Question about Sony Handycam DCR-HC20 Mini DV Digital Camcorder
Having problem with my sony handycam DCR-HC20. The touch screen is not giving me the options to rewind, FW, or play bottom. How can I fix this problem
    Genius:
  • 1,812 Answers
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to usually be repaired by a qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Sep 12, 2010
My SONY HANDYCAM DCR-HC26 touch panel is not working n m unable to forward,rewind,play,or do anything...how do i fix this problem..plzz help..its urgent...
Most likely, the flex cable that runs from your LCD to your main PCboard is bad. The only thing that you can try to do is flip your LCD around and against the camera. See if the touch screen will work then. The camcorder will still need to be repaired by an experienced technician at some point.
Hope this helps.
www.austintelstarservices.com
Oct 02, 2010 | Sony Handycam DCR-HC20 Mini DV Digital...
I have a sony DCR-HC20 Handycam, the screen
Hello Gary, sadly lots get the LCD screen go wobbly on the camera types you have, Sony did do a recall on the problem, did you register yours? if so you could have mislaid it.
I had to send my Sony for repair as it went same as you camera has.
Cheers,
David
Jun 06, 2010 | Sony Handycam DCR-HC20 Mini DV Digital...
When I turn my camera on and try to record, nothing shows up on the screen.
Make sure lens cover is open, if still camcorder does not show live view then it is bad ccd imager chip problem that will be replaced.
Let me know exact model of your Sony camcorder to provide you part number info of ccd imager chip.
Thanks.
Sep 24, 2009 | Sony Handycam DCR-HC20 Mini DV Digital...
Lcd screen is blurry on my sony handycam dcr-hc20
This does not sound like a CCD problem yet, but a LCD problem. This would require you to replace the LCD screen. Sounds like the LCD inverter is shot. That is the power supply that is required to back light your LCD.
Before we blame that, you should make sure that all ribbon cables are secure and tight.
Good luck !
Feb 04, 2009 | Sony Handycam DCR-HC20 Mini DV Digital...
DCR HC20 The touch screen does not work. I went to the calibration screen and pressed the "x" like the manual told me...It does not work too, Please help
I believe the flexible cable from the LCD screen to the main control was cut or lose because the action of open and close the LCD, in any case It require a qualifier Tech trained from Sony to replace this FC
DO NOT tampere it, You might damage the LCD screen
Dec 09, 2008 | Sony Handycam DCR-HC20 Mini DV Digital...
Error E:61:10
I suspect an issue with the CCD and the associated image processing circuitry. Please consult a Sony Service Center to have the camcorder serviced. Thanks!
Aug 14, 2008 | Sony Handycam DCR-HC20 Mini DV Digital...
Sony handycam DCR-HC20 Screen blank
i want driver of sony digital 8 ready shot camera
Jul 06, 2008 | Sony Handycam DCR-HC20 Mini DV Digital...
Black and white playback with sony handycam dcr-hc20
There is no problem on your camera, DCR-HC19E is PAL system(European system) DCR-HC20 is NTSC(American system). Are you in US or Europe? I think your TV is NTSC, cause the tape recorded on DCR-HC19E you played has no color. To confirm, connect your HC20 to TV in camera mode, not recording yet, just look at the TV as your monitor, If its in color, no problem, just erase the old video recorded on the HC19E, but if its important to you, you can convert it to NTSC using a PC. thanks
Sep 12, 2007 | Sony Handycam DCR-HC20 Mini DV Digital...
Sony Handycam DCR-HC20 Mini DV Digital Camcorder Logo
103 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
