Question about HP Deskjet 6980 InkJet Photo Printer
I installed a new colour cartridge but the teardrop keeps flashing and I can't print anything.
    Sergeant:
  • 259 Answers
Might have to clean off cartridge contacts and those on cartridge carrier. Use isopropyl alcohol(don't touch nozzles)! and wipe clean.
print test page and/or photo. Align cartridges from maintenance menu and good success......Please rate if it helped. Thank you. Meder's tv service.
Posted on Oct 07, 2010
My deskjet 6122 will not print but a teardrop looking button light keeps flashing. Have tried shutting it off and unplugging but no help??? Bryan
The teardrap light imples that your ink cartridge needs replacing or is incorrectly installed. If you have recently replace your incartridge, check to make sure it is properly installed. If it has been a while, your cartidge probably needs replacing.
Nov 18, 2010 | HP DeskJet 6122 InkJet Printer
Teardrop keeps flashing and won't print anything
Hi Good day.. The problem is on your ink level. To check your ink level please do the following.
1. Click "Start" then Setting
2. Click "Printer and Faxes"
3. right click your printer and then properties you should be in the printer box.
4. Click "Printing Preferences" and then you will see your actual ink level..
that why the teardrop is flashing, maybe your ink has ran out.. refill the ink or replace it with new one..
hope my solution help you.
Regards
JR
Oct 06, 2010 | Office Equipment & Supplies
My printer isn't printing, the teardrop button is flashing on and off and the down arrow button is flashing on and off. Does this just mean I am out of ink?
yes, you don't have ink. you can refill your cartridge by your own or you can go to an expert. take care that the colour number of your cartridge to be the same with the ink you buy.
Sep 04, 2010 | HP Deskjet D4260 Printer
I put in a new cartridge (56) and now my alingment
after replacing the cairtage printer needs alignment it gives a test page when we put it face down on scannes it starts the alignment...
on alignment process it doesn;t found the colour bands so it shows the alignment failure..........
pls install the new colour cairtge the it will give u the printout
thanks....
Jul 08, 2010 | HP PSC 2210 All-In-One InkJet Printer
Teardrop light is flashing yellow. Green clock at left is lighted. Control panel says everything is ready but it won't print. There is no paoper jam.
This light that is showing the Print Cartridge Status. Here is what you can do:
If the light is on and not flashing: Check to see if a print cartridge is low on ink. If a print cartridge is low on ink, consider replacing the print cartridge. If neither print cartridge is low on ink, press the Resume button. If the Print Cartridge Status light remains on, turn off, then turn on the printer.
If the light is on and flashing: Verify that the correct print cartridges are installed.
Follow these steps:
1. Open the printer's top cover, remove the black or photo print cartridge, then close the cover.
2. Do one of the following:
  • If the light is flashing: Open the top cover, replace the print cartridge you removed, then remove the tri-color print cartridge. Go to step 3.
  • If the light is off: There is a problem with the print cartridge you removed. Go to step 3.
3. Manually clean the print cartridge.
After cleaning the print cartridge, reinsert it into the printer. If the print cartridge status light continues to flash, replace the print cartridge.if the light is on and not flashing. Check to see if a print cartridge is low on ink. If a print cartridge is low on ink, consider replacing the print cartridge.
Jan 07, 2010 | HP Hewlett Packard Deskjet 5650 InkJet...
Printer won't print. "teardrop" light is flashing.
"teardrop" light is Ink level indicator.It is saying you are out of ink or that there is a problem with that cartridge. remove it and inspect it, making sure it is not covered with any tape, and reinsert it. If it still fails, get it replaced. If the new replacement fails, you have a failed printing device, and you need another printer.
Aug 28, 2009 | HP DeskJet 6122 InkJet Printer
Printer won't recognise new colour cartridge
I got a new print head @ "staples" office supplies. It didnt cost me anything!!! Kodak had probs with the head, & gave a bunch to staples.....i changed the head, put in new inks, again...got a calibration to run...& things printed np!!!
Apr 14, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
I have just put in both black and colour refills into my printer which is a Pixma MP150, it it printing both black and colour ok, however my Black Ink light still keeps flashing on and off, the coloured...
I think you printer cartridge as sensor which ink levels as it is failed in the black cartridge ,you can either clean the contacts the printer and cart with dry tissue paper and replace and set printer installing new cart or use it like this because the printer company doe not support refilled cartridges to be used .
Apr 09, 2008 | Lexmark X1240 All-In-One InkJet Printer
Wonky colour printing!!
you need to run a print alignment test.. this should correct the colour faults (unless you really do have blocked cartridges,
Sep 27, 2007 | HP DeskJet 5550 InkJet Printer
HP Deskjet 6980 InkJet Photo Printer Logo
87 people viewed this question
Seeker5211
Seeker5211
