oven problem ? If so, what was it ?
I have the same exact thing going on....
Brad
Posted on Feb 12, 2010
joeguest2
  • 2080 Answers
SOURCE: Model KDRP407HSS4. The display
Here is the main support page for that model showing the detailed schematic diagrams and the parts lists with prices:
http://www.appliance-parts-warehouse.com/whirlpool-parts/Whirlpool-Range-Stove-Oven-Hood-Parts/Whirlpool-Parts-KDRP407HSS4.cfm
Double check the circuit breakers at the house's main electrical panel and ensure that you are getting the correct voltage at the oven's electrical supply outlet.
Also try pressing the cancel button or setting the clock time on the oven control unit.
If resetting the circuit breakers does not clear the PF error code fault condition, then you probably need a new Oven Control Unit ($200) which is labelled item 5 on the Control Panel Parts diagram.
If the unit is still under warranty I would contact your local service representative and arrange a service call. If the warranty has already expired, then unless you are confident and comfortable disassembling a significant portion of your oven to carry out a moderately difficult repair, I would contact a local appliance technician and have them do the work.
Thank you very much and good luck.
Posted on May 12, 2011
I have an LG stove/oven and for some reason every time I press the oven functions the panel says 'lock'. So I can not use the oven at all. How do I unlock this feature?
Shut the power off at the breaker, wait 10 minutes, then reset the breaker. Sometimes the units need to be reset, as power failures will make the computers in them react 'funny'.
Aug 28, 2011 | LG LRE30451 Electric Kitchen Range
I have a GE gas range at my home in Ecuador. Ecuador being a third world country has frequent power failures. every so offen my ranges clock reads FFF and the oven doesn't work. in the past I pulled the...
Disconnect your range from your AC outlet. At this time determine the time of the day where the power supply is stable and plug the Ac cord the display must reset the time time you plugged in the cord. If no reset happens the control panel board is damaged and must be replaced.
Nov 30, 2010 | GE Kitchen Ranges
Frgidaire Pro Series glass cooktop error code
look at your owners manual and see if there is a reset mode for oven. Had a friend just reset her oven she purchased last year. sounds like it might be the same thing.
May 09, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Brad
Feb 03, 2010 | KitchenAid KDRP407H Dual Fuel (Electric...
My Whirlpool oven fan is running continuously. This happened after the elec. co. shut the power off to change out a pole. We have reset the breaker twice but it is still running. In addition, it locked...
sounds like the electronic oven control has failed. you might check with the electric company to see if they will cover the repair(they usually have insurance to cover this). I have done work before when this type of thing happened and the electric company did pay for it. It is worth a shot.
Dec 18, 2009 | Whirlpool Accubake RF362LXTT Electric...
The electric power to my house was temporarily interrupted, and since it was restored my Modern Maid wall oven has not worked. The timer and griller work, but the wall oven does not. Does the oven need to...
The timer is 110 volt, and the grill may also be . The oven, however, is 220 volt. Suggest you check your main circuit breaker box and reset the breaker set marked "oven" or something similar. This would be the exterior breaker box where power comes into the home.
Nov 14, 2009 | Ovens
GE Stove clock shows FFF and oven will not work
GE Error Code: FFF
Condition: Door motor safety circuit
Fix: Repair Electronic Range Control (ERC)
Usually, failure happens after power surge.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 13, 2009 | GE JSP26 Electric Kitchen Range
Main oven failure
Shut off power at the mains breakers and restart. This may reset the unit.
Dec 10, 2007 | Smeg A2.5 Dual Fuel (Electric and Gas)...
KitchenAid KDRP407HSS Dual Fuel (Electric and Gas) Kitchen Range Logo
100 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
