Question about Sharp LC-52D64U 52 in. LCD HDTV
I can not remove the stand from my tv - Sharp LC-52D64U 52 in. LCD HDTV
  • 29 Answers
1. Verify that there are 4 screws fastened (2 screws on each side which can be unscrewed using a hexkey)
2. place the TV on a flat surface with the screen facing down... unscrew the 4 screws using the right hexkey size.
3. Pull the stand downwards to take it off.
Posted on Sep 12, 2010
Remove stand from w4207 TV
Put tv on bed face down and look at the stand and locate and remove any and all screws holding stand to the flat screen set. Then after mounting the wall plate per instructions mount the tv to wall mounting.
Sep 08, 2015 | Westinghouse W4207 42 in. HD-Ready LCD TV
I need to remove the stand from my Toshiba 37HL67 so I can mount it on the wall. Can you help me. Auburn Abenton716@aol.com
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface.
Note:
Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws shown in the diagram below. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand a way from the TV (Remorve 5, 4mm or 5/32" Allen Bolts from back of TV.)
For Mordels
26HL67
32HL67
32HL67U
37HL67 = My TV
42HL67
Herb
Sep 22, 2011 | Toshiba 37HL67 37 in. LCD HDTV
I can't remove the stand off the tv
Hi, i have instruction on removing your base stand.
Note: Extreme care should always be used when removing
without tools.
3) Remove the four screws shown in the diagram below. This will
4) Once you have removed all four screws holding the pedestal
sliding the pedestal stand away from the TV.
Feb 12, 2011 | Toshiba REGZA 52RV530U LCD TV
Can't remove base from Regza 37HL17
download manual and check' page 5 'for wall mounting.
without tools.
Five screws
Feb 14, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
I just purchased a JVC 47'' LCD just need to know how to remove the stand. I have it hanging on a Unti do not need the stand.
1. remove the 4 screws on the back of the TV (these are located in the deep holes above the stand)
2. after the screws are removed, the TV will lift from the stand.
The stands sits inside the TV. after the screws are removed the TV will still sit on the stand. you (and someone else) will need to lift it from the stand.
Nov 10, 2009 | JVC LT-47X788 47 in. LCD HDTV
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
How to remove tv stand from toshiba 42 inch lcd model 42hl167
Remove 5 screws as shown in below image to remove stand of TV.
It is also mentioned in user manual of TV page-5, click Toshiba Support to download a copy, if required.
Thanks.
Aug 30, 2009 | Televison & Video
I want to wall mount my 26LB30QD but the stand needs to come off, there is nothing in the instuctions on how to remove the stand, please advise.
With the tv laying flat on to the screen, remove the two screws in the recessed holes. Then remove the two screws above towards the input panel, one under AUDIO-L/AUDIO-R and the one under HDMI-1. The stand should easily slide out.
Mar 06, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Taking stand off toshiba regza tv
forget the four holes on the bottom of the stand. Remove the five allen bolts on the back bottom of the tv-not the stand. Yank on stand and metal plate slides out with stand.
Jan 25, 2009 | Toshiba REGZA 47HL167 TV
Question on toshiba tv - fixya post
Found this on the www.Toshiba.com website. Q. How do you remove the stand?
Models: 26HL37, 26HL47, 32HL17, 37HL17, 42HL17, 32HL37, 26HL67, 32HL67, 37HL67, 42HL167, 42HL67,
47HL167, 52HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00078
1. Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface. NOTE: Extreme care should always be used when removing the pedestal
2. Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can
3. Remove the five screws shown in the diagram below. This will allow removal of the pedestal stand.
4. Once you have removed the five screws holding the pedestal stand in place, remove the stand from the TV by
sliding the stand away from the TV. The Toshiba customer service number is 1-800-631-3811. Hope this helps you with your problem.
Dec 22, 2008 | Toshiba 42HL167 42 in. LCD Television
Sharp LC-52D64U 52 in. LCD HDTV Logo
262 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
