Question about Cameras
Samsung u-ca5 where do i get flash bulb and is it easy to fit
    President:
  • 2,712 Answers
Try HERE.
Hope that helps!
Posted on May 14, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
What meaning of message code CA5
Zynga Poker accounts. We recommend changing your Facebook password immediately.
Oct 21, 2012 | Zynga Texas HoldEm Poker
Tv shuts off after 1 min and the timer light lamp light and power light flash on and off
Hi, My samsung dlp 46 tv did the same thing, it was the lamp bulb needed to be replaced.
It is easy to replace, we replaced it twice. I paid I believe $85.00 on ebay store, discount tv lamps
hope this works!
Jun 08, 2011 | Samsung HLT6187SAX 61" DLP HDTV
My Samsung DLP HL-P4663W 46 in. turns off every minute and a half. already replaced the bulb, and the timer, lamp, and stand bye flash after turning off.
hello make sure the lamp is fitted securely and the lamp cover as well as there are safety switches. you might have reset the lamp counter hope it helps
regards
shaun
Jan 02, 2011 | Samsung DLP HL-P4663W 46" Rear Projection...
Dim picture on Samsung HLS4266W, wondering if this simply means to replace the bulb?
It sounds like you may need a new lamp. When the lamp stops functioning, you will not have a picture and the lights on the On/Off control (Lower Speaker Bar, Middle of Set) will flash on and off. Search for instructions, it is easy to replace. Once replaced, the picture is as bright as when new.
Nov 28, 2010 | Samsung HL-S4266W 42" HDTV
Ineed a user manual for a Samsung Digimax U-CA5 Camera
You can download user manual free copy of Samsung Digimax U-CA5 from HERE
Thanks.
Nov 12, 2010 | Cameras
Hello.... Samsung HL-P5063W Lamp LED blinks approximately 35 times followed by 1 long standby/temp light blink After this all 3 lights remain lit and flash....lamp/standby and timer makes a loud humming...
Sound like ur tv have two problems.The "lamp"LED light flashes,mean ur tv need a new projection bulb.The loud refrigerator sound,mean the tv colors wheel is dead,it spinning off of it axes motor.Hire a tv repairman to do this the colors wheel is hard change,because require take out many machanicals parts even to get to the colors wheel to change.The bulb is easy replaced,but he there pay him to put new one in.
May 26, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Sony rear projection TV power light flashing red. New bulb recently installed so should be fine there. What causes power button to flash?
hello it will flash if the bulb is not securely fitted and make sure the front cover is fitted securely as well
regards
shaun
Jan 21, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Replaced color wheel and bulb and now the bulb doesnt light
you need to go back and check every plug in the area that you were working in as thev plugs can come lose part way very easy! you should go back one by one using your hands and check every plug for the proper seating into the connector. Good Luck!!!!
Larry Dillon (AKA Techman)
Sep 01, 2009 | Samsung HLP6163W 61" Rear Projection...
How to change headlight bulb on ford mondeo
Very easy, 2 or 3 minutes.
Remove radiator grille. 2 plastic fittings on top, quarter turn and lift out grille.
Remove complete headlight. Simply lift out 2 L shape retaining pins. Disconnect lead. Ease out complete headlamp unit.
Remove back of headlamp unit to access bulbs. Disconnect lead from bulb while bulb still held by clip. Then release clip to remove bulb.
Reverse process to fit.
Jan 02, 2009 | 2001 Ford Focus
Cameras Logo
65 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
