Question about Golden Technologies Liteway 3/4 Wheel Travel Scooter
Scooter battery shows full charge but scooter does not move ! red led light flashes 8 times !
  • 692 Answers
Plamont unfortunately that flash code usually means a controller error. The controller is the brains of your scooter. Take the seat off and remove the rear shroud that covers the batteries and motor/gearbox assembly. Check all the wiring connectors for damage or loose connections. After checking the connectors turn the scooter on and see if you still get 8 flashes.
Did Medicare purchase the scooter? If so they will pay for most of the repair costs. You can contact your provider that sold you the scooter or a repair service Repair Xpress@ 1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 Hope this helps you
Posted on Sep 13, 2010
How do I charge a moxie power scooter??
  • Turn the scooter's power switch to the OFF position.
  • Connect the charger's plug to the charging port on the scooter.
  • Plug the charger's power cable into a power outlet.
  • When the charger's LED red/orange light is on, the battery is charging. Optimal charging time is 6 to 8 hours, or up to 10 hours to achieve a complete charge. The scooter manual will have the exact charging
  • Times recommended for your scooter.
  • Stop charging when the LED light is completely green.
  • Disconnect charger from the scooter, then from the power outlet.
  • Run your scooter before riding it to verify the battery charge.
Feb 02, 2016 | Health & Beauty
Why does my chair show a full charge yet after only a half a block it will show only red flashing lite indicating needing charge.
Your batteries are nearing replacement time. They are becoming incapable of holding a full charge.
Apr 28, 2015 | Pride Jazzy Select Elite
My husbands Daytona 4 just started having this charging problem
I'm afraid your batteries have expired. They will show full voltage but the Amps are not being replenished.
Jun 18, 2014 | Drive Medical Health & Beauty
Aquasoothe travelite scooter, the batteries are fully charged, the battery gauge is showing full, but the battery light is flashing. It flashes 7 times then pauses, we can't get the machine to move or...
Response to similar query in 2011.
http://www.fixya.com/support/t5751777-aquasoothe_travel_lite_instruction
not my words. The link to the pdf for this is http://www.discovermymobility.com/store/scooters/summit-scooters/elite-portable-scooter/manual.pdf
you want page 22.
Problem Check Point
The driving of the wheelchair is too slow or insufficient, the status
indicator lamp flashes slowly Batteries are exhausted and need to be recharged
1 flash The battery needs charging or there is a bad connection to the battery. Check the connections to the battery or charge batteries.
2 flashes There is a bad connection to the motor.
Check all connections between the motor and the controller.
3 flashes The motor has a short circuit to a battery connection.
4 flashes Freewheel is engaged.
5 flashes Not used.
6 flashes The controller is being inhibited from driving; this may be because the battery charger is connected.
7 flashes A throttle fault is indicated. Make sure that the throttle is in the rest position before switching on the scooter
8 flashes A controller fault is indicated. Make sure the controller connections are secure.
9 flashes The parking brakes have a bad connection. Check the parking brake and motor connections. Make sure the controller connections are secure.
The-Active-Light
does not function,
the Battery/
Status indicator
flashes rapidly.
Count the number
of flashes:
10 flashes
An excessive voltage has been applied
to the controller. This is usually caused
by a poor battery connection. Check the
battery packs and controller
connections.
Sorry wasn't sure how much space they give you for answers. :)
Oct 11, 2013 | Health & Beauty
Raggta 6 scooter not been used for 12 month,red light on charger flashing all time
A flashing red light orLED on most mobility scooter chargers means the Batteries have a defect as mostchargers also test the condition of the batteries. This has happen becausemobility scooters batteries loose charge when not in use, and need a maintenancecharge at least once a month (best once a week). If this is not done batterieswill fail! Get the batteries load tested to confirm that they are faulty,
Oct 26, 2011 | Health & Beauty
M91 invacare full charge go to move and red leds flash 5 times
Check the freewheel levers they should be in the drive postion turn on and try to see if the lights quit flashing. If the don't then there is a problem with the electrical brake system Hope this helps
Mar 05, 2011 | Health & Beauty
I have a golden companion scooter and it wont move it flashes a green light but i haave no info on where to obtain the trouble codes
The L.E.D. located on the tiller
dashboard will indicate with flash codes what problem is occurring.
L.E.D. Flashes 1 time and pauses, 1 time and pauses…. Batteries are low,
scooter will still operate.
L.E.D. Flashes 2 times and pauses, 2 times and pauses…. Batteries are very
low, scooter will not operate.
L.E.D. Flashes 3 times and pauses, 3 times and pauses….Over voltage to
controller.
L.E.D. Flashes 5 times and pauses, 5 times and pauses….Brake is in the
freewheel position or connection to brake is open.
L.E.D. Flashes 6 times and pauses, 6 times and pauses….Paddle or speed
potentiometer problem.
L.E.D. Flashes 7 times and pauses, 7 times and pauses….Paddle or speed
L.E.D. Flashes 8 times and pauses, 8 times and pauses….Motor
disconnected or faulty.
L.E.D. Flashes 9 times and pauses, 9 times and pause….Controller fault.
I hope this helps they are pretty standard codes I got this from Golden Tech Web Site
Aug 17, 2010 | Golden Technologies Golden CompanioN II -...
4 whhel strider won't run, batteries charged
the motor is not working perfectly and chnge motor or check the connection perfctly
Jul 13, 2009 | Electric Strider Maxi 4 Wheel Mobility...
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Golden Technologies Liteway 3/4 Wheel Travel Scooter Logo
740 people viewed this question
Top Golden Technologies Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Golden Technologies Health and Beauty Expert? Answer questions, earn points and help others
