Question about kawasaki Sport & Outdoor - Others
I have a Kawasaki Prairie 360 that chokes out at higher speeds. By that I mean that it runs ok up to about 15 mph the it starts to cough and stutter at higher speeds. Any suggestions?
Check your belt, is the belt light on
Posted on Dec 22, 2010
  • munrag1
    munrag1 Jun 11, 2012
    Check exaust valve clearance!! Adjust if needed......probably slammed closed!!!
  • timothy_made
    timothy_made Sep 20, 2012
    i have kinda the same problem, i get my kawi up to about 15 then when i give it gas to go faster it boggs down.
2008 Kawasaki 360 , automatic quad . It starts up first time, ideals OK and dies after two minutes of running,. Checked carb , fuel filter, air filter, it's still doing it, can anyone advise please .
sounds like fuel flow from the tank is having trouble and its running off the gas built up in the bowl. could be the petcock, tank strainer, tank vent clogged
Feb 14, 2017 | kawasaki 2008 Prairie 360
My 2003 Kawasaki prairie 360 when u install the hose from the air box it will only idle u can not rev it up take the hose off and it runs fine
2003 360 Prairie 4x4 cutting out... I'm stumped! - Kawasaki ...
www.kawasakimotorcycle.org > ... > Kawasaki ATV and Mule
Dec 14, 2011 - This 360 4x4 has me stumped. ... 2003 360 Prairie 4x4 cutting out. ....It idles just fine, it has perfect throttle response, it just won't rev without ... 2006 Prairie 4x4 governor prob?
Oct 1, 2009
04 Prairie 360 Knocking when Idling and Belt Light on.
Jan 26, 2009
Older Prairie Tune Up Questions
Sep 19, 2008
Prairie 360 (Limp Mode)
Jan 4, 2005
More results from www.kawasakimotorcycle.org
Nov 19, 2015 | kawasaki Motorcycles
Will idle & run at slow speeds, bogs down at higher speed.
Prairie 360 revs high but goes slow (45mph) - Kawasaki ATV Forum
www.kawieriders.com > ... > Kawasaki Brute Force/Prairie/Bayou
Oct 27, 2008 - 2006 Prairie 360, wife's ride, polar white, with 26" Swamp Lites on SS108's. ... that it has a low top-speed...45mph is about as fast as they seem to go. ....air cooled motor theres no real performance there, the P360 wts are light ... Can't put 2005 Kawasaki KVF 360 into gear
Jun 30, 2013
Prairie 360 speed/power issue?
Aug 28, 2012
06 Prairie 360, too many rpms???
Nov 30, 2011
2004 Prairie 360: WOT miss
Nov 9, 2011
More results from www.kawieriders.com
Oct 08, 2015 | kawasaki 2005 Prairie 360
Will idle & run at slow speeds, but bogs down at higher speeds.
Prairie 300 carb problems - YouTube
? 0:28
www.youtube.com/watch?v=w1-znueTqFE
Dec 3, 2012 - Uploaded by Joey Fortner
Prairie 300 carb problems ... The slide (the piece you see moving up and down) has the needle running .... 2005 Kawasaki PrairieIdle issue.
Carb Issues
It's winter time...so cold weather is present and you'll have to use the choke. Are you using the choke?
Dec 29, 2013 | kawasaki 2005 Prairie 360
2006 kawasaki prairie 4x4 model kvf 360 c belt indicator light reset
On the right hand side of the ATV just under the gear leaver, you will find a grey and black multiplugs, you will need to swap them. Please see the link below. KAWASAKI 360 PRAIRIE BELT RESET
Sep 23, 2013 | kawasaki 2012 Prairie 360 4x4
I have a 98 kawasaki prairie 400. starts right up and runs great but it will only get up to about 30 mph and then it just wants to sputter and backfire if you try to push it any faster than that. at that...
Hey Frank,
This could be the issue, has this atv been sitting up for a length of time? ... I would put a new spark plug in first,, you may have water in the carb.....you can drain the float bowl and put in the new plug,,, see if that cures it, other wise get the carb professionally cleaned and set. Try this and reply to me.
Jun 16, 2017 | kawasaki 2005 Prairie 360
Kawasaki prairie 360 atv spits & sbuters at wide open throttle & when you gas it from a dead stop but runs fine in between i have already cleaned the carburetor any ideas off what could be my...
its your choke. when the choke is to the left it will sputter around. try moving the choke completely to the right. mine does the same thing u just have to run the choke on the right side. i dont know if its supposed to be on the left or right but if u push it ALL the way to the right it should be fine. my kawasaki 360 prairie is pushin 55 mph so i think i have it set up right.- Kyle
Jul 23, 2009 | kawasaki Quad Bikes
Sport & Outdoor - Others Logo
447 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
Phillip Edwin
Level 1 Expert
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
